| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Reverse Burnouts
Drives: 2013 Argento FRS
because when you corner, weight distribution matters, corner entrance, on the apex, and at the exit, if to much weight is transferred to the front you under steer, stiff anti roll bars shift the weight further back to balance out weight transfer while cornering, grip then is distributed accordingly between the tires that the car is leaning on through the corner
the result is less under steer, power on earlier when exiting a corner, faster cornering speeds, better turn-in all that equal better laps, so it does matter the car could be light but if the weight is skewed and isnt distributed equally, the car will turn better one way or the other or will under steer more on right and vs left hand corners if the left and right weight was 60/40 right hand cornering would be faster than left hand or if 32% of the weight was on the front right tire, the limit for the tires breaking away and under steering would happen sooner on right hand corners my celica under steers more doing left hand corners because the I4 engine and transmission placement,
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#44 |
Site Moderator
Drives: Stuff
But he was asking about it after traction was already lost, which is kinda pointless.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#45 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
However, by limiting suspension movement, this can actually increase grip by keeping the suspension within its optimal range. So the effect of a sway bar will depend on the application and the size increase/decrease. Vehicle suspension is an amazingly dynamic thing that deals with nearly every form of practical physics. But it means that a single change can have varied and sometimes subtle results. Which is why I prefer suspension tuning over engine tuning. You never have zero traction. Even in a slide, your suspension setup matters for car control. Believe me, my main hobby is playing outside the traction circle. |
#46 | |
#47 |
Site Moderator
Drives: Stuff
I don't disagree. I'm a big fan of the grip circle and exceeding it under control, but the last thing I worry about is weight transfer after it's already been exceeded, and really, the concept is the same as before grip is exceeded so I don't see the difference in discussing it separately.
-Dave
#48 | ||
Reverse Burnouts
and by making the car a bit more oversteer friendly the cornering characteristics change and weight is transferred to the cornering tires differently
#49 | ||
Corner Junkie
Ideally, you'd want a matched set, preferably adjustable so you can tune the roll balance to your taste. Quote:
#50 |
Delights in pure handling
Drives: Zoom Zoom
What were you talking about then? Supposedly the car is already designed for this so it won't add much weight or take any rigidity away anyways. Not sure how the front seat placement is changed.
#51 |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Let's set one thing straight.
For a 2 door sports car the lightest design is a fixed roof coupe designed to be nothing but. A convertible designed from the ground up as a convertible will be light, but not as light as a fixed roof coupe. And a fixed roof coupe designed from the ground up to allow for a future convertible version will also be heavier than a fixed roof coupe. This isn't rocket science. Anyone that thinks an S2000 would weigh more if it was designed from the ground up as a coupe instead of a convertible needs to get their head checked.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#52 | |
Drives: Zoom Zoom
Exactly. Which makes you wonder how much lighter the BRZ/FRS would have been if there was no plans for a convertible version. |
#53 |
Site Moderator
Drives: Stuff
Didn't they say "It's possible but there are no plans for a convertible." or similar?
With all the structure they put into the roof it seems kind of unlikely that it was really built with a convertible in mind.
-Dave
#54 |
Reverse Burnouts
#55 | |
Site Moderator
Drives: Stuff
<<< doesn't read the FR-S.
-Dave
#56 |
Drives: s2000
Not exactly favoring the convertible FT86, but it is what it is. It'll look pretty good when it's running fast though!
The BRZ looks pretty light and probably has an ability to drop a few more pounds with the right wheels, seats, suspension system, and exhaust. Overall, I think a proper weight should be around 2650lbs. This would mean the car has high potential on the track. The turbo might make the car more potent if the weight can be minimized as well.
| Toyota FT-86 scale models starting to be sold | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-03-2013 10:23 AM |
| Toyota rep at Frankfurt IAA said FT-86 weight will be 1,160kg (2,555 pounds) | weger | Scion FR-S / Toyota 86 GT86 General Forum | 183 | 10-13-2011 12:18 PM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
| GUNDAM SCALE HOBBY | Dark | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 04-27-2010 10:34 PM |
| GTR World FT-86 article (speculates on weight of 2,645 pounds) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 01-12-2010 05:31 PM |
