Old 08-13-2013, 10:27 PM   #925
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Well just to confirm everyones suspicions about the boost creeping up to 10psi. I can without a doubt confirm that it was the header. Just installed my p&l header and I am no longer seeing boost over 7.5 psi. This is with the rest of the exhuast completely stock. I must say the car is a different beast with a new header even without my tune being adjusted at all.
MattF is offline   Reply With Quote
Old 08-13-2013, 10:30 PM   #926
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
@MattF Thanks for confirming. I was told my car was reading like 9psi with the stock header. Just got my P&L in today, so it will be interesting to see what it reads during tuning after the swap.
On another note, also received my cf driveshaft!!
tech4pdx is offline   Reply With Quote
The Following User Says Thank You to tech4pdx For This Useful Post:
invisage (08-14-2013)
Old 08-13-2013, 10:34 PM   #927
invisage
Drives: Thunder Silver 86 GTS
Originally Posted by MattF View Post
Well just to confirm everyones suspicions about the boost creeping up to 10psi. I can without a doubt confirm that it was the header. Just installed my p&l header and I am not longer seeing boost over 7.5 psi. This is with the rest of the exhuast completely stock. I must say the car is a different beast with a new header even without my tune being adjusted at all.
What are you using to measure psi?
invisage is offline   Reply With Quote
Old 08-13-2013, 11:17 PM   #928
MattF
MattF's Avatar
I have an aftermarket boost gauge. I drilled and tapped the MAP plate on the top of the supercharger. I didn't trust the factory MAP sensor since it max's out at 7 PSI
The Following User Says Thank You to MattF For This Useful Post:
Old 08-13-2013, 11:17 PM   #929
sw20kosh
Drives: 2013 Black FR-S
Makes sense. Good confirmation though!
Old 08-13-2013, 11:19 PM   #930
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Waiting for the day someone breaks 275whp on this thing...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
tech4pdx (08-13-2013)
Old 08-13-2013, 11:45 PM   #931
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm not so sure... Robispec is probably at the outer limit of what this SC can do with a 70mm pulley, E85, and full exhaust. I think he's a bit short of 275.
I think to get any more, someone will have to mount up a 335 blower and underdrive it. Or go for broke and wind out 400rwhp.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 08-13-2013, 11:53 PM   #932
tech4pdx
Make love
tech4pdx's Avatar
My goal may be lofty, but that is precisely what I'm trying to do and then some. The S5-335 is on my radar. We will see how things play out in the next few months..
Old 08-14-2013, 12:40 AM   #933
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Anybody getting any weird noise at high rpm when stomping on the throttle or shifting gears at WOT? Also of you hold the clutch in and bleep the throttle fast?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-14-2013, 12:52 AM   #934
invisage
I have an aftermarket boost gauge. I drilled and tapped the MAP plate on the top of the supercharger. I didn't trust the factory MAP sensor since it max's out a 7 PSI
Thanks is your header catted or uncatted?
Old 08-14-2013, 01:13 AM   #935
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
The only noise I have is when shifting hard, but that was there before the S/C went on. Not sure what it is, hope its not the clutch slipping, but I suppose its the most likely.
Old 08-14-2013, 01:58 AM   #936
evo4g63
evo4g63's Avatar
What does it sound like? This worries me now 😣
-2016 Subaru WRX
Old 08-14-2013, 03:14 AM   #937
sw20kosh
He is 260 whp on a dynodynamics where a stock FR-S reads at 135 and a 91 base innovate tune reads at 185.... You can do the maths on that one. :happy0180:
Old 08-14-2013, 03:39 AM   #938
ft_sjo
Drives: GT86
A crackling noise from the front?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
