#141 |
Yeah definitely, I will PM you. How has it been on the street when you hit high heat during the day to a cooler night?
#142 |
Drives: 2013 Black FR-S
So far my butt dyno sees no difference in 65 vs 100 deg weather. The data logs show no difference in timing either and there is no knock correction.
| The Following User Says Thank You to sw20kosh For This Useful Post: | ftc~brz (07-16-2013) |
#143 |
@Dezoris
Ambient was around 96 F. One big fan blowing on the front of the car. @robispec total cooling solution. ~5 mins between each pull Run 1 on the left, Run 6 on the right. Obviously there is not much airflow through the radiator so recovery of coolant temps after each run will be slower but as you can see coolant and oil temps dont creep up and up after 6 successive runs. ![]() 100 C = 212 F 96 C = 204 F 48 C = 118 F Last edited by sw20kosh; 07-13-2013 at 05:26 AM. |
| The Following 3 Users Say Thank You to sw20kosh For This Useful Post: |
#144 | |
All those runs with meth injection? Basically all that data looks very good. Be curious to see the difference from other owners on stock cooling and no meth. Again thanks a ton for posting this.
#145 | |
And yes to more temp logs from others. It is obvious to me that the robispec system is working great. Talked to him today and he told me in 116 deg ambient heat at a time attack track day his system was able to cope with flying colors. He was the fastest car there by the way... took first place by 10 secs! Congrats @robispec. Show those hondas who's boss! |
#146 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Finally had a chance to do a little video work:
[ame]http://youtu.be/IxC2iNj1j9g[/ame] |
#147 |
WUB WUB
Drives: 2013 Firestorm
love how it sounds, just wish I could hear mine over my exhaust.
| The Following User Says Thank You to wrxgoose For This Useful Post: | ftc~brz (07-16-2013) |
#148 |
Mike you killing timing before 7k to prevent knock?
#150 |
Drives: 22 BRZ
What a night and day difference in power delivery. I like it.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#151 |
Injectors are on (DW700). Full power to redline now. No leanout, tip in knock reduced significantly as well.
Seeing about 6+ms port injection time to achieve .8 lambda with e85. That means we are well into the duty cycle on these on the stock pulley in nearly 100 deg weather. Was debating as to whether to start smaller, but I'd say the 700's are a good injector here. Plan is to re-dyno once the header comes in. |
#152 |
Timing is taken out everywhere for pump gas. For E85 it is more selective. We pushed it on the dyno until the knock was blatantly evident (ever hear a 50 cal lol? hair away....) That point was well below stock maps on pump.
#153 |
Intake temps were 116f with the meth running? That seems pretty high. How much does meth typically drop the temperature? What are people seeing without it? I'm usually around 105 or so, within 5-10 deg of ambient (with a fmic though).
#154 | |
I assume your maf/IAT sensor is post intercooler on your kit? |
| Innovate Supercharger!!! | Titanmotorsports | Forced Induction | 62 | 08-24-2014 11:25 PM |
| Innovate questions | Fast_Freddy | Forced Induction | 12 | 07-02-2013 03:27 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 07:33 PM |
| innovate SC for sale | kioton32 | Forced Induction | 4 | 04-08-2013 12:42 PM |
