Old 03-22-2014, 02:02 AM   #659
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Originally Posted by MFB View Post
Hi Doc,
From the front, the intercooler is barely seen as well due it being stealth black. You really have to look inside to see the fmic. :-)
This is definitely the case - spot my intercooler :
Pitman is offline   Reply With Quote
The Following 3 Users Say Thank You to Pitman For This Useful Post:
Draco_PR23 (03-22-2014), MFB (03-22-2014), SkAsphalt (03-22-2014)
Old 03-22-2014, 02:46 AM   #660
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Hi Doc,
True for most people but if you know what to look for...
Minimal or no cosmetic mods also add to the stealth.
andrewFT86 is offline   Reply With Quote
The Following User Says Thank You to andrewFT86 For This Useful Post:
MFB (03-22-2014)
Old 03-23-2014, 11:43 PM   #661
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Just wanted to stop by once again.
After a full day with @DeliciousTuning yesterday, we where able to get my maps updated along with adding two more on just E85. I will be posting two E85 maps one on my 6psi actuator and one at 13psi with EBC. I am still waiting to receive my other two dyno charts on 91 Wastegate and 9PSI. Car was Dyno'd on a Mustang Dyno so it does not show Corrected value's. Will be taken to BisiMoto so I can use his dyno to get Real Numbers.
My current mods are AVO STG1 Turbo Kit w/ 6PSI Actuator, OEM Injectors, OEM MAP Sensor, DW65C Fuel Pump, ACT 6 Puck HD Clutch. AVO Air Filter, AVO 2.5" Overpipe and Non-Catted Frontpipe, Miltek 2.5" Non-Resonated Exhaust.
As you can see below I ran into Back Pressure in my Exhaust. Gotta play a wee bit with the EBC to get 13psi sooner to have a straight line. Im about 8/10 on my injectors.
(Disclaimer Currently had about E60-E65 in my car at the time of tuning.)
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 4 Users Say Thank You to DesertFrs For This Useful Post:
CxG (03-08-2017), Draco_PR23 (03-23-2014), SkAsphalt (03-24-2014), sw20kosh (03-23-2014)
Old 03-24-2014, 12:29 AM   #662
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
This was definitely one of the most complicated tunes to date that we have done. To give you an idea we set the tune up as follows.
This vehicle (dyno chart above) has 4 switchable maps.
Map #1 is set to wastegate pressure on 91 octane
Map #2 is set to ~10 PSI using an EBC through the ECU.
Map #3 is set to wastegate pressure on E60/E65 octane
Map #4 is set to ~13 PSI using the EBC through the ECU.
To boot the tune was developed as a Flex Fuel package. So when this car moves over to FlexFuel it is as simple as installing the FlexFuel changing a couple parameters in the ECU and now there is a FlexFuel setup built right now.
Yeah this was my brain work out for the day. Along with making it drivable in all conditions for both 91 octane and E85 while maintaining a decent MPG for both 91 and E85.
Definitely a nice challenge.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
DesertFrs (03-24-2014), SilverTipp (04-27-2014), SkAsphalt (03-24-2014)
Old 03-24-2014, 12:40 AM   #663
DesertFrs
DesertFrs's Avatar
Cheers,
William Knose
I'm loving the Tune more and more! Can't wait to add the rest of the items we talked about and get it back to you!
Thanks again!
Old 03-24-2014, 05:27 AM   #664
Bigmaxy
Drives: Pegasus GTS86
Sounds like a great setup. Congrats to @DeliciousTuning and @DesertFrs.
Can I ask why you are still on the OEM Map Sensor?
Bigmaxy is offline   Reply With Quote
The Following User Says Thank You to Bigmaxy For This Useful Post:
Old 03-24-2014, 05:27 AM   #665
JD86
Drives: 2013 Toyota 86 GT
Haven't been on here in a while, and this seems to be a bit of a hot topic... But what's the latest in gasket fixes? I've blown the turbo gasket twice now, not the block to header gasket but the gasket between the headers and the turbo. Both times have been at the track pushing hard, but was wondering if anyone else had experienced it or had any recommended fixes. I'm not using an AVO gasket anymore, swapped to a garret gasket after the first failure and still blew a decent hole in that.
JD86 is offline   Reply With Quote
Old 03-24-2014, 06:12 AM   #666
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Is it melting or what ?
You might have very high EGTs that are causing it to disintegrate, but that is just a guess
Sent from my IBrick
Old 03-24-2014, 08:25 AM   #667
DesertFrs
DesertFrs's Avatar
Thank you!
Let me start off by saying Thank you! The reason why I still have the Stock Map Sensor and some other OEM parts that usually get swapped out by other enthusiasts when they go boosted is because I'm testing the max capacity of each oem part along with turbo kit. It wasn't till now that we might have to switch it when we take it back to get another tune with some update parts. I still have to look for a map sensor that I like.
The Following 2 Users Say Thank You to DesertFrs For This Useful Post:
Bigmaxy (03-24-2014), SkAsphalt (03-24-2014)
Old 03-24-2014, 01:18 PM   #668
DeliciousTuning
From tuning Subaru's for many years, the MAF sensor does 99% of all the work in controlling fuel, timing, cams and even boost (load). So with that in mind we use the MAF sensor to control everything (even fail safes).
We could run a larger MAP sensor but just have not found a need to besides getting an actual real boost value for the customer. So we are working on finding a solid solution for this application to cover all basis.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
Bigmaxy (03-24-2014), CxG (03-08-2017), DesertFrs (03-24-2014), SkAsphalt (03-24-2014)
Old 03-25-2014, 05:59 AM   #669
JD86
Sent from my IBrick
Something like that. My exhaust has always been hot, in fact it was so hot it turned my kakimoto titanium exhaust from blue tips to all blue.
It turns out I'd done a little more than a gasket this time. I'd cracked my dump pipe, we think because there was no flex at all in my exhaust system anywhere (AVO dump pipe, custom 3 inch overpipe and high flow catted font pipe finished off with amuse R1 titan 70mm catback). So we're adding a flex joint in front of the high flow and then I'll track it again and see if that makes a difference.
Just noticed that the new AVO 3inch front/overpipe/dump pipe has a flex joint in it already so maybe I'm not the only one who's had issues.
Old 03-25-2014, 07:55 AM   #670
onzippy
Drives: 2014 FRS
I twisted the last wrench on my AVO install Sunday and loaded the last of a few rom files Monday morning. Paul sent me the file on a Sunday night which is just another reason why I wanted to say how happy I am with my purchase from AVO turbo world and how great the support was. Kudo's Paul.. everyone else, go get this kit!
onzippy is offline   Reply With Quote
Old 03-25-2014, 08:05 AM   #671
SmsAlSuwaidi
Boosted
May i ask who is tuning your car ?
Sent from my IBrick
Old 03-26-2014, 03:01 AM   #672
JD86
Sent from my IBrick
A local tuner called Tokyo Motorsports has done my custom tune... But I'm not going to recommend them or bag them out as my opinions on their tune are a bit love hate. It's a good tune for power and fun but has some holes.
I've been investigating other tuners so make of that what you will.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
