#2843 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So got my Ryzen 9 yesterday. Plugged her in and didn't get a post, so I figured I'd need to update the bios. Did that this morning and everything started out great, but once windows started to boot, it froze half way. I can get into the bios no problem, but it won't let me get into windows. I tried a slightly older bios file and same thing happened. Any thoughts? It's an MSI B550i btw.
#2844 | |
TRACKBREAD
Any PC Gamers Around?
Are you going from Zen2 to Zen3? You may need to update the bios with the Zen2 CPU installed. Edit: unless the board has a bios flashback feature, then you can do it without a cpu at all. |
#2845 |
It's zen3 to zen3. Ryzen 5 to Ryzen 9. I did the bios flashback since the stock bios didn't post. But now it's giving me that wired freeze. Got into safe mode but that's not really useful for me.
| The Following User Says Thank You to weederr33 For This Useful Post: | Yoshoobaroo (07-25-2021) |
#2846 |
LMGTFY
Drives: 13 FRS, 91 Miata
If you can get into safe mode it's probably something that's auto loading at startup.
Turn everything off and see if it boots. taskmanager>startup and everything not MS in MSCONFIG |
| The Following User Says Thank You to x808drifter For This Useful Post: | weederr33 (07-25-2021) |
#2847 |
ProCrastinationConsultant
You're using a preconfigured copy of windows?
A processor change has always required reloading windows for me to get all the appropriate drivers/locations sorted out.
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (07-25-2021) |
#2848 |
I've swapped MOBO and processors a couple times now with the same NVME with windows set up on it, and it's never done this before.
#2849 |
Im wondering if doing the clear CMOS will help?
| The Following User Says Thank You to weederr33 For This Useful Post: | Spuds (07-25-2021) |
#2850 |
Yes should have been your first step
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | weederr33 (07-25-2021) |
#2851 |
Drives: 2017 BRZ
Make sure there weren't bios changes - a flash nearly always resets it but try a clear anyway.
UEFI on/off for example, though I'm not sure you'd get safe mode if that were set wrong - haven't tried it though. That assumes you know how it used to be configured. My bet if you were to swap back to the other CPU with no other changes is you'd still not boot.
| The Following User Says Thank You to cjd For This Useful Post: | weederr33 (07-25-2021) |
#2852 |
TRACKBREAD
I would clear CMOS and then load optimized defaults in the bios, see if that boots.
If that doesn’t work I would swap the old processor back in just to make sure that still boots. If it does at least you know it’s either a configuration problem or a hardware issue with the new processor. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | weederr33 (07-25-2021) |
#2853 |
Ok, cleared CMOS with R9 still installed: fail
Swap R5 in: fail Updated BIOS with R5 in: fail So... at least I know it wasn't the expensive R9. Damn you MSI! I'll try a few other tips if anyone has anything, otherwise might revert back to an Asus B550i
#2854 | |
Drives: 2017 BRZ
It's bios a setting which was not the default and/or where the default changed, causing your OS issues. I'd take a look at UEFI on a whim, as I think that was not shipping as default for a long time, but recently has been. Do you know if your OS drive boot sector is GPT or MBR? Some settings depend on GPT. Could be >4gb access or something like that as well.
#2855 | |
#2856 |
1st86 Driver!
Where in the process is it failing? Do you have any indication?
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
