#113 | |
Drives: 2013 Brz C38 (bought not built :P)
I'm well aware not all fi are the same I just failed to understand how you had so little gain, 7psi explains it.
| The Following User Says Thank You to fumanchu1 For This Useful Post: | DustinS (03-22-2016) |
#114 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
wow i hope mine puts this down.
797Performance.com
| The Following User Says Thank You to nickmerronesucks For This Useful Post: | DustinS (03-22-2016) |
#115 |
Drives: Velocity Orange 86 GT
Thane/Northwest86
Coyoda Turbo Preproduction running a GTX3067R w/ Stainless manifolds unfortunately but it does the job. 95 RON or 90/91 In Imperial 8Psi Q300 with 2.5" Front (catted) and overpipe. Clutch, Synapse BOV, Plex PBC and other supporting mods for the track. - Other Notes/Conditions, Tuner, etc. (include link to other thread where people can go comment/ask questions if desired) Tuned by Coyote. This is on a dyno that posts 105kw for a stock car but numbers don't mean Jack really. The same dyno on the same tune has read 10-15kw different from a number of small things. It gives a good idea of the delivery though. For a rough estimate compared to most dynos you'll see in America add 10-25% to the numbers.
#116 |
Drives: 2013 FR-S M/T Ultramarine
Jackson Racing C38
Delicious tune/ 91 oct OFH, Invidia OP/N1, Spencer Fab HFC Front pipe 240whp/182tq Side note on this dyno, it was the baseline tune and I have since had a handful of revisions, and will dyno again with the finalized one. Also I'm at high elevation so only seeing 7.5psi at red line, opposed to the 9.5 you would see at sea level.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
#117 |
Drives: 2016 BRZ Hyper Blue
Jeff/jmh128
Edelbrock SC Delicious tune 93 Octane Fuel 12 psi Boost 225 A/S tires Everything else is stock Last edited by jmh128; 03-29-2016 at 08:46 PM. Reason: more info |
#118 | |
Drives: 13' Subaru BRZ Limited SWP 6MT
Thanks for sharing. Prior to the Edlebrock SC, I was set on a turbo. But with your performance, the simplified maintenance and operation of a SC, and the great appearance of the package, it's hard to argue against anything else in the ~300whp category. Btw, it looks like you'd get quite a bit more HP (300whp) with a 3" exhaust, if your TQ didn't drop off due to flow constraints.
| The Following User Says Thank You to mwjcyber For This Useful Post: | jmh128 (03-30-2016) |
#119 |
Fast enough
Drives: 2013 Subaru BRZ AT
Before: Moto-East e-tune
![]() After: DBW motorsports dyno-tune ![]() Relevant Mods: Automatic trans (According to Doug @ DBW, they run about 8-10% less on his dyno than a manual) Jackson Racing supercharger High boost pulley Flex fuel with E72 in the tank Full catless exhaust This is hitting 12 psi at the very top with the high boost pulley. |
#120 |
Drives: 2013 Whiteout FR-S
| The Following User Says Thank You to kanundrum For This Useful Post: | Mrc@ptuning (05-17-2016) |
#121 |
Drives: 2014 BRZ Limited [6MT/SWP]
- Josh / Jhood
- Full Blown Stage 1 Turbo Kit - GTX2867R - E85 by Moto-East Flex Fuel Kit - 9psi - Perrin 2.5" Catback - Dyno tuned at Moto-East (At max power output on E85 due to stock clutch) - Build thread in sig below 7psi on 93 = 257whp/205tq 9psi on E65 = 302whp/234tq
#122 |
Drives: 2013 Turbo FR-S Java Pearl
Gabe / Frs909
- Full blown motorsports kit - E85 ptuning kit - 8 psi - tomei overpipe, blitz front pipe, perrin exhaust - dyno tuned at church dyno tuning 93 - 303WHP e85 - 368WHP |
| The Following User Says Thank You to Frs909 For This Useful Post: | ShoGun (02-06-2017) |
#123 |
Drives: BRZ Limited
[QUOTE=nelsmar;1331234]I didn't realize this existed!
Nelsmar Kit: Vortech Supercharger w/ upgraded 3.125" pulley Fuel: Flex, dyno on E80-E85 Boost: 11.5PSI @ 1,100FT Fuel upgrades were done, everything else was stock. I took the muffler & OEM intake snorekel off out of curiosity a few days before. Tuned by FA20club on the dyno (flew him in to do it). Hood open was 360WHP, hood closed was 357 with slightly warmer engine temps. Nearly identical between Wow so you hit 357 with a catted exhaust? That's awesome. How many miles have you put on the car? Still running strong? I am about to make the jump to e85 with a similar setup you have. Pretty stoked after seeing this |
#124 |
SBD turbo kit
Invidia over pipe Invidia catted down pipe Stock exhaust OFT tuner 10.5 psi 93 oct
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
#125 | |
Since the last post, I dug a little deeper in the ol pockets and installed a new Exedy Stage 1 clutch, finished 2.5" full exhaust, and went back to Moto-East with E81 instead of E62 to hit the dyno one last time (I say that for now lol) Don't think I'm gonna get much more out of it safely. *Updated - Full Blown Stage 1 Turbo Kit - GTX2867R - E85 & 93 with Moto-East Flex Fuel Kit - 11psi - FBM 3" Downpipe, Motiv 2.5" Overpipe, Motiv 2.5" Frontpipe (200 cell HFC), & Perrin 2.5" Resonated Catback - Dyno tuned by Moto-East 7psi on 93 = 257whp/205wtq 9psi on E62 = 302whp/234wtq 11psi on E81 = 340whp/255wtq (+38hp/+21tq)
#126 |
Drives: 2023 GR86 - Track BRed Premium 6M
- Greg / TRACE_on
- GReddy T620Z Tuner Kit - 93 octane - 10 psi - Omni 3 Bar MAP Sensor - Tial Sport Q 50mm Blow-off-valve - Stock Injectors - Stock Fuel Pump - Motiv Concepts Over Pipe 2.5" - Motiv Concepts Test Pipe 2.5" - GReddy Supreme SP Catback 2.5" - ACT HD Performance Street Clutch - ACT Prolite Flywheel - 306hp / 245tq - tuned by Hal @ Dynosty (https://www.facebook.com/Dynosty/vid...0060979342634/)
STR also-ran
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 11:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
