Old 06-09-2014, 04:24 PM   #827
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Originally Posted by protpibe View Post
Any idea what the stock clutch can handle for torque?
My stock clutch was slipping at peak torque (~4500 rpm) at 6 psi on the stg. 1 kit. So right around 200 ft.lbs, I would guess.
FrX is offline   Reply With Quote
Old 06-09-2014, 04:39 PM   #828
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Yeah stock clutch should go to about 200 tq then start struggling. Exedy stage 1 is handling 255 tq with ease on my car and really isn't that much heavier.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 06-09-2014, 04:50 PM   #829
protpibe
protpibe's Avatar
Just ordered the Exedy Stage 1 actually
How is the chatter at idle?
Old 06-09-2014, 04:57 PM   #830
nataku
Negative Mass
nataku's Avatar
Loud hahaha. But I have a very stiff transmission mounting combo with white line + Perrin.
Old 06-09-2014, 05:03 PM   #831
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Depending on how hard you've driven it, 215#s - 220... That's assuming best case.
Yeah i was surprised how flat it was too. Was thinking maybe my clutch is slipping ? no idea
Bob, its an MT in 4th
You'd see a loop if the clutch was slipping, or an appearance of one at the onset... Looks great! Seems like you might even be able to get more.
Regards!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
protpibe (06-09-2014)
Old 06-09-2014, 05:17 PM   #832
FrX
I have the same exact setup. And yes, the chatter is pretty bad. But the clutch itself is holding up fine, and feels great.
The Following User Says Thank You to FrX For This Useful Post:
nataku (06-09-2014)
Old 06-15-2014, 11:11 AM   #833
Revzyuu
Drives: GBP '15 STI
I really should do my build thread on installing this beast. Have had it almost a month and now I'm up to 10 Psi and its working like champ, best 5k I've ever spent..
Revzyuu is offline   Reply With Quote
Old 06-15-2014, 01:55 PM   #834
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Same. 9-10psi. So good
brz2013 is offline   Reply With Quote
The Following User Says Thank You to brz2013 For This Useful Post:
SkAsphalt (06-15-2014)
Old 06-15-2014, 10:15 PM   #835
Revzyuu
Drives: GBP '15 STI
Even though I'm using stage one I plan to atleast be 11-12 psi by the end and be completely happy without blowing up the car. I'm well near the 300 HP goal
Old 06-16-2014, 01:33 PM   #836
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Hey guys,
just got my AVO Kit installed by chip-racing.ch. It's making about 290 hp and 322 nm (which is about 240 ftlb) on pump gas (AKI 93 / RON 98). It's fitted alongside with a milltek cat-back and overpipe and a motiv concepts catted frontpipe.
chip-racing.ch states, it is producing the power with only 0.3 bar, which is about 4.35 psi. Is this even possible? How should is setup Torque (app) to check the actual boost?
Flasher is offline   Reply With Quote
Old 06-16-2014, 01:35 PM   #837
brz2013
brz2013's Avatar
Originally Posted by Flasher View Post
Hey guys,
No those numbers are not possible on that little boost. Especially if you are meaning power to the wheels. I'm at 290 whp and 230 tq at 10 psi
Old 06-16-2014, 02:03 PM   #838
Flasher
Smartass
Flasher's Avatar
No it's not power on the wheels. It's metric hp, so it's a little bit less than 290 hp.
So how can i measure boost with torque? I added the MAF sensor reading, but it's updateing rather slowly and peaks in >0.40 bar which would be around 6 psi.
Old 06-16-2014, 02:34 PM   #839
onzippy
Drives: 2014 FRS
I think you're looking for the Boost gauge...
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
Flasher (06-16-2014)
Old 06-16-2014, 03:16 PM   #840
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
If you are running the OEM MAP sensor, it only reads up to 4.5~6psi. OEM wasn't designed for boost, so it's only a 1.5 bar unit. MAP sensors read current atmospheric pressure, which is 1 bar at sea level, then what additional air pressure (or vacuum) it has on top of that. So for a boosted car, you need generally a 3 bar unit, which would give you readings from 24-28psi max.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
