Old 07-06-2013, 09:16 AM   #85
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
In for full dynos of the 93 octane setup @10psi.
I understand E85's allure for max hp numbers but I'm curious to see what a set-it-and-forget-it FI pump gas car can do.
Also, would this kit fit with the Robispec 'total cooling solution' radiator?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline
Old 07-06-2013, 09:38 AM   #86
FAER
Drives: Silver BRZ
^^^^this....
FAER is offline
Old 07-06-2013, 10:47 AM   #87
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by FAER View Post
^^^^this....
Now that's what I'm saying.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 07-06-2013, 11:00 AM   #88
troek
troek's Avatar
Drives: 2012 Toyota 86
what size injectors is this on?
troek is offline
Old 07-06-2013, 11:01 AM   #89
WRBRZ
Drives: '92 30R Talon, '13 BRZ
To be honest, from what I've read so far, I'm sold on the FA20club kit. My goal with the car is safe, but entertaining, and when I see a 250whp Vortech BRZ trapping 101 it's clear that turbo is the only option.
I would want to use the Visconti 550cc injectors, maybe a fuel pump, and def. a clutch. Lotta $$$, but should be very, very, fun. Imagine a 320whp 2750lb BRZ, with the powerband, it would hit above it's league and surprise a lot of 'sports cars'.
WR '13 BRZ Premium 6MT - Visconti Stage 1 Tune, SRT Headerback, FX350
'92 Talon - FP3052, 503awhp, Mustang dyno
WRBRZ is offline
Old 07-06-2013, 11:11 AM   #90
FR-S FI
FR-S FI's Avatar
Drives: 2013 MT FS FR-S / 07 GT500
^^^^this....
For sure...^^^ I don't see a problem having installed the FA20 kit on mine, Tony or Robispec correct me if I'm wrong but Robispecs solution I think just pushes things a little forward, and there seems to be plenty of room between the a/c condensor and the intercooler, and I believe it can use the stock fans, so it oughta bolt right up at least with minimal finagling involved. I was going the Koyo Rad / separate oil cooler route until I saw Robispecs setup, definately make things easier. Only place I see an issue is routing lines from filter plate past the turbo inlet and that is easy enough if the fittings are 45 or 90'd off the filter plate and line length adjusted.
Stage 1 V2 .57trim Turbo Kit, ACT HD6P Clutch w/Streetlite Flywheel, Greddy EVO3
391whp/295tq 13psi 96 pump
335wh
p/260tq 10psi 93 pump
FR-S FI is offline
The Following User Says Thank You to FR-S FI For This Useful Post:
ultra (07-07-2013)
Old 07-06-2013, 11:24 AM   #91
FA20Club.com
Drives: 2013 White Out FR-S
we didnt run it again with that map on 93 sorry we left the power the same as the spy shot only difference was smoothed out the curve with the boost control and timing maps. we cant afford to keep running on they dyno for every adjustment. the weeks goals were set already and it was to smooth the maps test the boost control prior to pouring in e85.
FA20Club.com is offline
Old 07-06-2013, 11:26 AM   #92
FA20Club.com
Originally Posted by FR-S FI View Post
For sure...^^^ I don't see a problem having installed the FA20 kit on mine, Tony or Robispec correct me if I'm wrong but Robispecs solution I think just pushes things a little forward, and there seems to be plenty of room between the a/c condensor and the intercooler, and I believe it can use the stock fans, so it oughta bolt right up at least with minimal finagling involved. I was going the Koyo Rad / separate oil cooler route until I saw Robispecs setup, definately make things easier. Only place I see an issue is routing lines from filter plate turbo inlet and that is easy enough if the fittings are 45 or 90'd off the filter sandwich plate and line length adjusted.
the Robi kit should fit just fine no issues there other than like Dave said change a few fittings
The Following User Says Thank You to FA20Club.com For This Useful Post:
Sportsguy83 (07-06-2013)
Old 07-06-2013, 11:27 AM   #93
FA20Club.com
we have pump and injectors options with the kit which is cheaper to purchase from us vs another vendor
Old 07-06-2013, 11:28 AM   #94
FA20Club.com
550cc
troek (07-06-2013)
Old 07-06-2013, 11:35 AM   #95
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by FA20Club.com View Post
550cc
hes still on those 500cc? is there a formula to calculate the injectors on our DI engines? i can find them for regular engines which at these levels 550cc would not work but i'd love to figure out DI numbers
lbroskee is offline
Old 07-06-2013, 11:40 AM   #96
FA20Club.com
DI injectors are basically huge solenoids. the pressure behind them is so extemely high thats why these cars can make decent power on stock injectors. youre not going to find a formula to do DI injectors what you need to remember is that you have DI cars like 335i making almost 500hp Speed 3 making 350hp with a pump upgrade. what you guys dont understand is we can adjust what ratio of how much or either DI or port injectors are used and we are only using 50% of our port injectors since we are still utilizing the DI system. and the car is still super rich on brandons tune.
The Following 4 Users Say Thank You to FA20Club.com For This Useful Post:
GaN-MaN (07-14-2013), lbroskee (07-06-2013), slowmo (07-07-2013), Sportsguy83 (07-06-2013)
Old 07-06-2013, 11:43 AM   #97
lbroskee
lbroskee's Avatar
DI injectors are basically huge solenoids. the pressure behind them is so extemely high thats why these cars can make decent power on stock injectors. youre not going to find a formula to do DI injectors what you need to remember is that you have DI cars like 3355 making almost 500hp Speed 3 making 350hp with a pump upgrade. what you guys dont understand is we can adjust what ratio of how much or either DI or port injectors are used and we are only using 50% of our port injectors since we are still utilizing the DI system. and the car is still super rich on brandons tune.
ah makes sense
dam he must b burning thru fuel then
lbroskee is offline
Old 07-06-2013, 11:56 AM   #98
FA20Club.com
same 30% increase over pump that doesnt change when youre on boost
Search this Thread:
Advanced Search
Fa20Club.com Turbo Kit FASTEST IN FLORIDA lexusb3 Forced Induction 864 02-22-2014 11:00 AM
FA20CLUB Vortech vs. Turbo Kit Comparision FA20Club.com Forced Induction 18 06-26-2013 04:43 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
FA20CLUB V2 Turbo Kit On Sale @$3500+ FA20Club.com Forced Induction 24 03-30-2013 03:43 PM
FA20club.com E85 Preliminary Review JoeBoxer Engine, Exhaust, Transmission 130 12-10-2012 12:01 PM
