Old 04-25-2014, 12:33 PM   #85
Racecomp Engineering
I think you have the Swift rates backwards...the BRZ Swifts are firmer up front than the FRS Swifts.
Of these springs I'd prefer the Swift BRZ set. You'll be riding the bumpstops with the RSR springs. You're very very close to them with the Swifts, but at least they have firmer front rates to help.
- Andy
Old 04-25-2014, 12:35 PM   #86
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
also guys, its important to note that Swift has 2 types of springs for the frs/brz. Sport, and Spec-R
Both springs are designed for stock shocks, but the Spec-R are designed at the upper limits of the stock valving.
It bothers me that an aftermarket manufacture(RS-R) would make separate spring rates for the frs/brz, lol. I feel like it just adds to confusion.
Anyway, the specs of the springs are as follows: (direct from manufactures)
RS-R(for FRS)
Front .4-.6 drop, 2.82kg/mm or 158lbs/in
RS-R(for BRZ)
Front .4-.6 drop, 3.16kg/mm or 177lbs/in
Swift Sport(frs/brz)
Front 1.1 drop, 3.0kg/mm or 168lbs/in
Swift Spec-R(frs/brz)
Front 1.1 drop, 4.4kg/mm or 245lbs/in
RS-R(For FRS)
Rear .4-.6 drop, 4.49kg/mm or 251lbs/in
RS-R(for BRZ)
Rear .4-.6 drop, 3.62kg/mm or 203lbs/in
Rear 1.0 drop, 4.5kg/mm or 251lbs/in
Rear 1.0 drop, 5.3kg/mm or 296lbs/in
The Following User Says Thank You to continuecrushing For This Useful Post:
TofuJoe (08-21-2016)
Old 04-25-2014, 03:10 PM   #87
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by SurfAndSand View Post
How are the stock dampers holding up?
i have 5000 miles on mine - no problems at all
supramkivtt2jz is offline   Reply With Quote
Old 07-12-2014, 05:40 AM   #88
86Toyobaru
Drives: 86 & GRB
I have a question. I just get my RSR superdown but it doesn't come with bumpstops. So do you cut OEM bumpstops or not? If you do, how much did you trim it? Thanks in advance.
Originally Posted by DAEMANO View Post
Installed the RS*R Superdown's today
Basically, it feels more Racecar and less GT. Here's a pic.
86Toyobaru is offline   Reply With Quote
Old 07-12-2014, 07:52 AM   #89
troek
troek's Avatar
Drives: 2012 Toyota 86
i cut mine when i put them on. i followed a guide by one of the other manufactures. i tried finding it for you but i cant seem to....
EDIT:
maybe i followed this
http://www.techautohow.org/2013/06/0...rs-subaru-brz/
The Following User Says Thank You to troek For This Useful Post:
86Toyobaru (07-12-2014)
Old 07-12-2014, 08:21 AM   #90
86Toyobaru
Drives: 86 & GRB
EDIT:
すみません Troekさん According to hotchkis pic below, is that how much you trim for your bumpstops? Can hotchkis apply to RSR's bumpstops length as well? What if we didnt trim bumpstops? Is that bad for suspension?
Old 07-12-2014, 10:32 PM   #91
troek
troek's Avatar
ahh 日本語話せますか。 yeah im pretty sure thats what i followed for my springs, most springs come with shortened bump stops, or a guide to cut the old ones. i think if you didnt trim bump stops it wouldnt harm anything other than you would hit them under cornering easier creating a spike in spring rate, which would be undesirable.
86Toyobaru (07-13-2014)
Swift Springs BRZ TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 149 05-12-2015 01:33 AM
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 10:36 PM
wtb:swift frs springs bkblitzed Want-To-Buy Requests 0 06-16-2013 05:03 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 05:26 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 07:15 PM
