Old 02-15-2017, 12:37 AM   #2101
15limited
15limited's Avatar
Originally Posted by DuMa View Post
theyre grippy
theyre noisy
theyre oversized
theyre loud
theyre cheap
sometimes when im cruising on the highway and i think theres a jet following me. no its just the fucking tires screaming.
A++ would buy again.
Sounds like the definition for a tire belonging in the Meaty Tire Thread
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-15-2017, 12:42 AM   #2102
15limited
15limited's Avatar
theyre grippy
theyre noisy
theyre oversized
theyre loud
theyre cheap
bonus shot
Oh and even on 17X9 Weds? What size Federals are you rubbing, I mean running 😈
Old 02-15-2017, 12:48 AM   #2103
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Originally Posted by 15limited View Post
Oh and even on 17X9 Weds? What size Federals are you rubbing, I mean running ��
255/40 in rear only. they fit more like 265s
i dont know want to know how loud it will be when i replace the fronts with the same RSRRs
DuMa is offline   Reply With Quote
Old 02-15-2017, 01:20 PM   #2104
WHITEBUUURRZZ
Drives: 2013 BRZ 6mt limited
Nice set up!!! Always cool to see nice 86 in TN.
WHITEBUUURRZZ is offline   Reply With Quote
Old 02-15-2017, 05:46 PM   #2105
Lust
Drives: 2017 Subaru BRZ
New wheels & new meat. I'll probably take better photos when the sun is out.
VOLK TE37SL 18x9.5" +40
265/35 Yokohama Advan Neova AD08R
Current specs
Ride height: 25 1/2" Front 25 3/4" Rear. Measured from the ground through the center of the wheel to the fender
Caster: 5.9
Camber: -2.0 Front -1.6 Rear
Total toe: 0 Front .08 Rear
Lust is offline   Reply With Quote
The Following 4 Users Say Thank You to Lust For This Useful Post:
Chayce808 (02-15-2017), MyNameIsKeh (02-16-2017), slow15frs (02-15-2017), swarb (02-17-2017)
Old 02-15-2017, 09:40 PM   #2106
Lust
Originally Posted by Alltezza View Post
Yeah I called the guy up asking if he'd like to roll my fenders and he's basically saying to get an alignment so I don't rub or whatever. I was like look man based off the forums and some things I've read I need them rolled and he's all like "Get an alignment"
I was a little irate to be honest....
Was hoping to get my damn fenders rolled, didn't wanna get the alignment done since i don't have LCAs yet
I see where he's coming from. He's thinking if you get an alignment you may not run into clearance issues. Avoids permanently altering the fender. You'd have to have a lot of negative camber though.
Old 02-16-2017, 04:47 AM   #2107
sqd
sqd's Avatar
Drives: '13 SWP GT86
Originally Posted by Chayce808 View Post
Got my wheels and tires mounted this past weekend 18x9.5 +40 with 265 35 18 MPSS �� #meatyftw
Sent from my SM-N920V using Tapatalk
"TE37SL, white car and 265 squared"-master race?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
The Following 4 Users Say Thank You to sqd For This Useful Post:
Lust (02-17-2017), SkAsphalt (03-20-2017), swarb (02-17-2017), yberther (03-13-2017)
Old 02-16-2017, 08:56 PM   #2108
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Anyone got recommendations for LCAs?
I noticed Jive Turkey is running SPCs, what all are you guys running?
Alltezza is offline   Reply With Quote
Old 02-16-2017, 08:57 PM   #2109
Chayce808
Chayce808's Avatar
Drives: 2017 Subaru BRZ Crystal White Pearl
I've got SPC also.
Chayce808 is offline   Reply With Quote
Old 02-17-2017, 03:04 AM   #2110
Lust
I personally have SPL. Cusco, Whiteline and Velox are also good.
Old 02-17-2017, 05:06 AM   #2111
churchx
churchx's Avatar
Drives: 2014 GT86
I'd probably would get Velox for no comprimises one i like most, or SPC(=Whitline,=Eibach) if lowest price and oem-look-alike matter most. For other alternatives i'd look only if i'd happen to be from extreme drop stance crowd, i won't.
Old 02-17-2017, 06:06 AM   #2112
Alltezza
Alltezza's Avatar
Just placed an order for SPCs, I'm starting to wish I got the LCAs with the coilovers......really don't wanna go back under there LOL.
I was looking at RSR and Cusco and Voodoo they all look nice af but I think SPCs from the looks of it looks like a more Functional street car setup.
The high end brands look pretty fancy while SPC just looks plain but still gets the job done.
Old 02-17-2017, 04:26 PM   #2113
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
all you really need rolled is the rear. the front part i'm talking about you can do yourself in five minutes with a rubber end of a screw driver and a microfiber. its super small and bends right in.
rear fenders i suggest a roll, so you can run minimal camber back there. can you get an alignment that has more camber to not get a roll? sure, but then why go through all of this modding and not have the car dialed in exactly how you want....this guy just sounds lazy
also, you didn't post your offset. offset is probably most important in fitting wheels correctly
SPC is great. i ran them for a long time. I originally had Cusco and i hated them. they are the reason i needed toe arms. they also are a huge pain in the **** to adjust so alignments took forever.
i always tell people get SPC unless you want to spend more in which case get SPL. all other arms suck to adjust and seize up. even my cusco seized up after i anti seized them and everything
Jive Turkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post:
Alltezza (02-17-2017), kevaughan (05-03-2020), Kris86 (04-28-2019)
Old 02-17-2017, 05:06 PM   #2114
JT.86
Drives: Scion FRS 2016
I'm planning to run 18x10 et44 TE37RT square 265/35 in spring. Anyone know what I have to dial in to avoid rubbing?
I feel like I may rub on the inside (I'm running ST coilovers).
will I need to roll the rear with minimum camber?
Your inputs are appreciated
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 343 10-16-2023 07:15 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
