Old 09-14-2014, 04:42 PM   #379
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Stock Exhaust
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 09-14-2014, 04:44 PM   #380
tonystewart
I will fix it when the car returns home in November, unless it comes home before
Old 09-14-2014, 07:58 PM   #381
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Sounds like it needs to be adjusted. I'm lowered about 1.5-2" and running the V1 (at nearly its lowest mounting point) and don't scrape.
Parting out HERE
civicdrivr is offline
Old 09-14-2014, 09:00 PM   #382
tonystewart
You are correct, I am not blaming the diffuser, I just never tested (speed bumps) before sending her back to college with it. I will address the mounting height.
The Following User Says Thank You to tonystewart For This Useful Post:
civicdrivr (09-14-2014)
Old 09-16-2014, 06:34 PM   #383
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Let me know when you get hands on the car, I'd like to know where it's scraping maybe I can offer a solution.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline
Old 09-16-2014, 08:25 PM   #384
s0sl0w
Proud of Boxer
@Wonderbar do you mind if I share my modified mounting here?
s0sl0w is offline
The Following User Says Thank You to s0sl0w For This Useful Post:
Wonderbar (09-17-2014)
Old 09-16-2014, 08:58 PM   #385
tonystewart
The two center fins.
The stock exhaust doesn't go through the cutout hole in the diffuser, the diffuser is as high as I could mount it (the two holes at the sway bar mounts) without touching the exhaust pipe.
I assume I will have to cut a slot, slightly wider than the exhaust pipe, to allow the diffuser to clear and be mounted higher.
That will be 66 days from now, at the earliest.
Old 09-16-2014, 10:12 PM   #386
Gunman
Drives: 2019 Mazda Miata RF
I have an altered mounting scheme too, and the OEM exhaust is touching the diffuser (Type 2). Right now I'm letting it deflect the diffuser, with some high temp thermal barrier padding between exhaust and diffuser. It's pushing it down 1/4" or so, but the OEM exhaust will be leaving, hopefully soon.
I'm only dropped 1", and have not had any issues, but again, this is a Type 2 with the traditional style strakes.
Gunman is offline
Old 09-17-2014, 08:58 AM   #387
Wonderbar
Driveway labs.
Wonderbar's Avatar
Go for it! I encourage further modding to make things fit your specific needs.
I do it with nearly every part I get for my car.
The Following User Says Thank You to Wonderbar For This Useful Post:
Gunman (09-17-2014)
Old 09-17-2014, 12:35 PM   #388
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Originally Posted by FT-86 SpeedFactory View Post
Driveway Labs is pleased to announce the release of their rear diffuser for the Scion FR-S, Subaru BRZ, and Toyota GT-86. Unlike other diffusers on the market this is a functioning aerodynamic item.
Specs:
5052 Series Aluminum
.050 Thickness
Machine Laser Cut
Machine formed bends
Two different mounting height options
All install hardware is included
Hand Built and assembled here in the USA.
Super simple install that anyone can do in their Driveway.
Confirmed Exhaust Fitment:
Stock Exhaust
FT-86 SpeedFactory V1
FT-86 SpeedFactory V2
Invidia N1
Perrin 2.5"
Perrin 3"
Nameless
More details coming soon...
Black available as well.)
Hi! Will any of your guys' driveway labs diffusers work with a tomei type 80?
'14 Firestorm FRS Build Thread:
http://www.ft86club.com/forums/showthread.php?t=71248
WallsAndFoundations is offline
Old 09-17-2014, 09:01 PM   #389
Wonderbar
Driveway labs.
Wonderbar's Avatar
It will with modification to the diffuser.
I am working on picking up a type 80 to build a specific fitment for it.
Old 09-21-2014, 02:48 AM   #390
jester04
Drives: Subaru impreza STI, subaru BRZ
I just got my type 80 from ft86speedfactory, so hopefully you will be able to make a diffuser for the type 80 lol. Will be saving up starting now!
jester04 is offline
Old 09-21-2014, 09:13 AM   #391
Wonderbar
Driveway labs.
Wonderbar's Avatar
Have it shipped to me first, then I'll send it down along with your diffuser. Hahahaha
Old 09-21-2014, 11:39 AM   #392
tonystewart
That is a great idea, guaranteed fitment
activate more mpg, diffuser, downforce, functional, rear diffuser
Search this Thread:
Advanced Search
BRZ Rear Diffuser Kimsey47 BRZ First-Gen (2012+) -- General Topics 72 06-06-2015 02:41 AM
New Rear Diffuser garfull Exterior Parts (Aero, Lighting, Etc.) 1 07-19-2013 01:13 AM
rear diffuser.. jonperezinsd BRZ First-Gen (2012+) -- General Topics 10 07-02-2013 09:13 AM
FR-S/BRZ Rear Diffuser JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 15 02-25-2013 01:08 PM
WTB: BRZ rear diffuser FR-Shadow Exterior Parts (Aero, Lighting, Etc.) 6 01-18-2013 12:52 PM
