#15 |
Drives: Scion FR-S
#16 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Can u show me a pic?
#17 |
Drives: Pile of junk
why not just vent it to atmosphere
#18 |
Love Boost!!!!!!!!
#19 |
Drives: Scion FR-S
#20 |
Love Boost!!!!!!!!
Yep they told me the same thing but i then why do D3 performance and many other has them to blow to the atmosphere
#21 |
Drives: Scion FR-S
Quite honestly I don't know enough about it to answer intelligibly and defer to others that have a better understanding. From what Crawford explained, you want the crankcase to be under vacuum and you don't want oil leaking onto the road. As far as D3 goes, no idea.
#22 |
Drives: 2013 Asphalt FR-S
They don't have any diagrams of the inside of the can so it's difficult to tell for sure how you need to connect it with a boosted application.. but i am guessing, since any oil caught is supposed to drain out the bottom port, the can has no internal separation and as a result it's not doing anything good in the current configuration.
Fairly sure the way that is plumbed right now you are sucking unmetered air into the intake manifold when off boost and blowing metered air our the when under boost. That may be part of the reason your fuel trims are all over the place. For the time being, you should take the can out of the equation and put the system back like it was before you installed the can. For that can to work properly it needs to be a closed system. You will need a bung pre turbo (as others have said) to connect to the port that is open. you also want a good check valve between the can and the intake manifold port so it will not pressurize the can under boost pressure. The stock pcv valve is on the block side so as soon as you go in boost the charge is filling the can and running out the open port and back into the block on the connected intake side port. I honestly think you would be better off with 2 separate 2 port cans and a couple of crankvents (http://www.et-performance.com/automotive.html)... the idea draining the caught nasty back into the oil system is.. well... nasty.
~Namaste~ Last edited by mad_sb; 07-01-2013 at 09:37 AM. |
| The Following User Says Thank You to mad_sb For This Useful Post: | blackfireball5 (06-27-2014) |
#23 | |
Love Boost!!!!!!!!
#24 |
NASA SpecE30 Racer
They have also blown motors and had their car performing poorly in two videos now, so I don't know that I would take my advice from them. Venting to atmosphere definitely won't hurt your car. If you plug that extra port then the vacuum from the back of the intake manifold should still pull on both the PCV and the front port.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#25 |
NASA SpecE30 Racer
Until someone shows me gains when pulling vacuum on the crankcase, then I will stick with vented. I don't want that oily air going through my engine.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | IBill4You (07-21-2015) |
#26 |
Love Boost!!!!!!!!
So having a filter is ok?
#27 | |
Drives: Scion FR-S
#28 |
Love Boost!!!!!!!!
4 engines??? Holy shit
| Crawford Edition FRS??? | CAMBAM_6 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-23-2013 08:36 PM |
| Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 | ngabdala | Engine, Exhaust, Bolt-Ons | 11 | 06-10-2013 10:22 PM |
| FS: Crawford AOS | xwd | Engine, Exhaust, Bolt-Ons | 6 | 04-07-2013 08:44 PM |
| Need help Crawford AOS install | ngabdala | Engine, Exhaust, Transmission | 19 | 11-21-2012 09:04 AM |
