#379 |
Drives: An old Citroen Xantia TD
#380 |
Error the best is under 5200 rpm to not have the seal issue!
#381 |
The D4S engine use 8 injectors. At high rpm the engine become too hot and the exhaust valve must open with high frequency. The motor running upper 5200 is turning enough to refresh the combustion chamber and make the seal safety. But when you upshift upper 5200 rpm and you fall above 5200 rpm the exhaust valve as a lower open frequency and the motor overheat the seal (it can reach 150 °C) and the seal can melt. It's why Toyota says that you must upshift and waiting 0.6s to leave the combustion chamber lose is heat.
#382 |
This would seem to weigh heavily in favor of getting an oil cooler and/or radiator upgrade if you're going to be running hard in the higher RPMs (i.e., track use). Or upgrade the seals.
2022 BRZ Build 2013 FR-S Build |
#383 |
Drives: Black frs project
That's why we keep our oil temps under 230 degrees f....10k track miles zero failures even supercharged!
| The Following User Says Thank You to robispec For This Useful Post: | InvalidJohnny5 (08-22-2013) |
#384 | |
Drives: 2013 BRZ Ltd. MT
If so, at what mileage, how hard was the car driven up to that point, and how did the direct injectors look? I was reassured by Dezoris' experience, and if your injectors are fine, that would be even better still. |
#385 | |
Drives: 2022 Subaru BRZ
ZA1JA00A for the JDM Manual ZA1JA00C for the US Manual ZA1JA00G for the EU Manual see http://www.ecutek.com/news/newslette...r.html#reflash |
#386 | |
Yes my injectors were fouled by the stock filter coming apart. The seals were fine. This was at 8K track miles 2K street miles. 4K more track miles and just checked them again all perfect. |
| The Following 2 Users Say Thank You to robispec For This Useful Post: | Captain Insano (08-21-2013), thill (08-21-2013) |
#387 | |
Drives: '13 BRZ Ltd
#388 | |
#389 | |
Wahoo! Found this, I think if you have this update you are in the clear:
Next time my car is in for service I will be verifying my calibration file, but my car had a March 2013 build date so I should be good. |
#390 | |
Do you have a different tune, a modified ignition mapping, that might contribute to your engine durability where other engines have melted down? |
#391 |
Drives: '13 BRZ Ltd
Hmm. Looks like the guys in SA who have had the 00 -> 01 update have reported some better mid range bump as well (pulling out of the dip a few hundred RPM sooner):
Subective claims and dynos: http://www.ft86club.com/forums/showt...99#post1090499 I'm assuming since I have a build date of May 2013 I should be good to go. |
#392 | |
We have always run 5w30 oil and have a HUGE radiator/oil cooler combo. I think all these problems stem from too hot oil.....as the hotter the heads get the higher your chances of detonation happening, and detonation is what kills the seals. |
| Tags |
| regalsurinalpost |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 12:25 PM |
| 86 rentals - 2013 era | bcj | AUSTRALIA | 11 | 04-23-2013 11:27 PM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 06:07 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) -- General Topics | 9 | 01-30-2012 01:25 PM |
