#1163 |
Drives: 2014 Limited Subaru BRZ DGM
#1164 | |
Senior Addict
Drives: 86 GT
Also, were the issues people had with failed gaskets,and warped flanges related to the early production kits only? Did anyone who installed the Stg1 more recently have similar issues? The instruction manual doesn't call for checking the torque on the flanges around the turbo, so you'd assume they're torqued correctly at the factory? But if someone were to tighten then up (say pre-install check, or after replacing gaskets) what should the torque values be? |
#1165 | |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
(honestly, I'm not exactly sure how one would go about getting a torque wrench to some of those bolts, so that would be another question?..)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#1166 |
uosɹǝdʎɐl ʇɹǝdxǝ
Radium Catch Cans and AVO
Has anyone tried to install the Radium Catch Can Kit for FR-S/BRZ/GT86 with the AVO setup?
![]() @Astroboy; I think you're running this setup, how do you like it? How often are you draining it out and did you install the petcock drain kit?
#1167 |
Ridge Racerrrrrrrrr
1. Of course you can add a EBC or MBC to this kit. Many people have. I have a MBC right now, will be switching to an EBC come spring. 2. Fewer and fewer of these cases are coming up. Most issues with gaskets are falling into the installation error camp (or using the wrong sized gaskets) 3. Always check the tightness of all of the bolts before installing. That is important. For TQ values, message AVO turbo world on here or on facebook.
| The Following 2 Users Say Thank You to SkAsphalt For This Useful Post: | Draco_PR23 (10-25-2014), Fizz (10-25-2014) |
#1168 | |
Drives: None
Just recently I saw a torn down chevy motor with carbon built up all over its valve springs, cams, chambers, etc. That stuff felt like mud. Blow by ain't no joke! And no I didn't buy the pc kit. I'd get the pc kit for the radium can mounted near the battery though, just to make it easier for you. |
| The Following 2 Users Say Thank You to Astroboy For This Useful Post: | @Art_Mighty (10-25-2014), CxG (01-12-2018) |
#1169 |
Senior Addict
Drives: 86 GT
What other bov's will fit this kit? I've got a spare evo8 MR recirculating diverter valve sitting at home. Will that fit?
#1170 | |
Drives: 2014 Pearl White BRZ
The tuner - Bob at the Drift Office - had already enabled the EBC. Basically - whenever I hit the gas hard - the engine would cut out suddenly at full boost. I described this to him and he guessed what was going on. Quick fix. Anyway - you don 't need to buy anything extra - your tuner should be able to accomplish this with the base map plus tweaks. It might even be built into the basemap for AVO. I think mine was set at 16PSI or something like that. |
#1171 | |
| The Following User Says Thank You to protpibe For This Useful Post: | SkAsphalt (10-25-2014) |
#1172 |
Senior Addict
Drives: 86 GT
Are you guys using thread sealant on all the oil line fittings? If so, what is the recommended product? I've got Permatex high temp liquid thread sealant (rated 400F). Will that work?
Is it also necessary to remove the factory fitted oil fitting, apply sealant, then refit? What about the engine to manifold gaskets? Can I use copper sealant on it even if I use the Grimmspeed gaskets? Or would I be doing more harm than good? |
#1173 | |
Ridge Racerrrrrrrrr
#1174 | |
I would suggest against permatex copper on the actual header gaskets. It's a pain in the ass to get off if you ever have to take the header off in the future. Personal opinion of course
#1175 |
Senior Addict
Drives: 86 GT
#1176 |
Ridge Racerrrrrrrrr
you could use teflon tape? I see it in some of AVO's photos of their fittings
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 05:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
