Old 10-02-2014, 12:53 PM   #939
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Thats true, offset is as importance as width. Mine is 9" with +42, maybe with a little less offset i would have been able to dial in more negative camber up front without worrying about the inside fender liner. I had to remove my tabs also to avoid conflict between the tire and rear bumper/fender junction. Also what i meant by the 255/40 being too tall is that it may rub with your set up not that the tire is wrong for the wheel size. Post some pics lol
yomny is offline   Reply With Quote
Old 10-05-2014, 09:42 PM   #940
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Originally Posted by yomny View Post
255/40R17 As usual rubbing the rear fender/bumper tab but only on extreme circumstances.
What wheels are these? Weds TC105ns? Reps?
cactus is offline   Reply With Quote
Old 10-06-2014, 08:24 AM   #941
yomny
yomny's Avatar
They're their replicas Rota Titan
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post:
cactus (10-06-2014)
Old 10-07-2014, 10:07 PM   #942
Ric0
Drives: 2013 Subaru BRZ SSM
Inspired by Jive Turkey's car (jive's breeze)
235/40/18 Hankook RS3
Ric0 is offline   Reply With Quote
The Following User Says Thank You to Ric0 For This Useful Post:
Jive Turkey (10-08-2014)
Old 10-07-2014, 11:05 PM   #943
nlamon33
nlamon33's Avatar
Drives: 2013 SWP BRZ Limited
Then why 235 on a 9.5" wheel?
nlamon33 is offline   Reply With Quote
Old 10-07-2014, 11:11 PM   #944
Ric0
I wanted to see the life span on these tires before spending an extra $400, so far only 3 months on these, if I can squeeze a year then it will be 255/35 next time, these are not that stretched even tho the size may say it does.
Old 10-07-2014, 11:49 PM   #945
nlamon33
nlamon33's Avatar
Yeah RS3's run kinda wide, so a 255 would probably fit very well.
Just seemed odd because they are a great tire and you could have much more rubber on there!
The Following User Says Thank You to nlamon33 For This Useful Post:
Ric0 (10-08-2014)
Old 10-08-2014, 06:37 AM   #946
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
Originally Posted by BRZ21 View Post
So now I've been thinking either 225/40 front with 255/35 rear
Or
235/40 front and 265/35 rear on 18 x 8.5 et45 front and 18 x 9.5 et45 rear.
Stock suspension for now
Any input?
Sorry I keep popping in and asking basically the same question. And I know raven kinda confirmed either setup would work (thanks) but I'd just like to know which setup I should go with.
Personally I'd like to go with the wider setup as long as it would fit.
Thanks guys
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 10-08-2014, 10:30 AM   #947
yomny
yomny's Avatar
To be honest I would go with the narrower set just to be on the safe side. I just got the wider of my two choices 255 over 245 and now the inner liner in the front is being rubbed against so I had to raise my car a bit. You have a pretty high offset so that pushes the wheel inside.
BRZ21 (10-08-2014)
Old 10-09-2014, 01:31 AM   #948
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Trashing fender liners isn't really a big deal. I've replaced them several times.
Old 10-09-2014, 01:35 PM   #949
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i only went through one liner, and thats only because i caught a chunk of ice and it ripped it into my wheel thus ripping it out. otherwise, i NEVER rub, only when i go full lock, and even then its not always.
if your'e rubbing, you either have too soft a suspension, you forgot to roll/trim certain parts, or your offset is too aggressive to fit functionally. i personally wouldn't go more than +35 on a 9.5 wheel, even +35 is too aggressive for my liking on a square setup.
Jive Turkey is offline   Reply With Quote
Old 10-09-2014, 04:24 PM   #950
octavio.molina.1985
octavio.molina.1985's Avatar
Drives:
Meaty Tire Thread
Any one know if TPMS from another FRS will reset itself if I put it on my car???
Of course I have an FRS da well. Dealer is trying To charge 250.00 to reprogram the new ones.
My old TPMS is in Arizona I'm in Cali(didn't think of transferring them) :/
My tire light is permanently on
Sent from my itablet
octavio.molina.1985 is offline   Reply With Quote
Old 10-09-2014, 04:40 PM   #951
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
TPMS codes are specific to vehicle and must be programmed in. They do not "auto-reset."
sdemo is offline   Reply With Quote
Old 10-09-2014, 06:34 PM   #952
octavio.molina.1985
Drives:
Dawn, so dealer only huh?
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 343 10-16-2023 07:15 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
