86WORX
Old 10-23-2016, 11:30 PM   #1961
swarb
Originally Posted by 15limited View Post
Did you guys go from stock to these setups? What other setups have you ran?
yes
Old 10-23-2016, 11:42 PM   #1962
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
Was stock, the stock with spacers.. then beefy
GenRuleAThumb is offline   Reply With Quote
Old 10-24-2016, 04:19 AM   #1963
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by GenRuleAThumb View Post
Im dropped 2 inches i dont think the 65s would fit in the front without rolling fenders or more camber than i want to go with my offset, and i wanted to stay square.. But i envy you.
You could be right, I have -2 degrees camber in front although fitted fine even before then. But, with +45 offset. With +38 that many people run I think I would have had issues.
nzer is offline   Reply With Quote
Old 10-24-2016, 04:22 AM   #1964
nima314
Drives: Subaru BRZ 2017 (almost)
Yep. Im all about that fitment!! I get a chub just thinking about how well they fit.. pluss meaty yo
I was worried whether it will look good or not but your 2" drop photo gave me a lot of relief and excitement haha. Would be great to see more pics whenever you have the time later. You rolled fenders just like the OP?
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 10-25-2016, 04:45 AM   #1965
Allan13
Allan13's Avatar
Drives: 2013 Subaru BRZ
Fitted 17x9+35 Rpf1 with 245/40 tires.
Not the meatiest tire but I'd like to show that I'm able to fit somewhat meaty tires on stock body with pbm angle kit 😁.
PBM angle kit, PBM coilovers, PBM RLCA, Tomei 2way diff, Hydraulic Ebrake, Bride Seat, Schorth harness.
Allan13 is offline   Reply With Quote
The Following 2 Users Say Thank You to Allan13 For This Useful Post:
15limited (10-25-2016), swarb (10-25-2016)
Old 10-25-2016, 09:17 PM   #1966
15limited
15limited's Avatar
That's a good look! Is it the PBM kit that gives it such a wide track?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Allan13 (10-26-2016)
Old 10-26-2016, 12:13 AM   #1967
Allan13
Allan13's Avatar
Thanks!
Yes the adjustable LCA from pbm lets you adjust track width 😁.
Old 11-04-2016, 09:24 AM   #1968
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
mas protein
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following 2 Users Say Thank You to mmmcambelsoup For This Useful Post:
15limited (11-05-2016), brz11b (11-04-2016)
Old 11-04-2016, 09:58 PM   #1969
nima314
There is no MPSS or ExtremeContract DW in 255/35 available in Australia. Should I go 245/35 or 255/40? I don't want to go 265 since it's just too much tyre for the power of the car. I want to fill the fender as much as possible..
EDIT: I'm probably going 265/35 with rear arms. Dealer suggesting Cusco and says its super easy when i mentioned it is apparently a pain to setup/adjust..and cannot find SPC in Australia lol.
Old 11-04-2016, 10:52 PM   #1970
nzer
nzer's Avatar
What offset are your wheels? You may not need rear arms if you're +45 as I don't with 18x9.5" +45 and 265/35 tyres
Old 11-04-2016, 11:11 PM   #1971
nima314
18x9.5" +38. I would probably need them with that offset. I am thinking of buying SPC directly from FT86 SF depending on their response to how long it will take to arrive here in Australia.
Old 11-04-2016, 11:21 PM   #1972
nzer
nzer's Avatar
Agreed, you'll likely have fender rubbing without some extra rear camber
The Following User Says Thank You to nzer For This Useful Post:
nima314 (11-04-2016)
Old 11-04-2016, 11:24 PM   #1973
nima314
In that shot i was dropped 1.5 in on st coilovers.. dropped it down to 2in now..
What control/toe arms did you use? I'm worried that the SPC arm with toe kit is not enough for a 2" drop and I will need toe arms?
Thanks
Old 11-05-2016, 05:23 AM   #1974
GenRuleAThumb
Drives: 2014 FR-S
Thanks
None, i only have ST coilovers, natural camber in the rear from the drop and a little camber up front to tuck the tires in.. ill take some more shots tomorrow
Search this Thread:
Advanced Search
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 343 10-16-2023 07:15 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
