| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Reverse Burnouts
Drives: 2013 Argento FRS
hes talking about when sliding all the weight is transferred to the direction of the slide, thats why tires squish when you turn its because the wright is transferred through inertia and you feel it as g forces, the harder a tire grips the more weight is on that side of the car, thats why performance tires have (weight) load ratings because of grip, gforces, and inertia
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#30 |
Butterscotch Boss
Drives: 335i
#31 |
Drives: Attitude
#32 |
Still about 200lbs heavier than I would've liked... if the MX-5 could do it why can't Subie/Toyota?
*Rhetorical question - don't answer this* What's done is done.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#33 | |
#34 |
Hot Dog
Drives: quicker than arghx7
Hmm, I hadn't considered the advertised weight being will a full tank of fuel. The math works out pretty close if that's the case, since gasoline is 6.1 lbs/gallon, adding 40 lbs to the scale weight makes sense, since both reports claim the car had about a half-tank of fuel.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#35 | |
Drives: Attitude
#36 |
Hot Dog
Well that's what I get for not looking into it and solely relying on corner-weight scales.
#37 |
Drives: '23 BRZ
Weight distribution is the result of many compromises. Primarily, minimized size/weight and +2 seating. They could have made the wheelbase longer with the front wheels shoved further forward relative to the engine/passenger compartment and made it 50/50, but there would be a size/weight penalty.
55/45 isn't that great, but at 2700 lb., I'll take it. Would be cool if they also made a 2-seat sports car out of it on the same wheelbase, with the engine and front seats moved aft by 24" or so. 50/50 or better, no prob. |
#38 | |
Delights in pure handling
Drives: Zoom Zoom
http://www.ft86club.com/forums/showt...ht=convertible |
#39 | |
Drives: '23 BRZ
#40 | |
Drives: '23 BRZ
When convertibles are made out of existing fixed-roof coupes, you get a ton of weight gain. This is not the case for dedicated roadsters like the Miata, Boxster (lighter than Cayman!), S2000. For them, there is no convertible weight penalty. Even the Corvette is only ~25 lb. heavier in convertible form. A 1989 240SX weighed ~2650-2750 lb. The FR-S/BRZ are pretty much the modern incarnation of that car, and weigh the same. So, no weight gain from "new safety features". Or, rather, advances in design, materials, and fabrication techniques negate that. 2700 lb. is pretty much as light as could reasonably be expected, I consider it a success in that regard. As much as I too would rather it were in the 2300-2500 lb. range... |
#41 | |
![]() Read the article below and pray we get a Man's version of the greatest roadster ever made. http://www.edmunds.com/mazda/mx-5-miata/history.html "The 1990 Miata was truly tiny. With an 89.2-inch wheelbase and stretching out just 155.2 inches overall, the Miata was 16 inches shorter than Mazda's smallest sedan that year, the Protegé, and rode on a wheelbase 9.2 inches less expansive. Mazda made the Miata's small size a virtue. Everything about the car had a delightfully light touch. Instead of smothering the pavement under huge rubber, it relied on careful tuning of the double wishbone (front and rear) suspension to get the most out of modest P185/60HR14 tires. Power steering was an option, but the standard manual rack-and-pinion setup reacted instinctively to steering inputs and reported back even subtle details about what was going on with the tires." "The biggest advantage of the Miata's small size was its feathery weight — just 2,116 pounds in base trim. Because light cars don't need big engines to achieve an entertaining power-to-weight ratio, the first Miata was powered by a 1.6-liter, dual-overhead cam, 16-valve inline four making a modest 116 horsepower." |
#42 | |
| Toyota FT-86 scale models starting to be sold | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-03-2013 10:23 AM |
| Toyota rep at Frankfurt IAA said FT-86 weight will be 1,160kg (2,555 pounds) | weger | Scion FR-S / Toyota 86 GT86 General Forum | 183 | 10-13-2011 12:18 PM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
| GUNDAM SCALE HOBBY | Dark | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 04-27-2010 10:34 PM |
| GTR World FT-86 article (speculates on weight of 2,645 pounds) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 01-12-2010 05:31 PM |
