Old 07-27-2013, 02:23 PM   #1
Scoobidude
Drives: DGM BRZ
I walked out to my car to find this....
So i went out last night and this morning when I woke up to go wash my car I found this
Anyone know of anything I can use to fix this.
Scoobidude is offline   Reply With Quote
Old 07-27-2013, 03:16 PM   #2
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
An insurance policy? Looks like it is scratched down to the primer or bare metal, so it will need paint to completely cover/hide it. I'd start out with Meguiars Scratch-X 2.0 for starters, should make it look a little better. If you can't cover it with paint right away, put some wax over the area to keep any rust from forming in case it went down to bare metal.
To get paint on it, I would use touch-up paint, and ideally dilute it, then use a really fine tip artist's paint brush to fill the scratch, using multiple thin coats instead of one or two thick coats. If you did wax over the scratch before painting it, remove the wax with Dawn dish soap.
There might be better ways to do it, but this is what I would personally do (and have done in the past) for similar scratches.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Scoobidude (07-27-2013)
Old 07-27-2013, 03:17 PM   #3
qijian
Drives: FRS
its its not too deep, try meguiars ultimate compound... works best for me when it comes to scratches like those. Apply wax afterwards and it should help it look better.
qijian is offline   Reply With Quote
The Following User Says Thank You to qijian For This Useful Post:
Old 07-27-2013, 03:39 PM   #4
Scoobidude
Drives: DGM BRZ
Ok cool thanks ill get some touch up paint. Now what if the paint gets on the outside of the scratch and has the raised look. What can I do to get it smooth again with no bumps? Sand it?
Old 07-27-2013, 04:06 PM   #5
Miniata
It is bound to happen that some paint will get outside the scratch. You can level it off if you very carefully use 1000 grit sandpaper, then 2000, then 3000 to level it off with the rest of the area.
Old 07-27-2013, 04:07 PM   #6
whaap
whaap's Avatar
Take a lot of time and use a tooth pick to fill in the valley but don't get any on the good paint. It will probably take a few coats. Once it's built up it shouldn't be too hard to buff it out.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Old 07-27-2013, 04:37 PM   #7
Scoobidude
Drives: DGM BRZ
I had some generic scratch remover and tried that. It darkened it up a big but its still very noticeable I'm going to go to the dealership and get some touch up paint and get that
Old 08-01-2013, 08:32 PM   #8
TheSandeman
TheSandeman's Avatar
Drives: Audi TT VR6 Coupe
good to hear you sorted that out - dont forget to get the clear too along with the black base coat
TheSandeman is offline   Reply With Quote
Old 08-01-2013, 08:37 PM   #9
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Looks like someone keyed it. If that was me I would be getting the whole panel painted again (I know it's costy). I am OCD about those kind of things. Touch up paint from the dealership will be your best bet to hide it. None of the scratch remover/wax applications will help at all. Those are for surface scratches in the clear coat only. I feel for you. Been there done that.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
Scoobidude (08-02-2013)
Old 08-02-2013, 12:22 PM   #10
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
If the scratch can catch your finger nail it can't be "buffed" out.
If its deep and you want to best fix it, you need to fill in the scratch with 1 part bondo, then wipe off excess with a reducer, then paint on a bit thicker with sucessive light coats rather than one huge thick, sand back when dry and polish. If you don't fill the scratch first it will look not so hot.
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Meguiars/Ford detailing team SEMA 2010 and 2011
Ask a pro blog writer for detailed image
duPont Registry approved detailer
Greg Nichols is offline   Reply With Quote
The Following User Says Thank You to Greg Nichols For This Useful Post:
Still trying to find a BRZ? sparks BRZ First-Gen (2012+) — General Topics 27 01-14-2013 06:46 PM
[GTA] Where can I find... drei CANADA 39 12-05-2012 04:37 AM
Want the BRZ but can't find one kduff85 BRZ First-Gen (2012+) — General Topics 9 07-10-2012 09:33 AM
Test drove a FRS! Walked away.. Enigmus Scion FR-S / Toyota 86 GT86 General Forum 43 06-23-2012 10:34 PM
It's here!! I just walked out of my office... Indestruct BRZ First-Gen (2012+) — General Topics 13 06-01-2012 01:32 AM
