86WORX
Old 07-10-2013, 02:59 PM   #29
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by FRSBRZGT86FAN View Post
If you had aftermarket pulleys, say like Tomioka Racing Pulleys, would the amount of power lost from the A/C compressor decrease?
Shouldn't unless they were under driven.
Ranatsu is offline   Reply With Quote
Old 07-10-2013, 11:13 PM   #30
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Yeah, I mean the defrost... I guess that makes sense considering it does remove the humidity from my car... Hmm... I wonder if it is any more or less efficient than running straight A/C? If I run the A/C it gets cold... take it in and get it checked since it is/should be under warranty. If not, track the leak down and get a R-132a refrigerant (assuming that is what the FR-S/BRZ takes). Pretty easy to add to a car.
Surakusa is offline   Reply With Quote
Old 07-13-2013, 05:44 PM   #31
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I started a thread on this at the beginning of the year and everyone, including me, said their a/c blew "hot" air.
Old 07-13-2013, 06:07 PM   #32
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
i have not run my ac.... haha windows down and it turned to the cold side is good enough for me!
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 07-13-2013, 06:09 PM   #33
boredom.is.me
Custom User Title
Me too, but my windows go up once I pass 50mph.
Old 07-13-2013, 06:41 PM   #34
Mango22
Winter is Coming
Drives: GBS BRZ
My AC works like a champ. It blows frosty cold even on the hottest humid day. I usually run it on low setting since it blows so cold that it freezes my arms. I use recycle setting most of time. That might help with the air getting so cold. Works like a freezer.
Mango22 is offline   Reply With Quote
Old 07-14-2013, 01:56 AM   #35
Gen
Drives: Scion FR-S
AC isn't very good. However, I have a koyo radiator, intercooler, and an oil cooler up there, so it the airflow the condenser gets is quite reduced. It works reasonably well, but I wouldn't say great.
Gen is offline   Reply With Quote
Old 07-14-2013, 02:16 AM   #36
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I'd have to I'm not 100% impressed with my ac. Not ice cold but cool enough I guess. Seems like other cars are a bit colder. Next time I'm at the dealer I might bring up the issue. Has anyone actually measured the air temp coming out of the vents. I've done a few ac rebuilds and if I remember correctly 50F is really good goal to shoot for.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 07-14-2013, 02:31 AM   #37
retrosmiths
Drives: Scion FR-S Whiteout
I have 3M Crystalline 70% installed all around. It helped the AC a LOT!! Before, I always switch it to 3, now even 1 is enough. So maybe instead of trying to get the AC to work better, help it do what it's doing now.
Note: Crystalline tint is expensive, but in my experience I've had it for 2 weeks and it already paid for itself. Earlier today, I tracked at Willow Springs and 103F+ sucks, but it's cool in my car, even with AC off.
-Sent from outer space
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-14-2013, 08:51 PM   #38
Stephens
Stephens's Avatar
Drives: 2013 Scion FR-S - MT - Asphalt
I have noticed that mine is not very cool if I am sitting. Once I am moving it's fine. It combats Alabama summer heat which says something about a car's A/C.
To succeed in life, one must go through it with a tenacious fiery spirit of twerk.
Stephens is offline   Reply With Quote
Old 07-15-2013, 12:02 PM   #39
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I found that putting it on the defrost setting for a few minutes then using the front ac vents yeilds much cooler air for longer duration.
supramkivtt2jz is offline   Reply With Quote
Old 07-15-2013, 01:16 PM   #40
radroach
Drives: car
^true that the windscreen defrost blower is great
Why does this car blow hot air when I have the air off?
Old 07-15-2013, 03:29 PM   #41
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Your AC will not be nearly as cold at idle versus moving, and that's been true of almost every car I've owned on R134a. It's simply going to work better when you're at higher RPMs. You can even sit in your car at a stop, rev the engine up to 2k+ RPMs, and feel it get colder.
DoomsdayJesus is offline   Reply With Quote
Old 07-15-2013, 03:40 PM   #42
Chee-Hu
Chee-Hu's Avatar
My AC blows pretty cold. Cold enough to keep me comfortable on 2 bars while it's 108+ outside.
Chee-Hu is offline   Reply With Quote
Search this Thread:
Advanced Search
Mind-blowing features of the next model BRZ Baldoak BRZ First-Gen (2012+) -- General Topics 89 08-28-2013 07:59 PM
Passenger side HID Ballast keep blowing CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 3 04-13-2013 01:13 PM
it to cold Pekingduck Southern California 9 01-05-2013 09:08 AM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 02:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 08:10 AM
