#15 | |
Right Foot Flat
Drives: Asphalt Lucille
The engine will only downshift to prevent stalling. Overall treat it like a manual when it is in manual mode. There were times I downshifted, I meant to upshift. I hear the WOOOOOSSSSSHHH I was like oh damnit hahaha. It was 2nd gear into first gear instead of third gear. I hit 6kish RPM. |
#16 | |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
#17 |
Drives: Subaru BRZ Limited M/T
I agree with @Spartan65. When in manual mode the trany ECU (can't remember correct name) will not let you downshift if it will over rev. Otherwise I have complete controll. It WILL beep at you. And it does downshift for you, but only when coming to a stop.
It will let you hit the rev limiter. I do believe there is a way to defeat the the rev limiter. My Subaru guy did a push button dance, car not running, with the function buttons on the dash. And yes I will get more info. I autocross on a regular basis. And it does accelerate pathetically. Sent from my iPhone using Tapatalk |
#18 | |
Drives: 2013 AT Firestorm FRS
#19 | |
Drives: 2013 DGM BRZ Limited
| The Following User Says Thank You to Symmetrical For This Useful Post: | Spartan65 (07-17-2013) |
#20 | |
#21 | |
#22 | |
#23 |
I personally find sport mode useless for anything other than straight line acceleration.
The problem with downshifting to first is that it (for lack of a better term) engages the clutch for you and it's hard to predict the moment it will. So you go from engine braking to no braking to you braking (or engine braking and you braking against the engine to you braking with virtually no resistance). I've found that downshifting to first above 18 MPH leads to far more predictable stops. |
#24 | |
Drives: Raven Black FR-S
) also if you do, we normally slowly engage the clutch. the reason why it's unpredictable is because the auto is still trying to do an aggressive downshift resulting in that kick you feel.just enjoy the car man, it'll all come naturally to you later |
#25 | |
This wasn't a recommendation or endorsement, I was answering Oburn's later comments about 2 to 1 shifts not happening smoothly. I only use manual mode if I'm doing spirited driving, in that mode I have the engine doing most of the deceleration for me. I'm nearly always in drive mode, though, I believe the transmission chooses what I want to do 99% of the time in normal drive mode. I have activated sport maybe 6 times in the 10k miles I've driven because Drive mode does so well and Sport doesn't do well enough predicting the gear I would choose for myself (but the Sport mode would probably be a thousand times harder to get right than Drive, so I don't fault the engineers for that). |
#26 | |
1st86 Driver!
You are partially correct. It will not shift up, it will just bounce off the rev limiter. I believe the manual does the same. The A/T will downshift if you get into an engine stall state. It's somewhere around 1200RPM I believe. Easy to try, put in manual, shift into third and then stop the car. It will stay into third until the point where a manual would buck and shut off the engine. Instead, the AT downshifts.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Spartan65 (07-18-2013) |
#27 | |
1st86 Driver!
If you could get a full "clutch drop" type launch, I actually think the AT would be faster because it will do 60MPH in second gear (I've done it) while the MT requires a shift to 3rd to hit 60 (or so I'm told).
#28 |
Hmm. Who cares about the speed, I just like the fact paddles make me feel like an F1 driver. Also maybe they will add some sort of launch control in the future, I know Ferrari's and Nissan's launch control holds first or second gear and constantly modulates the brakes for best traction and acceleration then learns the surface once you do it once making it a tenth of a second or two faster the next time you run it on that surface, maybe in the next generation?
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 03:35 AM |
| More MPG in manual mode (AT) | aceangel | BRZ First-Gen (2012+) -- General Topics | 11 | 03-27-2013 02:12 PM |
| AT - Failed to downshift in manual mode | abutterman | Issues | Warranty | Recalls / TSB | 26 | 03-14-2013 10:11 AM |
| AT Manual Mode Easter Egg? | whataboutbob | Engine, Exhaust, Transmission | 2 | 12-14-2012 12:03 PM |
| AT Manual Mode Downshifting | Reprobate | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-23-2012 12:40 PM |
