#57 | |
Drives: 2013 Subaru BR-Z Limited
I feel for the guys having these issues and its the only thing that has me on the fence over FI. I'd love to have the FA20 kit installed already and beating the crap outta the car having at least some faith in the reliability but these issues popping up on NA motors too has me worried to install even a "safe" supercharger kit like the innovate or Vortech. I've been watching as patiently as possible as the early adopters (you) of the early adopters (ft86 community) log some miles on each of these setups and find the weak links. As hard as it is to wait my wallet thanks you for taking the leap first.
#58 |
Drives: 92 Integra
I think I will wait on buying this car as new. I would rather pick one up with a blown motor in a couple of years and throwing in an LS swap. I'm predicting there will be many cars with blown motors to chose from.
| The Following User Says Thank You to lsxiong For This Useful Post: | Roadliner (07-08-2013) |
#59 | |
I planned on it if I ever get the parts in!
So chances are IF I do have a problem it was caused before supercharger, and now the extra heat and pressure are going to accelerate the issue. Thanks for the heads up. As soon as I pull the injectors I will have a video and thread with the results.
| The Following User Says Thank You to Dezoris For This Useful Post: | chadstyle (07-07-2013) |
#60 | |
Again, thanks for the prompt replies! Chad
#61 |
Drives: 2013 SWP Limited BRZ - Manual
Wow...a 100% failure rate with a sample size of 2! I have 100% rate of no crickets...oh my sample size is 1..that's legit right?
Two cars that were bought at the same time are not a great way to diagnose problems with the engine as a whole. |
#62 | |
Reverse Burnouts
Drives: 2013 Argento FRS
but who knows, its scary for people like me and a few others because i don't track at all but i do drive my car pretty spiritedly in small spurts here and there and im coming up on 35k miles so ill let yall know if i have a failure, im pulling mine at 50k if i don't throw a code by then
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#63 |
Drives: FR-S MT
If this becomes a pervasive issue at higher mileage, it is likely that Toyota will take car of it under a "silent warranty" program. For example, Toyota replaced chassis of Land Cruiser no longer under warranty due to excessive rusting.
#64 |
Drives: Asphalt FRS
This thread definitely needs more details but it certainly raises some valid questions.
1. When were the rental cars manufactured? Is this something that Toyobaru has "stealth fixed" with the ECU update to retard engine combustion over 5200 RPM? 2. Is the failure the result of the fact that these two rentals were used almost exclusively on the track? 3. What does this mean for the future of this car, on track and off? |
#65 | |
Drives: Moped
Not to mention the owners here who have either had the issue crop up already, or have cars starting to exhibit the symptoms... |
| The Following User Says Thank You to Lonewolf For This Useful Post: | cmspooner (07-07-2013) |
#66 |
I hate to say this, but even adding a sample size of 4 to the cars on here, failure rate is pretty low.
#67 | |
Drives: Moped
So far the failure rate of forum-involved individuals appears to be quite low; but as to the true failure rate, only Toyota/Subaru know. As most are speculating, this problem seems to appear after hard use (perhaps prolonged use as well) and it is unsettling that there is some potential for this problem to become significantly more widespread as the years go by. For now, this problem could just be an unfounded fear that will not affect the masses, or it can become the automotive equivalent of the boogeyman, crapping on all our hopes and dreams...
#68 |
Drives: 2020 CTR
Wow, I feel like I'm on the NASIOC. Defend the newer crappy 2.5L WRX in 2008 with all the engine failures. Coming from an x owner we should spread the news so Toyota can look into it and get it fixed. I don't understand why people get their feelings hurt when their cars are not perfect which the truth is non of the cars are perfect. If there is an issue based on whatever is causing the problem we should be a part of the solution not to cover up and pretend it's a fluke.
I'm about to pull the trigger on a new one but until Toyota/Subaru finds a solution I'm not buying one "yet". I don't feel like being lucky and get a good one. I don't have the time anymore. I remember Audi had problems with the DFI/carbon buildup and I'm not sure if it's even fixed today but definitely improved. |
#69 |
Drives: Argento FRS
I fully expect my engine to have problems. It's a new engine, has crickets etc.
3 years and it's going to be traded in for sure. |
#70 |
4 is better than 2...but how closely where they manufactured and how early are their vin numbers?...I have an early vin...but my issues have been cosmetic so far (condensation, passenger window, and rear deck ticking; and the ticking has gone away(.
| Tags |
| regalsurinalpost |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 12:25 PM |
| 86 rentals - 2013 era | bcj | AUSTRALIA | 11 | 04-23-2013 11:27 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 06:07 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
