#589 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
all you need to do is get a heat gun and a screw driver that has a rubber end/handle. heat up that area, take that rubber end and push the lip in slowly, keep it hot, push it in etc etc. very simple to do just takes some carefulness |
#590 |
Drives: 13 CSB BRZ Ltd
Wow those bad boys are tucked. Looks clean. Any details on the alignment specs?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
#591 |
Drives: White 2013 FRS
#592 |
Drives: FR-S 10 series
#593 | |
Haven't got it aligned
#594 | |
It all depends on how low you want to be. You can be lowered more than an inch with no fender mods. Personally, I have a fairly aggressive roll on the roll with no fender work in the front. The front rubs on hard cornering only, not bad at all though.
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | mmmcambelsoup (04-15-2014) |
#595 |
Boosted
Drives: Not a supra....yet
Test fit on the brz, these are going on the frs though. The car is going to be dropped pretty low
Sent from my IBrick
| The Following 3 Users Say Thank You to SmsAlSuwaidi For This Useful Post: |
#596 |
Drives: 2013 - Scion FR-S in White"red"out.
This seems like a great thread to ask this question and since Im in the "meaty" club, it should still remain on topic and serve to help others.
@King Tut (since he tends to know this shit pretty well) Im running 255/35s on Eibach Sportlines with 18x9.5 e38 wheels. Im pretty close to the Spring Perch, but not rubbing on anything. I would like to Camber my fronts to -1.5 degrees. I asked the tech about this when i had my alignment done and was told that using camber bolts I would tip myself into my spring perch. I was of the understanding that they all moved together so as long as I am not rubbing now, I would not rub if I cambered them. Can someone confirm/deny this for me? I am considering getting coilovers soon to improve my ride quality some and lower my car more than I currently am, so this may be a moot point, but if I like the camber and drive quality if I use camber bolts then I may just stay with it. Thanks for the help!
#597 |
Drives: '13 SWP ZC6 R
Camber adjustment via adjustable top hat moves the entire strut assembly. Camber adjustment via camber bolts moves the hub / knuckle in relation to the strut.
The tech is correct, if you adjust camber via camber bolts, you will run into clearance issues.
| The Following 2 Users Say Thank You to sdemo For This Useful Post: | ilpad (04-15-2014), Jive Turkey (04-16-2014) |
#598 | |
Meaty Tire Thread
This. You could always get camber adjustable top hats for your stock strut assembly, but the question remains as to whether or not that would be worth it. Personally, I'd recommend going with a full coilover assembly. BC Racing Extreme Low or Stance coilovers would be a great option if you're on a budget.
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | ilpad (04-15-2014) |
#599 | |
Now back to meaty!
#600 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | ilpad (04-15-2014) |
#601 |
Drives: bucket
i don't like quoting pictures but this needs to be seen over and over. maybe i missed the specs so could you post again for the slow ones? tires appear to be 255/40/17?
#602 | |
Boosted
Yes sir, toyo r888 255/40/17 Sent from my IBrick
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | humanshield (04-17-2014) |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 343 | 10-16-2023 07:15 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
