Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 03-19-2012, 04:59 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by serialk11r View Post
What is "the junk in the trunk"? Spare+tools?
Yes. It's all the crap the auto-x'ers would toss prior to making their runs. Spare, tools, carpet, foam blocks, everything that's quickly removable.
Originally Posted by Draco-REX View Post
Here's a question:
Why are people speculating on heavier weights?
The only question left is the weight delta between the pre-production cars roaming the USA and the actual USDM production cars that started "for real" production a last week.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-19-2012, 05:29 PM   #16
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Originally Posted by ForReal-Someday View Post
I think they probably set it up this way to make the car more prone to oversteer, which fits with their "fun" intentions.
Don't you mean the reverse? A front-heavy car tends to understeer not oversteer.
2004 WRX Wagon PSM. Link to my car journal HERE.
ryun84 is offline   Reply With Quote
Old 03-19-2012, 05:46 PM   #17
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
So the weight numbers are pretty darn close to what was predicted. That's a good thing.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 03-19-2012, 05:46 PM   #18
oneday
Opinionated
oneday's Avatar
Drives: Something Red
Tell that to the E30 race car I drive....we had to add weight to the trunk to keep the back end on the ground.
That said, nose heavy cars can be very understeer prone depending on the suspension set up.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 03-19-2012, 05:50 PM   #19
catharsis
Drives: honda civic si 08
Nose heavy cars have a tendency to understeer and then snap over steer.
catharsis is offline   Reply With Quote
Old 03-19-2012, 05:51 PM   #20
ryun84
ryun84's Avatar
Yeah, I'm speaking in general terms. There are many factors that contribute to oversteer/understeer. If anything, I think the engineers made the weight distribution the way it is in order to have neutral balance with a hint of understeer, as many test drive reviewers have mentioned. I think bringing the distribution to 50/50 would disrupt this balance and cause the car to be oversteer prone (and dangerous), at least with its current suspension setup.
Old 03-19-2012, 05:57 PM   #21
scorcherjf
Drives: RX8
With stock camber, struts up front, staggered tires, and 55% of the weight up front I think it'll understeer quite a bit...
scorcherjf is offline   Reply With Quote
Old 03-19-2012, 06:14 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Ryephile View Post
So Subaru BRZ Forum dot com post [w/picture for proof] is saying 2723 lbs, which is likely with trunk junk. SCCA forum post is saying 2686 lbs, but then says trunk junk is worth 35 lbs. 2686 + 35 = 2721, only 2 lbs off the other post. Sounds very plausible, and good news that the car is lighter than advertised! The only thought of caution is the pre-prod's touring the USA may not have the full compliment of USA crash structure. Actual production weight may or may not be different. Nevertheless, it's a good first sign.
Not a full tank of gas.. add that back in and it's as advertised.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-19-2012, 06:15 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And the fact that this car was missing 50lbs of gas
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-19-2012, 07:14 PM   #24
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Where is the weight coming from? The car is as small as an s2k, but weighs about the same as a stock base. You would think the BRZ would weigh significantly less given that it doesn't have to reinforce the chassis as much as a convertible. Is it from all the new safety features that are put into new cars?
iLuveKetchup is offline   Reply With Quote
Old 03-19-2012, 07:26 PM   #25
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
According to some new reports the ft86 was built with a topless version in mind so they did do a lot of strengthening
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 03-19-2012, 07:41 PM   #26
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
The important numbers are in the cross corner weights, which look very, very good. Understeer is easy to cure, sometimes with just tire pressure adjustments.
taosracer is offline   Reply With Quote
Old 03-20-2012, 12:26 AM   #27
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
What about when the car slides? Wouldn't the weight shift on its own while sideways? The inertia has to travel somewhere
Snoopyalien24 is offline   Reply With Quote
Old 03-20-2012, 12:46 AM   #28
fatoni
What are you talking about?
Toyota FT-86 scale models starting to be sold Axel Scion FR-S / Toyota 86 GT86 General Forum 94 09-03-2013 10:23 AM
Toyota rep at Frankfurt IAA said FT-86 weight will be 1,160kg (2,555 pounds) weger Scion FR-S / Toyota 86 GT86 General Forum 183 10-13-2011 12:18 PM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
GUNDAM SCALE HOBBY Dark Off-Topic Lounge [WARNING: NO POLITICS] 15 04-27-2010 10:34 PM
GTR World FT-86 article (speculates on weight of 2,645 pounds) Axel Scion FR-S / Toyota 86 GT86 General Forum 10 01-12-2010 05:31 PM
