#15 |
Drives: Scion FR-S
I got a small ding a month ago on my door and have been debating paintless dent removal. I like this better, so I think I'll use this to cover it up and use the ding location as a good locator for the strip to hopefully prevent this in the future. For what it's worth, my dent is about where you put your strip. Thanks!
#16 |
Is your car lowered or running bigger wheels & tires? looks good
#17 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
| The Following User Says Thank You to shiumai For This Useful Post: | White64Goat (07-28-2013) |
#18 |
Drives: Fr-s 2013 white out
i wonder how it would look on pearl white
#19 |
i'm not really enamoured by the look of the STi side skirts - i prefer the more subtle chargespeed ones or the prova ones. but, i'm not 100% sure i want side skirts otherwise i'd have put some on. i'm sure more styles will come out as time goes on.
#20 |
Drives: WRB Series.Blue
I like it, goes really well with the car. You did a great job.
For those not wanting to stick something permanent on the car, I saw these on a car the other day. They're called Door Shox http://www.doorshox.com/index.htm |
#21 |
Drives: 2013 CBS BRZ
What kind of spats and rear diffuser you got on there. Looks sick! Even these door ding things look good on urs.
Say that 5 times fast "Door Ding Thing" |
#22 | |
If you click the BRZ/FR-S link, I believe there is a WRB one that has these installed and it actually looks pretty good. (I can't believe I'm saying this! I've removed these on every car I've ever owned!) |
#23 |
#24 |
Where did you get the copy from. I dont wanna pay 500 for the oem
#25 |
you can get it from a vendor here:
http://www.ft86club.com/forums/showthread.php?t=29019 |
| The Following User Says Thank You to shiumai For This Useful Post: | TONYpepperon1 (07-31-2013) |
#26 |
Drives: Scion FR-S
I was having issues with door dings (Already got two on both sides of the car), so bought these as well. Took 3-4 weeks to come in. Paint matched really well, but a few minor paint defects did exist, but nothing major (a few small pits). Took about 1 hour to install. Just some tips:
1) When using the bond promoter, don't push too hard when applying or it will drip and run down your door panel (promoter comes with trim). I had to use scratch remover to get the drip out. 2) Use painters tape to tape the trim to the door and then step back and see if you like positioning. I used the trim to cover a dent, so I didn't follow the dimensions given in the instructions. After the dent was covered, I measured from the door handle scoop and the side mirror to get the same height on the other side. Then use painters tape to mark where the trim is, and take off the trim (then use bond promoter etc. per instructions) 3) The gap between my small trim and large trim is a bit off from one side to the next due to my own fault (1-2 mm), so before you stick it, double check that it's exactly where you want it. Overall pretty happy. Where I put them was exactly where the damage was on both sides due to door dings. I'm pretty confident this will prevent quite a few in the future. Here's a pic installed.
#27 | |
Drives: FR-S Whiteout
#28 |
i don't know - i think white on white would blend in just as well. the thing that gives it away on dark colours are reflections. on lighter colours, it's the shadow beneath the trim. i don't think it'll be much different in any colour.
| Plastic protection strip on bottom corner of door sill | robo_robb | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 12-12-2015 01:11 PM |
| Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 02:30 AM |
| Shoes Driver side door | gr8scott | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 05-12-2013 10:22 PM |
| Door ding prevention! | smbrm | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 01-29-2013 07:22 PM |
| does your car come with side door marker light? | excited86 | CANADA | 12 | 08-02-2012 07:07 PM |
