#1303 |
Drives: 2014 GT86
Khyron686: imho there is one way to eat cake & have it too, if you like those 235/45r17 that much. Install slightly different final gear ratio kit. It might not be enough to compensate speedo changes, but imho it will fix slower acceleration.
#1304 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
"Meaty" is about tire width, not sidewall. Tires are sometimes referred to as Meats and when you say a car has a lot of meat under it, or that it is "laying down a lot of meat" it means it has wide tires. Sidewall doesn't come into it. A 265/35 is meaty. A 185/70 is not.
| The Following User Says Thank You to Draco-REX For This Useful Post: | stevesnj (05-08-2015) |
#1305 |
Drives: 2013 Whiteout FR-S
Is 295/30 meaty?
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
| The Following 2 Users Say Thank You to pleong For This Useful Post: | Hicklinc (02-20-2018), Jive Turkey (05-08-2015) |
#1306 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
| The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post: | Jive Turkey (05-08-2015), pleong (05-08-2015) |
#1307 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#1308 |
Car Nut
![]() 255/40/17 |
| The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post: | Scracho (05-12-2015) |
#1309 |
Drives: SWP BRZ
hey guys so I'm running 245/40/18 on 18x9.5 +34 and on st coilovers. My camber is -1.8 front left and -1.6 front right. rear left is -2.5 and rear right is -2.8. i rub going up driveway or dips at an angle and rub when i hit a dip or bump if I'm not going super slow. not sure what to do
thanks in advance.
#1310 |
Drives: 2014 FR-S Asphalt
#1311 |
Drives: 2014 Subaru BRZ LTD 6MT
| The Following User Says Thank You to ajaxthebetter For This Useful Post: | BRZZZZZZZZZZ (05-09-2015) |
#1312 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
funny how you post appropriate tires to make your point, but then stretched tires with no sidewall to show how width is irrelevant.
with that offset you really should roll your rear for some clearance, thats also a lot of camber in the rear with a not that large of a tire (assuming you went 245 for clearance?) how low are you? reason i ask is ST are a bit on the softer side, so if you're slammed, it makes sense why you rub because your wheels don't fit. post a photo and we should be able to help you out. i'm assuming your'e talking about tire rubbing, not ground clearance issues. do you have any markings in your tires? good way to see where you are rubbing is to chalk your sidewall. many do it at auto-x, including myself, to see if they are rolling over and should add or take away pressure. |
#1313 |
Drives: 2015 Fire
![]() 265 |
#1314 | |
Drives: SWP BRZ
![]() image hosting adult |
#1315 |
Drives: SOLD...
and nvm... a 245/40/17 RS3 v2 is wider than a 255/35/18 V12 EVO
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
| The Following User Says Thank You to Skurj For This Useful Post: | Jive Turkey (05-13-2015) |
#1316 | |
Drives: 13' Asphalt FRS
IG: __thatguyjeremy
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 343 | 10-16-2023 07:15 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
