#29 |
Drives: 2017 Camaro 1SS
#30 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yes, because you can always add power. It just depends on what your power goals are though. I can't speak as to which platform would be better for making big numbers, but the 370 is a larger, higher displacement engine. You don't seem to want crazy horsepower numbers though, judging by this not being a muscle car forum at all, so I would think a lightly boosted FR-S would be perfect for you.
#31 | |
Also: What's the advantage of using the crawford performance short block? Is anything gained from it alone? Or is it meant to be used with turbo/sc? |
#32 | |
Drives: Passat
I believe that the differences between the AA80 and 960E extend far beyond the missing 2 gears. However I would trust the A960E to handle 250whp without any problems. |
#33 | |
Drives: 2013 DGM BRZ Limited
Good luck with your choice (Just get the FRS lol)
#34 |
Drives: Silver AT Limited
I love my auto. I autox it, tracked it, and use it to drive on horrible 405 traffic in Seattle. Works for me! Just my 2 cents
#35 |
#36 |
I've said this 8 billion times in other threads, but I also drive in traffic to go to work daily, and by god I'd go crazy if I still drove a manual. It makes the 6AT that much sweeter for me.
| The Following User Says Thank You to Symmetrical For This Useful Post: | mechaghost (07-22-2013) |
#37 | |
Weight Nazi
Whatever you enjoyed from the test drive was only what you can experience in a test drive. Imagine what you'll be able to experience when you can sling it around all you want. You may totally forget about power. Or maybe you're a total d!Šk of a test driver and already found out everything about what is essentially someone else's car. In which case, you're well beyond my experience as I've only had two put-putting test drives.
| The Following User Says Thank You to Anthony For This Useful Post: | Symmetrical (07-22-2013) |
#38 | |
Drives: Passat
If you can afford to blow the engine, pay for the rental car while your car is being repaired, and all of the repair and associated costs without it being a financial hardship on you or your family, then and only then is it worth considering. An extra $5000 laying around should cover most of it. |
#39 | |
#40 | |
Member of the year - 2016
Drives: Scion FRS
I'm not saying it's as simple as just taking out 2 gears and calling it a day. But then again we have this... Lexus IS 250-sourced A960E 6-speed automatic with upgrades such as earlier torque converter lockup, faster upshift and downshift times and throttle blips accompanying downshifts was spot-on. http://kaizenfactor.wordpress.com/20...n-or-is-scion/ If that info is true, then perhaps the automatic can take 400HP.
#41 |
Drives: Firestorm FR-S AT
Buy the car you want, you are the one that has to drive it and pay for it. With that said, I love my FR-S and am glad that I went this route. I see those other cars on the road and while they might have more power, I still think mine looks better.
I have considered FI for my automatic and I even like the FA20club kit, low enough PSI to be reliable and enough to produce fun amounts of power however I decided to skip it for the time being. There is so much else that can be done with my car and it is my only vehicle. If I had another car then a turbo would probably be dropped in. All comes down to what is your situation and how ok are you if something goes wrong? In my case, I would be screwed and have no car. So no there is nothing wrong with a turbo or S/C on the automatic and if that is what you want go for it. |
#42 |
Well guys I'm gonna do it. Either red or dark grey. Thanks for all of your input. Will probably be buying it this week.
| Do you think FT-86 will have automatic? | TRD | Engine, Exhaust, Transmission | 217 | 08-03-2013 10:36 AM |
| break-in for the automatic brz/frs | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 03-08-2013 01:52 PM |
| Red Automatic FRS available | BRZ88 | NY / NJ / CT / PA | 0 | 06-01-2012 01:04 PM |
| My Car is here DGM Limited Automatic | SgtBolt | BRZ First-Gen (2012+) -- General Topics | 2 | 05-28-2012 06:03 PM |
| Anyone Else Considering an Automatic FR-S? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 410 | 02-16-2012 01:41 PM |
