#85 | |
Drives: 2013 Subaru BR-Z Limited
David, now that Tony has you dialed in...I want a ride!! You're like me, bro..you wear your emotions on your sleeve. It was great to see your excitement as your car built more and more power...customers like you make Tony's job worth it!! Thanks again man!
| The Following User Says Thank You to chadstyle For This Useful Post: | Sportsguy83 (07-16-2013) |
#86 | |
I Love custom Turbo kits
Drives: Limited BRZ
We should meet up again soon!
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | chadstyle (07-16-2013) |
#87 |
Drives: really slow...
Is there a thread somewhere that helps us understand the differences in the radiators? I don't want to monkey up this thread with a OT post but I know I need to upgrade rads before going FI and trying to make the most informed choice as possible.
I've had problems with Koyo rads before in that they simply do not have enough cooling capacity (in my other 2 boosted cars). I also don't think a radiator needs to be thicker than the stock endtanks to be efficient enough to cool FI cars. Hopefully someone can chime in. Is it safe to say the Robi rad or FB does not fit 100% like stock? It sounds like they push the condenser (which is mounted on the rad) forward towards the front of the car a bit. |
#88 | |
Drives: Limited BRZ
Like i said in my previous PM and post in the thread, Robispec version 1 was huge, and there was no way to fit it. He says version two should fit, just modifying the condenser brackets, and I agree it should add enough space (by limit the space between the radiator and the condenser) to fit. IMHO, modifying those condenser brackets to make them shorter should also allow the FBM radiator to fit. To answer your question, none of the aftermarket radiators fit like the stock one. All of them push the condenser towards the front of the car and/or push the fans farther into the engine bay.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | RYU (07-16-2013) |
#89 |
Drives: Attitude
There really isn't a way to fit a bigger radiator in that space without doing one or the other...it's not a magic pocket dimension.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Sportsguy83 (07-16-2013) |
#90 |
Ok, it seems i'll have to go out and commission to have a rad made with 100% OEM Fit but 3x the cooling capacity. We did that with my other car with much success. Unfortunately it seems all the rads available so far need to go bigger to cool these FI motors.
Stay tuned... |
#91 | |
Drives: Limited BRZ
#92 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#93 | |
Good question. There is a lot of science that goes into a proper radiator core design. Metalurgy, tube size, fin density, fin pitch, and expected air pressure drop. Most manufacturers like Koyo use the same fin and tube design for all their rads. They do not optimize them for each car's coolant flow and air flow. That's why most rad companies either go A) bigger core or B) they simply don't work as good at the limits especially at higher rpms on a hot day, in dry air, with a big condenser and FMIC blocking the rad's air flow. Like Koyos where they are basically all mass produced cores. They work very well as stock replacements (usually) but I haven't had much luck with them when pushed to the limits like in a track spec FI car. Been here.. done that. Now just need to put in the work because it appears there's no off-the-shelf solution where the answer is just to go bigger. Bigger isn't always better. Sorry @Sportsguy83 for going OT here. BTW: the first thing I would do is to upgrade the stock fans. The entire cooling system especially the FMIC will benefit from it. |
| The Following User Says Thank You to RYU For This Useful Post: | Pete (07-16-2013) |
#94 | |
Drives: Limited BRZ
I have issues because I have AVO FMIC. If I were N/A, they would fit right in with no problems.
#95 | |
Please let us know if you do find a solution for your setup. Sounds like grinding down/shortening the brackets will be a good solution if you plan to stick with those rads. I'm not sure if I speak for other folks here but i'm very interested in upgrading the radiator just like you did but also want it to fit the first time it's installed. You're doing us all a favor. Thank you!!! |
#96 |
Drives: Limited BRZ
All aftermarket rads need to be bigger and to do so, there is no going around moving the condenser to the front (they all do). Koyo radiator moves the condenser to the front also, but its such a small amount that it fits with AVO IC.
#97 | |
it needs to be denser maybe...yeswell this is all heresay until something is available. let me see what i can do. i've already commissioned the lab to get started on the calcs. if you're saying the oem condenser is inside of the end tanks then I've got no case her. i guess now is a good time to remove my bumper to inspect this. |
| The Following User Says Thank You to RYU For This Useful Post: | Sportsguy83 (07-17-2013) |
#98 | |
Drives: Limited BRZ
I do understand what you are saying. What you are saying is just making the core as thick as the endtanks. And you are correct, none of the current aftermarket radiators offer that, they all are thicker than the stock endtanks.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | RYU (07-17-2013) |
| Sportsguy's LS2 Swapped BRZ | Sportsguy83 | Member's Car Journals | 2969 | 08-20-2018 12:12 PM |
| King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience | King Tut | Forced Induction | 196 | 09-04-2016 10:47 AM |
| FS: NY - Sportsguy Handcrafted Armrest | xxscaxx | Interior Parts (Incl. Lighting) | 43 | 05-04-2013 06:30 PM |
| Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) | F3dzo | Southeast | 46 | 12-06-2012 02:49 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
