| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: WR blue
oh,so where do you hook up the adapter?
#16 | |
#17 |
degrees
Drives: 6MT BRZ
Both Torque and the gauge above use the OBD2 port and pull data from the factory computer. Torque uses an OBD2 to Bluetooth adapter where the gauge uses a cable for both signal and power. Data output should theoretically be identical.
#18 | |
Shorter of breath
Drives: a soft bargain
Umm....huh? Your comparison doesn't make much sense, it's not a question of accuracy. Your analogy is like saying the oil temp sensor only reads from 70F to 250F, and you want one that reads from 0F to 500F. |
#19 | |
All these OBDII sensor readouts that have been popular as of late are just hype, meaning if you want a "light show" (gauges that are barely useful), then by all means waste your money. If you are serious about knowing your engine vitals, then you will not be getting that information from your OBD port. This new trend reminds me of people installing narrowband O2 gauges years ago, thinking that they were actually useful. |
#20 | |
Drives: 2013 Subaru BRZ Limited LR
You don't have any data or evidence showing a difference between odb2 oil temp and an expensive gauge; until you do, don't be so damn rude. Your implication of some kind of 2fast2furious bs is garbage. Even if it was off by 10 degrees F, it would tell us if the oil was warmed up or if something was overheating. |
#21 | |
degrees
Drives: 6MT BRZ
No one here is refuting the potential for inaccuracy in general with OBD2 output but what happens in other platforms is irrelevant. You need to provide data showing that the ECU output and factory sensor outputs in our cars are inaccurate, where they're inaccurate, and by how much. So, please post some hard data from this specific car. Many here would love to see the data. It's an honest question looking for an honest answer. :happy0180: |
#22 | |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
You're comparing apples to oranges here bud. It is very important to have an accurate, quick to respond a/f gauge for obvious reasons. Things like oil/water temp are clearly a different case altogether. If you think you're such an expert that you'll turn your nose up at relatively small discrepancies in measured vs actual oil temp with a small delay then clearly you up your own ass too far to even talk to. Using the OBD port to log max oil/water temps while out on the track is a smart thing to do, OEM or aftermarket. Feel free to spend the several hundred dollars to get a system that meets your needs for accuracy, I'm going to monitor my oil temp for ~$20 and it is plenty accurate. |
| The Following User Says Thank You to Thorpedo For This Useful Post: | xuimod (02-28-2016) |
#23 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Before I installed a Defi DIN-Gauge, I had a Scangauge in my car. I ran both for a day to see what kind of difference there was in their readings. Nothing. If there was any kind of discrepancy between the two gauges it was one or two degrees at most.
#24 |
Drives: WR blue
#25 |
Drives: WR blue
Thx guys,Thx for all the inputs.
#26 | |
degrees
Drives: 6MT BRZ
#27 | |
BTW, I do have a cheap OBDII bluetooth adaptor and torque on my daily driver maxima. To me its basically a fancy version of whats already available on the dash. If you're not worried about accuracy, the OEM gauge cluster is perfect to tell you if the car is overheating. |
#28 |
Shorter of breath
The "damped' gauge you refer to is the coolant temp in most newer cars (circa ~2000 and up, very roughly speaking).
It's not the sender that's 'damped'...the gauge itself has a 'dead zone' around whatever temp is considered 'normal' by the manufacturer, where fluctuations of less than X degrees don't register on the gauge. The sender sends the information (in the form of fluctuating voltage), but the gauge is what flattens the response. Without that, you see the temp climb from a cold start, then drop a bit when the thermostat first opens, then rise, then fall, then rise...on cold days in the winter, the fluctuations can be relatively dramatic. The story goes, for whatever it's worth, manufacturers got tired of explaining how the cooling system works when people brought their cars in for service, thinking it was a problem. All my cars up through about '99 had 'working' temp gauges. All my cars post-'99, except for my Corvette, have the 'damped' gauge where it goes up to steady-state and just hangs there. The Corvette has both a coolant temp gauge, and coolant and oil temp digital readouts, and they move around quite a bit. The only cars I can think of made today that have an actual analog oil temp gauge are Camaros with the console cluster, some BMWs and Porsches, and maybe the Focus ST? I've not ridden in any of them long enough to pay attention to fluctuations on the oil temp gauge. |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 03:57 AM |
| A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 02:19 PM |
| exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 10:06 PM |
| Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 09:25 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 05:29 PM |
