86WORX
Old 10-26-2014, 08:48 AM   #1177
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yea the permatex I have is a liquid teflon sealant....should be ok to use I suppose
Been reading up lots on the installation as I plan to tackle this myself, so I'm sure I'll have a lot more question coming
Fizz is offline   Reply With Quote
Old 10-26-2014, 09:57 AM   #1178
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@gdrider77 how has your avo kit been holding up since dealing with the leaks issues you had last year? I believe you and @Sportsguy83 used thread sealant?
When I get around to install mine, I'd sort these potential issues when everything is still off the car.
As for the coolant hoses, would fuel injector clamps be better than the worm gear clamps they supply?
Old 10-26-2014, 12:01 PM   #1179
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I used thread sealant on the NPT threads of the kit.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
@Art_Mighty (10-27-2014), Fizz (10-26-2014)
Old 10-27-2014, 06:51 AM   #1180
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
...I was also wondering about this
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-27-2014, 08:24 AM   #1181
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by protpibe View Post
I think you're confusing an electronic boost controller (EBC) with overboost protection. Standard overboost protection with ECUTEK is a fuel cut and doesn't have anything to do with a boost controller. Or maybe I just misunderstood what you said in your post. Either way, overboost protection is fuel cut, and i would assume that all ECUTEK turbo tunes would have it
With the basic kit I don't see how either one of these issues can be addressed if the stock sensor only reads to ~5 psi of boost...
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
protpibe (10-27-2014)
Old 10-27-2014, 09:00 AM   #1182
Sportsguy83
Drives: Limited BRZ
Correct, need upgraded MAP sensor for boostcut and EBC to be included in the tune.
Old 10-27-2014, 09:42 AM   #1183
toast
Without an EBC and upgraded sensor (is the stage 1 kit) how is boost controlled, just wastegate spring pressure?
Old 10-27-2014, 10:18 AM   #1184
protpibe
protpibe's Avatar
That's a good point!
Old 10-27-2014, 10:26 AM   #1185
protpibe
protpibe's Avatar
Sorry to sound noob, but may I know why you don't recommend sealant on the oil line fittings? The product description recommends using them on NPT threads
My suggestion was to not use sealant on AN fittings I would for sure recommend it on NPT threads, but not on AN or AN style (flare) fitting.
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Fizz (10-27-2014), Sportsguy83 (10-27-2014)
Old 10-27-2014, 10:50 AM   #1186
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes they would be. If the hose is under pressure and needs a tightened hose clamp, then I would not use a cheap worm gear clamp that can damage the hose.
Old 10-27-2014, 10:56 AM   #1187
Sportsguy83
Drives: Limited BRZ
Yes.
Old 10-27-2014, 11:03 AM   #1188
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok got it. I haven't gotten the kit yet so can't check, but I think the oil lines provided comes assembled ready to use....straight into the NPT fittings.
Old 10-27-2014, 05:41 PM   #1189
TimDing
TimDing's Avatar
Drives: Storm Black Manual 86GTS
Is anyone running the FBM rad and fan set up with the AVO kit? Looking to upgrade the stock rad and tossing up between FBM & Mishimoto and also wondering about clearances.
Cheers.
TimDing is offline   Reply With Quote
Old 10-27-2014, 05:47 PM   #1190
protpibe
protpibe's Avatar
Cheers.
Yup, I'm running their rad, shroud, and fans.
The drivers side of the condenser will contact the intercooler pipe but you can either move the mount holes or live with a rad that sits at a very slight angle.
The Following User Says Thank You to protpibe For This Useful Post:
CxG (12-06-2016)
avo, avoturboworld
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
