Old 07-27-2013, 09:02 AM   #29
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
A twincharge system on this car would be great, but personally, I'd use a roots type s/c instead of a twin screw. There's no internal compression as it just compresses air against the intake manifold. then pair that with a fairly enormous turbo, one that would probably never see enough flow from the motor in its stock form. Use the s/c for the low end and to increase flow so the turbo can spool. Fueling upgrades would be required unless the stock system can handle the amount of air flow generated. The hardest part would be getting the motor to handle the increase in air pressure. at that point I think you'd have to do low comp pistons as you'd be shooting for a 25-35psi output from the turbo, after the intercooler and going through the S/C.
Old 07-27-2013, 09:17 AM   #30
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
If anything, maybe do a "twin turbo" sequential setup using an electric turbo feeding something like a gt35.
Use the electric turbo to provide boost from 2k-5k and the gt35 for an amazing kick the ass from 5k-redline. I wonder who would want to tune something like that? Wouldn't be much different using a hit of nitrous to spool a big snail. That's been done for drag cars.
industrial is offline   Reply With Quote
Old 08-16-2013, 10:45 AM   #31
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Guys. As I'm sure Nix may already know I am currently neck deep in my twin charged twin intercooled system. The turbo I am using (made 354rwkw) is a Gtx3076r modified by blouche and got me the highest hp 86 in Australia title. I am running a PERRIN barrel cooler between the turbo and the sc as I already have cooled water from the sprintex intercooler system. The supercharger will be set at a stable 9psi and will be fed another 14psi from the turbo compounding the boost. This is on a fully built Fa20 with 10.1:1 comp. It should make a little over 400rwkw and minimal lag.
Sent from my GT-I9505 using Tapatalk 4 Beta
jet86 is offline   Reply With Quote
The Following 3 Users Say Thank You to jet86 For This Useful Post:
CSG Mike (08-16-2013), Hawk77FT (08-18-2013), Sportsguy83 (08-16-2013)
Old 08-16-2013, 10:46 AM   #32
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
That's supposed to say PWR barrel cooler not Perrin obviously lol....
Old 08-16-2013, 02:30 PM   #33
Aaron_blatherwick
That is awesome! Do you have any pictures or videos? How's the off / on throttle response? Does it feel torque monster or a boost bomb?
Aaron_blatherwick is offline   Reply With Quote
Old 08-16-2013, 03:24 PM   #34
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
This would be the mother of all FA20 builds but with one of these and a serious fuel system I would say go for it!
Seriously people on this forum here need to lighten up. If you have the $20-$30k to put into such a monster build and you made it work we would worship you...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-16-2013, 03:44 PM   #35
suaveflooder
This has been happening on Mustang Cobras for a couple years now. Cool idea. I know the cobras are putting down good numbers with it. Interested in seeing numbers on an 86
suaveflooder is offline   Reply With Quote
Old 08-16-2013, 11:39 PM   #36
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
This is the turbo setup I built. 473.8hp. Currently installing the sc as we speak.
The Following User Says Thank You to jet86 For This Useful Post:
Sbeezy (08-18-2013)
Old 08-18-2013, 03:23 AM   #37
SKELLINGTON
Drives: 2013 CBS BRZ LIMITED
why twin charge you say? because racecar. or because this --->[ame="http://www.youtube.com/watch?v=HmscSzFurwg"]The World's Fastest Lotus? - /TUNED - YouTube[/ame]
SKELLINGTON is offline   Reply With Quote
Old 08-18-2013, 04:04 AM   #38
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by ft_sjo View Post
It compresses it further. That doesn't change the difference between air mass and air volume. Do you know the difference? If a given object chokes at a given air mass, further compressing the air isn't going to help that.
I'm no expect on fluid dynamics, though, but i'm sure someone can chime in to talk about the friction aspect of it.
You don't get it. The supercharger flows a specific amount of air per revolution, yes, but the limit there is the amount of air available to the supercharger at the induction point. If you push more air into the supercharger's inlet, you are going to be moving more air at the outlet also.
A roots unit would be better for compound charging, but the twin screw isn't as much of a limitation as you're implying.
To the OP: You need a bigger turbo for a twin charged setup. A 300hp blower with a 300hp turbo is going to result in a 300hp max. Your example would result in an AVO turbo car that makes less power than other AVO cars. The turbo is the limiting factor, airflow wise, and the supercharger is going to be sucking up horsepower that other AVO cars aren't losing.
Sellout is offline   Reply With Quote
Old 08-18-2013, 04:11 AM   #39
s2d4
s2d4's Avatar
Yeah, I ignored his reply as he had no idea what he was on about.
Old 08-18-2013, 04:30 AM   #40
ft_sjo
Drives: GT86
I await your technical explanation with baited breath.
Old 08-18-2013, 04:36 AM   #41
Sellout
Mr. Cranky Pants
Sellout's Avatar
Highly technical explanation incoming.
More air in = more air out.
The Following 4 Users Say Thank You to Sellout For This Useful Post:
mswhong (08-18-2013), s2d4 (08-18-2013), Sbeezy (08-18-2013), suaveflooder (08-18-2013)
Old 08-18-2013, 06:07 AM   #42
s2d4
s2d4's Avatar
Lol, he missed out density as well....
It isn't as if the 2 compressors are trying compress gases into liquid...
The Following User Says Thank You to s2d4 For This Useful Post:
Sbeezy (08-18-2013)
Search this Thread:
Advanced Search
GRMN Gazoo Twin Charged 86 Concept (320hp) Revealed! KyShro Scion FR-S / Toyota 86 GT86 General Forum 151 01-04-2016 04:10 PM
Gazoo GRMN Sports FR Concept Twin Charged 325HP Teased Ahead of 2013 Tokyo Auto Salon vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 168 03-07-2014 09:37 AM
FA20CLUB Innovate Twin Screw Combo Now On Sale FA20Club.com Forced Induction 107 11-25-2013 11:48 AM
Twin Charged HKS set up! Evasive Motorsports Forced Induction 35 05-24-2013 06:54 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 10:14 PM
