Old 07-07-2013, 01:08 PM   #29
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I've got 32k+ on the car with 100ish miles of daily commuting and 2-3 2day AutoX events per month. I just SC'd my car. It seems to run great at this point. I'd like to check my injectors for signs of issues, but what am I looking for?
NM, a bit of searching seems to have found more info.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
Old 07-07-2013, 01:09 PM   #30
regal
Originally Posted by 4U-GSE View Post
I am curious about the spark plug issue they are having. About a month ago I brought my car in for a check engine light. Under WOT Cylinder 4 was misfiring. The Toyota tech said that they switched the spark plug in cylinder 4 to cylinder 3 and that if the check engine light comes on for a misfire in cylinder 3 they will replace the spark plug. Since I have gotten the car back I haven't had any issues but I am still wondering if I am getting the full story.
Has anyone else had this issue?
A bad plug is a bad plug, switching cylinders couldn't have done a thing. Take your car up a hard pull over 5k rpm in 3rd gear and report back.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-07-2013, 01:16 PM   #31
Mikem53
Drives: FR-S 6MT
Originally Posted by regal View Post
Prove its not, pull your injectors and post pictures. No one I repeat no one has pulled a set off inectors without the problem. Its not a huge bit of inductive reasoning to conclude that O-rings are showing some degradation on all cars. I would love to be proved wrong, believe me.
So you are accusing the OPer of hearsay, classy. How about utilizing the forums as a means to help correct the issue before it leaves a lot more dissatisfied customers instead of pointing fingers and hiding in denial? Something constructive maybe ?
You prove it. You are the one claiming its a problem, not me. You own a car, pull yours.
I'm accusing you of quoting other people's post as fact. You even quoted that they are dropping the 86 from their fleet based on reading another persons post. Yet the cars are still offered for rent. I am not questioning the OPs talk with the employee.. But that doesn't make it fact does it? You don't really know the facts.. Yet you are determined to spread the word.
I'm sure Toyota/Subaru will address the issue. They have a bit more experience at this than you I suspect. In the meantime.. I will continue to enjoy my car and get it fixed if it breaks.
Mikem53 is offline   Reply With Quote
Old 07-07-2013, 01:22 PM   #32
ft_sjo
Drives: GT86
Don't bother me with the truth, my mind's made up!
The Following 3 Users Say Thank You to ft_sjo For This Useful Post:
Evil Jesus (09-18-2013), suaveflooder (07-07-2013), yuicebox (07-07-2013)
Old 07-07-2013, 01:24 PM   #33
regal
You are a perfect candidate to help the community. Study the manual, you need an o-ring tool which isn't expensive but hard to obtain right now with all the issues. Also parts are reported unobtainable for several months back-ordered since the issue is so widespread. So plan ahead.
Thanks
This is what you don't want (on the right):
Mods:
The Following 2 Users Say Thank You to regal For This Useful Post:
marky (07-07-2013), whataboutbob (07-07-2013)
Old 07-07-2013, 01:33 PM   #34
whataboutbob
Thanks
When I pulled the injectors/fuel rail/etc off for the Innovate SC install, none of my injectors looked like the one on the right. They all looked like the one on the left.
Old 07-07-2013, 01:40 PM   #35
ft_sjo
Drives: GT86
I doubt you pulled the direct injectors to install your supercharger.
Old 07-07-2013, 01:47 PM   #36
whataboutbob
My bad. Yeah those were the port injectors.
Old 07-07-2013, 01:49 PM   #37
regal
I don't think that's the right answer. Do you really want a replacement engine, or a car with a poor rep and resale value?
There are basically three scenarios with brand new engine design catastrophic failures:
1. The OEM takes care of the issue and fixes the root cause that arise whether it be <5% or 50%
2. The OEM covers the <5% under warranty waits a few MY's for a redesign, after warranty with the initial design the issue festers and presents itself in more and more cases as miles pile on. Word gets out and resale plummets
3. The enthusiasts of the community put their collective heads together and come up with a fix that the OEM can't due to economic, corp. politics, or regulatory reasons
4. The engine was well or over engineered to the point that it gets a reputation for being "bullet" proof which helps resale and in general success of the platform.
Threads here are littered with reports of blown engines first and second hand, and lets face it this forum is but a small percentage owners. This problem is not traceable to a certain build date or bad batch. It has been acknowledged by on small division of Toyota for months yet nothing has been done. Dealers can't get parts due to so many cases. At this point Toyota is choosing #2, we need start working on #3.
Mods:
Old 07-07-2013, 02:31 PM   #38
bestwheelbase
Drives: 1985 P-Type
@regal we think good information will come from those who inspect their direct injectors even if they're not experiencing engine problems. There may be many people on the road to premature failures who do not yet realize it.
It never hurts to check, right? Everyone can learn from it.
Old 07-07-2013, 02:33 PM   #39
torqdork
torqdork's Avatar
Drives: RV-7
From memory, I thought there was a thread here describing a running change in the DI system to address this last year, but couldn't find it. Anyone else remember this?
torqdork is offline   Reply With Quote
Old 07-07-2013, 02:37 PM   #40
marky
marky's Avatar
Drives: 2020 BRZ tS #54
@DriftEm hey buddy i was at the sdrc last week just checking out the track and bump into Charlie and said that your car sounds like it was miss firing.. could you be have this DI issues ? hows your car running? i know you drive like you stole it
Old 07-07-2013, 02:52 PM   #41
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
@BlaineWasHere is already at over 30k with a ton of autox abuse. He just popped an axle recently. No DI issues though.
denkigrve is offline   Reply With Quote
Old 07-07-2013, 03:02 PM   #42
suaveflooder
Just sent you a text. If you can do it on my day off (any monday or tuesday), i can head up your way and help
suaveflooder is offline   Reply With Quote
regalsurinalpost
Search this Thread:
Advanced Search
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
86 rentals - 2013 era bcj AUSTRALIA 11 04-23-2013 11:27 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 09:32 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 06:07 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) -- General Topics 9 01-30-2012 01:25 PM
