#1345 |
Drives: 13 Asphalt FRS AT
Anyone happen to have pics of prodrive boost controller install? I had mine installed by a local shop but am not seeing any boost increase via selectable maps. I should be seeing wastegate on map 1, 8 on map 2, 9-10 on map 3, 10-11 on map 4. I am seeing 7 psi regardless of map selection. Harness is wired to prodrive so not sure where there issue is.
Sent from my Nexus 7 using Tapatalk
#1346 |
Drives: WRB BRZ
Did u get a tune for maps? Ebc doesn't work itself, it has to be ecu tuned for each maps.
#1347 |
Drives: WRB BRZ
Any one has got an air intake temp problem with this kit? I had to trim airfilter pipe shorter due to HID headlights (BRZ) and my AIT is a big problem, close to 180f° in traffic.
I'm going to reroute the airfilter to the space where the windscreen washer bottle is located. |
#1348 | |
#1349 | |
#1350 |
I wrapped my intake tube and sensor with gold heat resistant tape and it really helped drop the IAT's in traffic.
I think putting the gold tape on the top halves of the intake runners would also help keep the heat down on the intake manifold too. |
#1351 |
Hella Flush
Drives: 2013 SWP BRZ
What radiator and fans you guys running?
#1352 |
Still running stock
#1353 |
Hella Flush
Yeah summer is coming up def want to do the radiator and oil cooler upgrade
#1354 |
Drives: Pile of junk
Throw the kit in the trash
#1355 |
I had my header and downpipe ceramic coated and will be rewrapping them in a few weeks. Ceramic alone won't do it. I need to get this boost control fixed first though. Did some searching last night and it doesn't look like it is plumbed correctly. The harness is facing towards the front of their car in the video below.
Turbo frs boost controller: [ame]http://youtu.be/AOrQlo1pZ5o[/ame] Sent from my Nexus 7 using Tapatalk
#1356 |
Can't afford it and gotta make the best out of a bad situation.
#1357 |
Drives: WRB BRZ
My header and down pipe are not ceramic coated but wrapped and my intake charge pipe is wrapped with gold heat reflective tape too. gold tape is definitely helping but not enough.
I got a Koyo rad and Laminova oil cooler from fa20club too and they are working very well. |
| The Following User Says Thank You to Justkiz For This Useful Post: | Ny Brz (04-28-2014) |
#1358 |
Drives: FRS
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20CLUB TURBO KIT T3/T4 60 | 86pro | Forced Induction | 50 | 07-26-2014 12:48 PM |
| Fa20club turbo install issues | Mikegraves777 | Forced Induction | 8 | 07-25-2013 01:56 AM |
| FA20CLUB 60 Trim Turbo 16 PSI Results Are In | FA20Club.com | Forced Induction | 148 | 07-22-2013 09:00 PM |
| FA20CLUB V2 Turbo Kit Progress | FA20Club.com | Forced Induction | 40 | 05-17-2013 02:26 PM |
