Old 04-26-2015, 07:39 AM   #1261
Jamesbrz
Drives: White BRZ
Hi guys doing some research on wheels and was just wondering if 18 inch by 9.5 inch wide rims with a offset of 45 if I will have any issues of rubbing at all, looking at 255/35 tyre, also is that a lot of stretch or would be fine. Also have coilovers.
Jamesbrz is offline   Reply With Quote
Old 04-26-2015, 06:43 PM   #1262
byun
byun's Avatar
Drives: 2015 BRZ CWP
Depends how low you go. I think I'm dropped around 1.5" in front and only rub the fender liners as full lock right or left. Rear you got plenty of room. Tires don't look stretched Name:  ImageUploadedByTapatalk1430084645.215904.jpg
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
Figo (04-30-2015)
Old 04-27-2015, 03:38 AM   #1263
coeurdencre
coeurdencre's Avatar
Drives: 2014 x ZC6 x 37J
Originally Posted by Jive Turkey View Post
what rubbing issues...?
but that makes sense, but you have more room than you think
I thought 255/265 tires would cause rubbing issues without spacers.
coeurdencre is offline   Reply With Quote
Old 04-30-2015, 03:57 AM   #1264
willnigguhwassuh
IG: will__is__nguyen
willnigguhwassuh's Avatar
Drives: 2013 Asphalt FRS
finally get to post on here! Lowered on Fortune Auto coilovers running 255/35/18 toyo r888
front camber: -2.2
rear camber: -3.5
willnigguhwassuh is offline   Reply With Quote
The Following 3 Users Say Thank You to willnigguhwassuh For This Useful Post:
Figo (04-30-2015), Hicklinc (02-20-2018), nlamon33 (04-30-2015)
Old 04-30-2015, 06:34 PM   #1265
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
front camber: -2.2
rear camber: -3.5
why are you running so much rear camber?
also if anyone is interested, my cusco LCA is for sale. went with something that makes my life aligning a bit easier.
350$ takes them. thanks!
Jive Turkey is offline   Reply With Quote
Old 04-30-2015, 08:23 PM   #1266
car_roll
Drives: Nuisance BRZ
what LCA did u get? I'm on the same boat about my cuscos.
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 05-01-2015, 06:04 AM   #1267
MNGBRZ
Hi guys,
I have a Release series 1.0 FRS that comes with TRD springs. (1 inch lower)
I ordered Work VS-XX 18x9.5 +39 offset wheels, and i am thinking to wrap them with 255/35/18 all around. Oh 3mm spacers for the front. I really like the ride quality of 40 profile, so also considering 255/40/18.
Will i run into any issues?
MNGBRZ is offline   Reply With Quote
Old 05-01-2015, 08:05 PM   #1268
Jive Turkey
the tuna, no crust.
went with SPC, made my life so much easier, and now i don't have bling underneath for all the ricers to ask me questions about.
Originally Posted by MNGBRZ View Post
Hi guys,
that won't fit the front, at all.
The Following User Says Thank You to Jive Turkey For This Useful Post:
Porcupint (05-01-2015)
Old 05-01-2015, 08:49 PM   #1269
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
What was wrong with the Cusco ones?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 05-01-2015, 09:04 PM   #1270
Jive Turkey
the tuna, no crust.
adjusting them took forever because i'm not adding more camber, i'm actually taking it away.
the cusco's are great for those who need more camber. i needed less at the height i was at, the adjusting was getting annoying.
Old 05-01-2015, 09:17 PM   #1271
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Will wheels that are 18x8.5 + 42 offset fit with 235/40/18 with no fitment issues on stock suspension?
I've asked this almost everywhere and no response, so this might help. Hopefully.
Thanks.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 05-01-2015, 09:21 PM   #1272
willnigguhwassuh
I have to or else I will rub. I didn't roll my quarter panel yet.
Old 05-01-2015, 09:54 PM   #1273
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Thanks.
Tires are a bit bigger in diameter by like 2cm if that's what you are after. It will work fine, but 235/35/18 would be a closer to stock size.
Khyron686 is offline   Reply With Quote
Old 05-01-2015, 09:59 PM   #1274
x1UP
One & Done (AOZORA)
x1UP's Avatar
Finally, an answer! Thanks. I am looking to be flush with the car (without using any spacers) which is why I was going to go with 235/40.
So, basically, that would work right?
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 343 10-16-2023 07:15 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
