Old 01-07-2017, 05:07 PM   #2059
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Is this a track car or street car? I really doubt you'll see much of a real world difference between a 265 and 275 in terms of grip, and a 265 can be (relatively) easily shoe horned under your front fenders. With a square setup, you retain proper handling characteristics of the car and ability to rotate.
For "10" mm extra tread out back, you sacrifice so much....
sdemo is offline   Reply With Quote
Old 01-07-2017, 05:20 PM   #2060
FaDuck
Drives: 2014 UltraMarine FRS
Its just a street car... Im just going more for that "wow" factor. I love the tread design on the INVOs, thats mainly why Im going with those tires.
I originally was just planning on going with 235/40 and 265/35, which is a fairly common set up. And Im already planning on rolling the fenders to be on the safe side.
I just happened to come across Texasbound's posts and wanted some thoughts and opinions
FaDuck is offline   Reply With Quote
Old 01-08-2017, 02:39 AM   #2061
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Nice to find someone else @FaDuck that chooses tyres on how they look too
If I'm choosing between tyres I'll check how the tread and side wall looks. I like a square side wall as well as a race-car looking tread pattern :-)
Currently I'm using Bridgestone RE003 that I don't think are available in USA or they have a different model but do like the Nitto INVO "look" and had them before this set.
nzer is offline   Reply With Quote
Old 01-10-2017, 12:19 AM   #2062
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
...racecars don't have tread patterns
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
DustinS (01-10-2017)
Old 01-11-2017, 10:48 AM   #2063
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
265/35/18 continental dws 18x9.5 +35
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 01-18-2017, 09:19 PM   #2064
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
New setup... still rolling 285/30/18's at all 4 corners
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 7 Users Say Thank You to OmarGC For This Useful Post:
btune (03-02-2017), drew_kar (01-18-2017), DustinS (01-18-2017), ILLSMOQ (01-19-2017), mmmcambelsoup (01-19-2017), slow15frs (01-19-2017), spirit (01-21-2017)
Old 01-18-2017, 10:56 PM   #2065
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
All hail the king
Sent from my Pixel using Tapatalk
drew_kar is offline   Reply With Quote
Old 01-19-2017, 01:09 AM   #2066
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Looks great, what are the wheel specs? Got any more shots from the front or back to show how flush they are?
Hard to tell, is the tire chunked a bit from rubbing?
ILLSMOQ is offline   Reply With Quote
Old 01-19-2017, 01:23 AM   #2067
ILLSMOQ
Never mind found your build thread, awesome car!
Old 01-19-2017, 11:14 AM   #2068
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Yeah there was tire rub in the rear from my previous, slightly more aggressive wheels. I've since then pulled the rear quarters more and added RUCA offset bushings.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
Old 01-19-2017, 03:42 PM   #2069
ILLSMOQ
The Volk ZE40 18x10 +40 works well with the 285's? or is that the wheel that was rubbing?
Old 01-19-2017, 09:59 PM   #2070
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
You'd have to run a between a 10-15mm spacer up front I'd guess to not hit the frame at full lock would be my guess. Rear would be ok with an aggressivs pull
Omar GC
Instagram: 2jzus
Old 01-19-2017, 10:37 PM   #2071
ILLSMOQ
Are those the wheels that chunked your tires? The new bluish wheels, are those a different offset or are those the same wheels just refinished?
I'm doing a LS swap and shooting for 500+ at the wheels, so I need big rubber under my car and I like how your car sits and looks in all the pictures...but I need it to be usable with aggressive driving in the "back roads" know what I mean?
I'm pretty much thinking to go with your set up or do a wide body with 315's or 335's, though I'm not really excited to do a wide body.
What would you advise?
Old 01-20-2017, 01:33 AM   #2072
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Blue wheels are different... my old te37's (6 spokes) would rub the very outer edge of the of the tire tread where it meets the sidewall. They were 4mm more aggressive, my rear quarters weren't pulled as much as they are now, and no RUCAS mods.
I can't recommend doing adjustable RUCAS (rear upper control arms) or RUCAS offset bushings paired with lower control arms for camber correction enough.
But honestly, I don't feel any need to go widebody. I'm pretty confident that a 305mm section width tire will fit under the 86's factory quarters. I'm going to attempt it in the future, I would like to go widebody... but the stuff I want isn't very affordable lol
Omar GC
Instagram: 2jzus
ILLSMOQ (01-20-2017)
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 343 10-16-2023 07:15 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
