86WORX
Old 07-24-2013, 10:08 PM   #43
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
OK so if I'm at -1.6 degree with 1/16 toe in per side for the street. Going to -2.6 at the track will net almost zero toe. Have to try this and see if I can get a good measurement off the rim without putting it on the alignment rack. Thx
Originally Posted by Element Tuning View Post
I get more toe out with more negative camber on the FRS.
garfull is offline   Reply With Quote
The Following User Says Thank You to garfull For This Useful Post:
CSG Mike (07-24-2013)
Old 07-25-2013, 12:53 AM   #44
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'm starting to second guess my statement based on my pic here:
Somebody better double check the toe change with camber. I think I'm mixed up with my STi which has tie rods in front of axle and negative camber equals more toe out. The FRS has tie rods in rear so negative camber equals more toe in. My own picture supports that.
Element Tuning is offline   Reply With Quote
Old 07-25-2013, 08:39 AM   #45
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Unless things change dramatically with lower with ride height, we toe out with LESS camber. As you state above, it's due to the tie rod location (behind the strut vs in front of the strut).
celica73 is offline   Reply With Quote
Old 07-25-2013, 10:23 AM   #46
Element Tuning
Yeah and look at my strut top, there is a huge change in toe with camber (1/8th"). Car needs a bump steer kit!
Old 07-25-2013, 06:43 PM   #47
Hags86
Drives: Toyota GTS 86
Thank you to everyone who contributed to this thread - I've found it very useful. Give me some time (6 weeks or so) and I'll report back with some accurate numbers about camber/caster changes.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
Old 07-27-2013, 10:49 AM   #48
autobrz
Drives: Mazda 3
Thanks @FastLane1000 for being thorough and pointing out to me that the part number I provided for the 14mm lower bolt was wrong. I've corrected the original post and will include the correct part # here:
14mm bolt: 81260 SPC EZ Cam XR Camber Bolt Kit
autobrz is offline   Reply With Quote
The Following User Says Thank You to autobrz For This Useful Post:
FastLane1000 (07-27-2013)
Old 07-27-2013, 10:54 AM   #49
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
no problem bro! I appreciate your help and getting me the right part number and more negative camber on the cheap!
FastLane1000 is offline   Reply With Quote
The Following User Says Thank You to FastLane1000 For This Useful Post:
autobrz (07-27-2013)
Old 08-01-2013, 02:05 AM   #50
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
So we know more negative camber = more toe IN (approximately -1.0 degree for 1/16" toe in on each wheel). Do we know how many turns on the stock tie rod it takes to toe one of the wheels in or out 1/16" ????
FReSh is offline   Reply With Quote
Old 09-26-2014, 12:36 AM   #51
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Bump. This. Need to know nao
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
The Following User Says Thank You to forwallblakmail For This Useful Post:
smg1138 (04-08-2020)
Old 04-05-2020, 10:07 PM   #52
Danny318
Drives: 2019 BRZ
Does anyone in 2020 know ?
Danny318 is offline   Reply With Quote
Old 04-06-2020, 09:38 AM   #53
ROADRACER
Drives: unlimited cheap build N/A track car
Im not sure how many turns it takes, but if you sight down the outside edges of the front tires and see how they line up in relation to the rear tires, you can re adjust them after a camber change quite accurately.
ROADRACER is offline   Reply With Quote
Old 04-13-2020, 11:26 AM   #54
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by ultra View Post
I'm running a WAY milder alignment setup than everyone else has posted so far
yet I've had absolutely ZERO issues with my tires rolling over or scrubbing out on the track.
Perfect treadwear after three full sessions - right up to the edges of the tread but nothing on the shoulders. Tires look barely used.
Maybe you're just slow. =)
If you're setting lap records... I'm impressed.
Yep, I can eyeball a fairly accurate alignment.
There's always the old string alignment.
racingfool is offline   Reply With Quote
The Following User Says Thank You to racingfool For This Useful Post:
CSG Mike (04-13-2020)
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
Who's tracking their BRZ? random hero BRZ First-Gen (2012+) -- General Topics 11 08-20-2012 11:30 PM
