Old 05-07-2018, 08:45 PM   #183
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Finally took the plunge. Lots of work but worth it. Thanks @BRZen for the inspiration!
BirdTRD is offline   Reply With Quote
The Following 9 Users Say Thank You to BirdTRD For This Useful Post:
Brink (05-07-2018), derekbrz24 (05-09-2018), Drambeenie (05-07-2018), ERA (05-14-2018), Kimsey47 (05-17-2018), lbrixey (05-16-2018), pgranberg11 (05-14-2018), slacker221 (05-11-2018), Tristor (05-09-2018), xkalelx (07-23-2018)
Old 05-07-2018, 08:50 PM   #184
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
@tehShirt this doesn’t look too bad
Drambeenie is offline   Reply With Quote
Old 05-07-2018, 08:58 PM   #185
Brink
Drives: 2017 BRZ
Another mesh grille joins the club!
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
BirdTRD (05-09-2018)
Old 05-09-2018, 05:41 AM   #186
BRZen
Looks great against the silver!
BRZen is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZen For This Useful Post:
BirdTRD (05-09-2018), Tristor (05-09-2018)
Old 05-09-2018, 09:25 AM   #187
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I agree, they did a good job. Would be interesting to see someone keep the mustache, but replace the horizontal bars with the honeycomb.
tehShirt is offline   Reply With Quote
Old 05-09-2018, 09:46 AM   #188
Drambeenie
Drambeenie's Avatar
For sure. I'd like to keep the foam crash protection.
The Following User Says Thank You to Drambeenie For This Useful Post:
rvoll (05-12-2018)
Old 05-11-2018, 06:24 PM   #189
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Here's some more angles of the grill after I installed the plate re-locator. Something to keep in mind as you're lining up the grill to minimize the amount you have to cut away to install the post. I got lucky, only 1 horizontal needed to be removed.
Old 05-13-2018, 09:58 PM   #190
brehio
brehio's Avatar
Drives: 2014 Subaru BRZ
Anyone willing to post a link to where they bought the mesh? Looks so so much better than stock imo. Seems like a cheap mod that really changes the look of the car. Both you guys said huge time consumer, but can it be done in one day? Also, what did you guys use to glue it to the bumper and how is it holding up on the roads?
Thanks
Austin Brehio Racing
My build thread
brehio is offline   Reply With Quote
Old 05-14-2018, 01:56 AM   #191
Brink
Drives: 2017 BRZ
Thanks
I got this mesh (16x48 black version):
https://www.customcargrills.com/prod...rod=Brick-Mesh
Looks like the other guys doing this got mesh in a different pattern, they're more of a honeycomb shape. Since mine is a '17 BRZ the front bumper is a bit different so there was no glue involved - I can't speak to what glue to use or how long that part of it takes. One thing to keep in mind though is you will most likely want to do something with the crash beam - paint, plasti-dip, something like that. It's ugly otherwise. Got my mesh grille done without doing anything to the crash beam at first and was happy with it for a bit before I got tired of looking at it and had the bumper taken off again to plasti-dip the crash beam. Here's a pic of a crash beam in stock form, before painting it. BirdTRD's post has a nice picture of the after, so you can see the mesh grille with a nice black crash beam like you'll probably want to go for.
The Following 2 Users Say Thank You to Brink For This Useful Post:
brehio (05-14-2018), Drambeenie (07-24-2018)
Old 05-14-2018, 09:13 AM   #192
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Thanks
For the mesh I used https://www.ebay.com/itm/152828435566 the material itself is 1/4" thick. The "honeycomb" openings are 1-1/4" across and 1/2" high, which looks to be a bit larger than the one @BRZen used.
For the adhesive I used JB Kwik and you'll used most...if not all of the 10 oz size. https://www.amazon.com/J-B-Weld-8270...=jb+kwik+10+oz
I'll put some tips and lessons learned up in a bit.
The Following User Says Thank You to BirdTRD For This Useful Post:
brehio (05-14-2018)
Old 05-14-2018, 10:20 AM   #193
JoeC
Drives: Subaru BRZ Limited
why did did you plastidip the crash beam? isn't it just going to start peeling before too long?
Also, why are there all those tabs around the edge visible still?
JoeC is offline   Reply With Quote
Old 05-14-2018, 11:32 AM   #194
Brink
Drives: 2017 BRZ
Thought the plastidip would hold up better than paint against rock chips etc from road debris. It's just a thin coat so hopefully doesn't start to peel too quickly. The tabs are visible because that's actually what my mesh is attached to, it's not glued in like the others you've seen on here. The '17 bumper has the stock grille attached to those tabs and the grille just pops out so the mesh was basically just tied onto the tabs. Earlier model year BRZs wouldn't have had those tabs to begin with.
Old 05-14-2018, 11:46 AM   #195
JoeC
It's a paint that's marketed as easy to remove, I wouldn't expect too much.
I understand now. thanks for the clarification. I think I'd either paint the tabs black or trim them off entirely.
Old 05-14-2018, 01:16 PM   #196
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
this is interesting, i think i may have to do this to my brz now... My crash bar got replaced by a JDL bar and I do have a big fat intercooler.... so this may be a win win. lol
pgranberg11 is offline   Reply With Quote
Search this Thread:
Advanced Search
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 04:23 AM
Subaru BRZ Front End...is...ugly? hybrid4g BRZ First-Gen (2012+) -- General Topics 65 02-04-2012 12:33 PM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 03:08 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 06:26 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 03:24 AM
