Old 02-09-2016, 09:13 AM   #1737
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by GsxrMe View Post
Are you heat wrapped or coated headers and over pipe?
None
Astroboy is offline   Reply With Quote
Old 02-11-2016, 11:38 PM   #1738
luckykevin
luckykevin's Avatar
Drives: 2013 Subaru BRZ Automatic
where can i buy the turbo kit in China?
Hey guys, I'm in China, there is no AVO resaler in China, where can i buy the turbo kit? Thanks
Subaru BRZ Automatic, World Rally Blue , Innovate Supercharger, AVO Stage 1 Turbo kit, 4.556 FinalDrive, STI Big Break, DeliciousTuning
luckykevin is offline   Reply With Quote
Old 03-06-2016, 12:33 PM   #1739
Kckc1
Drives: White brz series blue
Just installed my turbo last night and I ran into some problems I was wondering if you could help with, there is oil leaking out into my intake side and it's going into the manifold and engine, is this due to a bad seal on the turbo causing it to leak? Oil seems to be leaking out and causing smoke around the turbo. Or is it possible the oil pump is not working correctly and is causing positive pressure in the system, sending oil out through the exhaust and up the oil breather line that's connected to the pcv and into the intake?
Kckc1 is offline   Reply With Quote
Old 03-06-2016, 12:38 PM   #1740
protpibe
protpibe's Avatar
Like it's leaking into the turbo and being pushed into the engine? There are no external leaks?
Old 03-07-2016, 12:20 PM   #1741
Kckc1
Yes, oil goes into the turbo, then into the resiviour and from there the mechanical pump seems to not be working so the oil goes up into my PCV and then manifold because I teed into that line.
Old 03-09-2016, 10:22 AM   #1742
luckykevin
luckykevin's Avatar
I am AVO kit owner now.
The Following 2 Users Say Thank You to luckykevin For This Useful Post:
Draco_PR23 (03-09-2016), MisterSheep (03-09-2016)
Old 03-15-2016, 02:52 PM   #1743
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Originally Posted by Astroboy View Post
I can upload a video tomorrow I
When I take it to work. I'll upload it around 9am. I torqued it to spec. I did try to resurface the oem flywheel with a dermal type machine that is used for sanding and such... I don't know if the sound is normal or if I really did fuck up.. 😔
Sent from my LG-D850 using Tapatalk
You described what it sounded like when my flywheel bolts backed out after doing a clutch and flywheel job on my old RSX. I torqued to spec the first time upon reassembly and 15 over spec the second time after the bolts backed out. Never backed out again even though I knew I was risking stretching them.
Did you ever find the culprit?
Any news on this? Good or bad?
Sold the BRZ and bought a miata O_o
KevinK121 is offline   Reply With Quote
Old 03-15-2016, 03:12 PM   #1744
Astroboy
Astroboy's Avatar
Drives: None
I was told it was just the clutch disk springs rattling. So I'm going with that. Makes sense
Old 04-01-2016, 03:05 AM   #1745
steve86gt
Drives: 2014 Toyota gt86 avo stg 2 e85
Hey everyone, i can say im a proud owner of a F/I Toyota 86 just had my stage 2 avo kit installed .. very happy with it !
I have been searching how to make the avo kit flutter but i cant find anything.
does anyone have any suggestions?
Thanks guys
steve86gt is offline   Reply With Quote
Old 04-01-2016, 11:00 AM   #1746
M1K3
M1K3's Avatar
Drives: vrooom...
AVO Stage 5 Ball Bearing Turbo:
Link to Fensport Post on FB: https://www.facebook.com/media/set/?...2933872&type=3
M1K3 is offline   Reply With Quote
Old 04-01-2016, 11:01 AM   #1747
qtwre
Drives: White FR-S
There's a stage 5 now? I guess you can never have too many stages.
Sent from my Nexus 6P using Tapatalk
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
nickmerronesucks (05-13-2016)
Old 04-01-2016, 11:15 AM   #1748
KevinK121
Miata traitor
KevinK121's Avatar
Funny thing, I started getting the whirring "horn" noise recently as well. Im part of the club now!!
I didnt know this club existed and I dont necessarily want to be a part of it but here we are.... No confirmed problem or solution for it that I've seen. Just deal with it and a lot of times it goes away I guess.
Or "NOW" albums?
(real album... they are in fact, on NOW 93)
The Following User Says Thank You to KevinK121 For This Useful Post:
Old 04-01-2016, 12:02 PM   #1749
ChrisD
ChrisD's Avatar
Drives: GT86
Thanks guys
The flutter is actually a bad thing (even though I love the sound of it). It means air is going back the wrong way into your turbo and slowing it down or at worst causing it to stall completely. Presumably your system came with a blow off valve which eliminates this by dumping the pressure to atmosphere (when it does this you hear a short hissing sound when you let off the gas after flooring it for a while) or recirculating it back round through the intake pipes and turbo. The avo blow off valve has the option of being set to 50/50, so it recircs some of the air and dumps some to atmosphere.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 04-01-2016, 12:03 PM   #1750
ChrisD
ChrisD's Avatar
Drives: GT86
Yeah Adrian at Fensport is currently fitting the stage 5 to his car and should be racing it in the sprint series in a couple of days. Interested to hear what he thinks of it compared to the stage 4.
avo, avoturboworld
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
