Old 07-16-2013, 10:26 PM   #155
jamesm
Originally Posted by sw20kosh View Post
It was a hot day on a dyno. Temps will be high at the airbox where the sensor is. This motor does not have a sensor in the intake mani so we cannot tell how much the meth is cooling.
I assume your maf/IAT sensor is post intercooler on your kit?
Yeah it has a blow-through maf, and I guess the temp sensor is in the maf.
jamesm is offline
Old 07-16-2013, 10:32 PM   #156
sw20kosh
Drives: 2013 Black FR-S
Yes. That is a big benefit to a blow through maf after the IC.
sw20kosh is offline
Old 07-26-2013, 05:30 PM   #157
swift996
swift996's Avatar
@moto-mike when are you getting the header in and tuned?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 07-26-2013, 10:34 PM   #158
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
good question, ask JDL
Xero-Limit is offline
Old 07-27-2013, 09:33 AM   #159
regal
I saw Edmunds put the innovate on their FRS, really caught my interest. I am at that point with the dealer that keeping this car stock is just not worth the hassel so instead of just buying a header+tune this kit is making sense. I tend to think there is a bit much emphasis on E85 and methanol while the majority of buyers of this kit will be running pump gas and just want enough power gain to not require a clutch, injector, pump etc.
Are you done with the pump gas tune, does the choppiness on the dyno concern you? Any hope left to smooth it out ?
Also have you measured EGT's? With pump gas and no intercooler I would understand quite a bit of timing is pulled and fuel added, should we be concerned about the stock manifold cats. Would you say a cat-free header is mandatory with pump gas?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline
Old 07-27-2013, 12:11 PM   #160
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Added a new thread with some of my install notes here: http://www.ft86club.com/forums/showp...84&postcount=1
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
whataboutbob is offline
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
Raven604 (07-27-2013), TemeCal (07-27-2013)
Old 07-28-2013, 08:42 AM   #161
Xero-Limit
Xero-Limit's Avatar
Definitely not done with the pump gas tune. We're ironing out some of the fueling stuff up top that may be the reason, and the down low issues that others are having as well (slight delay). Most of the way there at this point I think, but need to get a bit more data. Should have it back on the dyno again in the coming weeks if the header gets here.
A cat free header is highly recommended. While we can dump fuel to cool things off, those stock units are sized for output, so if you're flogging it a lot then it won't hold up unless we do that. But if it just occasional use it will hold up OK I think.
Old 07-28-2013, 12:03 PM   #162
regal
Thankyou and do keep us posted. I was considering a tune as my only mod but if you get the innovate + header tune down to producing zero knock like your other FI tunes I will probably just get all three at once.
Mods:
regal is offline
Old 08-16-2013, 10:01 PM   #163
Xero-Limit
Xero-Limit's Avatar
Ooh...what do we have here
Yup, it's awesome. E85 like performance on pump gas. Holds to redline, no issues despite no IC. You DO want a 3 bar MAP for this.
On E85? Holy hell it rips. Spent the better part of the last two days working on the pump gas tune and it looks good so far, should get it out to rest of our innovate people in the next week or so. Just waiting on confirmation from some of the folks to make sure the new tune is doing its job.
ETA on the pulleys is pending, we want to make sure these hold up good over time. 0 issues so far on the stock Innovate belt.
The Following 5 Users Say Thank You to Xero-Limit For This Useful Post:
Hempo (08-19-2013), ill86 (09-05-2013), mines13 (08-19-2013), Opposed (08-17-2013), Subzero (08-19-2013)
Old 08-17-2013, 01:01 AM   #164
scraejtp
Drives: 2013 Subaru BRZ
No numbers/graphs?
scraejtp is offline
Old 08-17-2013, 01:07 AM   #165
xjohnx
Grip>Slip
xjohnx's Avatar
let me know if you need someone to make sure those pulleys can hold up to the rigors of the blue Gates RACING belt. Look kind of brittle to me.
xjohnx is offline
Old 08-17-2013, 01:08 AM   #166
Xero-Limit
Xero-Limit's Avatar
Not yet. We're prioritizing making the tune consistent before going for peak hp numbers. So far so good, but I'd like to see more datalogs to make sure it is holding across multiple cars.
Originally Posted by scraejtp View Post
No numbers/graphs?
The Following User Says Thank You to Xero-Limit For This Useful Post:
evo4g63 (08-17-2013)
Old 08-17-2013, 03:50 AM   #167
ft_sjo
Drives: GT86
What size is that pulley? Sprintex don't warranty the units at 70mm normally, so curious how you're managing that?
ft_sjo is offline
Old 08-19-2013, 11:40 AM   #168
swift996
swift996's Avatar
Are you running the 70mm or 72.5mm? I'll be interested in seeing the results!
BTW - New tune file feels much better but only went for a quick spin.
swift996 is offline
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 11:25 PM
Innovate questions Fast_Freddy Forced Induction 12 07-02-2013 03:27 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
innovate SC for sale kioton32 Forced Induction 4 04-08-2013 12:42 PM
