Old 08-16-2013, 11:17 AM   #981
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by xjohnx View Post
have you adjusted your clutch pedal height from the DIY? i've seen some people adjust it too far and start getting this noise.
I have not played with the clutch or pedal on this car at all yet. As for the DI issue others have mentioned being that I can't get it to do it without the car moving/free reved at idle; I'd say it wouldn't be that. All the vids I have seen do that at idle. Maybe a throttle body or the bypass valve on the back of the blower?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-16-2013, 11:27 AM   #982
Subzero
Old...
Subzero's Avatar
Drives: Subaru
What do fuel trims, etc. do when the DI seals go out? I would think something like that would show up on a log.
Subzero is offline   Reply With Quote
Old 08-16-2013, 11:33 AM   #983
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by evo4g63 View Post
It does not happen when the vehicle is at a stop and free reved or throttle blipped. I even tried it at idle with launch control set on and nothing. The vehicle has to be moving and the throttle blipped, wot shifting or low speed clutch in throttle blipped. It's just super hard to drive and diag a noise while trying to look under the hood.
can you get some datalogs via ecutek? i would say it's drivetrain related if it only happens when moving, but the ecu is aware of vehicle speed and it's possible some comps are active when stopped that are not when moving.
when your moving the output shaft is turning, which at first glance seems to be the only difference between the rolling and non rolling tests...
Old 08-16-2013, 11:41 AM   #984
evo4g63
evo4g63's Avatar
Exactly, I would figure my logs would show erratic fuel trim or possible knock. The pulls and logging I have done seem okay.
-2016 Subaru WRX
The Following User Says Thank You to evo4g63 For This Useful Post:
mines13 (08-16-2013)
Old 08-16-2013, 11:45 AM   #985
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
If possible, attempt to mount your GoPro in the engine bay, aimed at your bypass valve. I believe the rapid transition from boost to vacuum while shifting/lifting is causing the actuator to open hard against the stop. It would not happen all the time at idle just blipping the throttle as you would not always be building enough boost to overcome the internal dampening effect of the actuator itself, at least to the point where it would make any significant noise. As loud as it is and the way it sounds, I highly doubt it is anything internal to your engine or transmission. It is a theory at this point, but I believe it would be worth investigating. I will see if I can find out more on my end, this may be happening in everyone's car and they just are not hearing it due to other modifications that are covering up the sound. If this is the case I would not be concerned.
mines13 is offline   Reply With Quote
Old 08-16-2013, 12:01 PM   #986
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Can you grab your engine and wiggle it? I do wonder if you guys are starting to kill engine mounts already.
Old 08-16-2013, 12:24 PM   #987
evo4g63
evo4g63's Avatar
Thanks for your input. I will see if i can mount a go pro umder the hood at get a bright enough light to actually capture good footage. At first thought I was worried about DI. But as I kept trying to diag and it not happening at idle I eliminated that. As for the bypass valve that makes more sense. If you hear of anyone else having the issue let me know. It's more of an annoyance than anything.
-2016 Subaru WRX
Old 08-16-2013, 12:37 PM   #988
phloozy
phloozy's Avatar
Drives: Scion FR-S
obviously the best way to diagnose the problem is to ghost ride the whip [ame="http://www.youtube.com/watch?v=SBPJTK1YBvs"]Ghost Ridin' Grandma - YouTube[/ame]
phloozy is offline   Reply With Quote
The Following 4 Users Say Thank You to phloozy For This Useful Post:
evo4g63 (08-16-2013), ftc~brz (08-16-2013), ill86 (08-16-2013), Sportsguy83 (08-16-2013)
Old 08-16-2013, 12:42 PM   #989
mines13
mines13's Avatar
Old 08-16-2013, 01:04 PM   #990
xxscaxx
Drives: 2013 SWP BRZ
I actually did this to check and see if my header was hitting anything as I thought the noise was related to that (I have one of the first JDL UEL headers that doesn't clear the skid plate).
Shook the hell out of that thing, couldn't replicate my noise.
Always worth a shot @evo4g63
xxscaxx is offline   Reply With Quote
Old 08-16-2013, 01:08 PM   #991
evo4g63
evo4g63's Avatar
I had the car up on a lift yesterday. Using a rubber mallet I beat the hell out of the undercarriage and exhaust components (not really beating the hell out of the car) No loose or rubbing components I could see. At times it sounds like when a weld is broken on an exhaust heat shield and it rattles. All checked out okay.
-2016 Subaru WRX
Old 08-16-2013, 01:10 PM   #992
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Did you have any excessive play prying the motor or trans around? L's, RS', Foresters, and leggy's were all awful about this after lots of miles or a short time with boost.
Old 08-16-2013, 01:10 PM   #993
xxscaxx
I meant shaking the motor, not checking for rattles on the header/exhaust components, I just used this method to check for clearance with my header. I grabbed the sc by the throttle body and shook it around to check for noises.
Old 08-16-2013, 01:14 PM   #994
evo4g63
evo4g63's Avatar
Did you have any excessive play, like prying the motor or trans around? L's, RS', Foresters, and leggy's were all awful about this after lots of miles or a short time with boost.
No, I didn't try using a pry bar to move the drivetrain or motor. I will take a quick peak at the mounts today. My car has 6k miles on it and 800 miles on the Innovate. In which 600 miles of those were driving from Phoenix to LA for 86fest this last weekend. I don't have a lot of miles at all but worth a shot to try.
-2016 Subaru WRX
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
