Old 07-26-2013, 10:27 AM   #15
s2d4
s2d4's Avatar
Originally Posted by ft_sjo View Post
Mass flow is mass flow.
So what happens when a high pressure, cooled mass of air hits another compressor?
Old 07-26-2013, 10:29 AM   #16
s2d4
s2d4's Avatar
Originally Posted by regal View Post
221Hp for >$10k
Fueling would be the limiting factor here.
Engine internal is another but could be negated via higher octane fuel source.
You are also not looking at outright HP in shoot out mode for a twincharge setup on a stock engine.
The largest benefit would be area under the curve, build for higher torque through out the entire rev range.
Old 07-26-2013, 11:06 AM   #17
ft_sjo
Drives: GT86
It compresses it further. That doesn't change the difference between air mass and air volume. Do you know the difference? If a given object chokes at a given air mass, further compressing the air isn't going to help that.
I'm no expect on fluid dynamics, though, but i'm sure someone can chime in to talk about the friction aspect of it.
Old 07-26-2013, 11:07 AM   #18
nix
nix's Avatar
Drives: AVO BRZ
221Hp for >$10k
It's sponsored by a lot of aussie companies, sprintex/avo etc no idea how much its costs.
nix is offline   Reply With Quote
Old 07-26-2013, 11:11 AM   #19
jamesm
if you're going to do something like that, you'd want to use a lot bigger turbo than that which comes with the avo kit.
The Following User Says Thank You to jamesm For This Useful Post:
Murseman27 (08-18-2013)
Old 07-26-2013, 11:11 AM   #20
nix
nix's Avatar
Drives: AVO BRZ
We have good quality pump here. 98 RON and e85 (~82%). Personally I think with a small turbo, all the effort would have negligible effect but let's wait and see.
Old 07-26-2013, 11:18 AM   #21
regal
Well its going to cost more than an Avo + Sprintex. Basically a $10k+ engine with the performance of a diesel, its a tuner competition for P.R. Nothing wrong with Aussie gearheaded fanatical compeiton but that's all it is.
The fact that they aren't flow matching the two compressors says everything.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-26-2013, 11:31 AM   #22
s2d4
s2d4's Avatar
Yeap, united is pretty good.
Sure the turbo could be much bigger, I would do the same thing though if I was going to fatten the area even further, not otherwise possible with both kits on their own..
Then again, I couldn't careless about peak HP but instead, how the engine makes power everywhere else.
Old 07-26-2013, 11:49 AM   #23
dabocx
dabocx's Avatar
Drives: Scion FRS
Id rather pick one kit
And use the money id spend on the other kit and fabrication and build the motor.
dabocx is offline   Reply With Quote
Old 07-26-2013, 12:15 PM   #24
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Indeed. The AVO turbo is much to small for a twin-charged setup.
FrX is offline   Reply With Quote
Old 07-26-2013, 12:15 PM   #25
s2d4
s2d4's Avatar
Fair enough, you would most likely need a pretty aggressive stroker kit to match the twinscrew. I would rather not deal with messing up the bore vs stroke ratio though.
Old 07-26-2013, 01:39 PM   #26
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I feel like anti lag with a turbo or a bigger posi displacement supercharger(since ours is at its limit apparently) would be a better option. our high comp motors cant really eat the boost #'s that twin charging is good for, its a waste of money to develop a true twin charger system just for a couple more psi. Now if you dropped to some low compression pistons and pushed 10 out of the super and 20+ out of the turbo itd be a reasonable investment....but thats just my opinion.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
nix (07-28-2013)
Old 07-27-2013, 05:15 AM   #27
Aaron_blatherwick
I got the idea from working on the newer twin turbo diesel truck engines and the older 8v92 2 stroke 8v twin charged engines.
Here's an article I found
http://www.autozine.org/technical_sc...duction_5.html
Aaron_blatherwick is offline   Reply With Quote
Old 07-27-2013, 08:22 AM   #28
s2d4
s2d4's Avatar
Look up 4agzte, hks also had a twin charge kit 20 years ago.
I also have a 4agze in the AW11 and have been looking at trying this too.
Search this Thread:
Advanced Search
GRMN Gazoo Twin Charged 86 Concept (320hp) Revealed! KyShro Scion FR-S / Toyota 86 GT86 General Forum 151 01-04-2016 04:10 PM
Gazoo GRMN Sports FR Concept Twin Charged 325HP Teased Ahead of 2013 Tokyo Auto Salon vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 168 03-07-2014 09:37 AM
FA20CLUB Innovate Twin Screw Combo Now On Sale FA20Club.com Forced Induction 107 11-25-2013 11:48 AM
Twin Charged HKS set up! Evasive Motorsports Forced Induction 35 05-24-2013 06:54 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 10:14 PM
