Old 07-22-2019, 09:59 AM   #8583
brybot
Drives: 13 DGM BRZ 6MT
Feeler: 210 Spare Parts
Finally sent my oil-seeping, misfire-causing unit into Jon Bond for its second rebuild in two years. Rebuild quote is more than it's worth so I'm parting out what's not broken. Figure might as well take a bad one out of circulation. Jon is generously offering to buy what's not broken, but advised seeing if anyone needed them first. I don't really expect anyone to be interested, just posting to rule it out.
1. Front bearing plate
2. bypass
3. Drive snout
4. rear manifold
5. lower mounting plate
6. Manifold (w/gaskets)
7. Intake tube
8. Breather/heater hoses/extensions
9. MAP sensor loom extension
10. Throttle body loom extension
11. Stock 80mm pulley
12. Two good belts
13. Allen screws for compressor-to-manifold mounting
14. Brackets
Everything listed is in working order. Will sell a 72.5mm Raceseng pulley and IC kit with both sets of blanking plugs soon if anyone wants to call dibs.
Thanks.
brybot is offline   Reply With Quote
Old 07-22-2019, 10:41 AM   #8584
jflogerzi
jflogerzi's Avatar
2. bypass
3. Drive snout
4. rear manifold
7. Intake tube
12. Two good belts
14. Brackets
Thanks.
I might be interested in the map sensor extension loom. Shoot me a PM with a cost.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
brybot (07-23-2019)
Old 07-22-2019, 03:20 PM   #8585
JDM_Import
Drives: Boosted Toyobaru
Originally Posted by 86TOYO2k17 View Post
I’m guessing you got an actual dyno tune by a shop and not a e-tune? Cable/Dongle is for loading e-tunes and cost extra.
If iPhone dashcommand
Yup I did get a dyno tune
JDM_Import is offline   Reply With Quote
Old 07-22-2019, 03:23 PM   #8586
JDM_Import
Ok so as I mentioned yesterday I got a CEL yesterday while turning on the car. I haven't driven it just yet just in case its something serious. I went out and bought a Innova 3100 OBD2 scanner which also scans ABS codes etc. Its giving me code P0451 (Evaporative Emission Control System Pressure Sensor/Switch Rage/Performance.
Anyone else get this code? whats your approach method?
Old 07-22-2019, 05:33 PM   #8587
86TOYO2k17
Drives: 2017 toyota 86
Did one of your hoses pop off the back of the manifold?
are the fittings in the back loose and or cracked? they may be going bad and leaking now.
Some people have also put a check valve between the output of the evap solenoid and the input to the blower to fix the problem.
If you are positive none of your hoses/fittings are leaking, or clogged.
You can always disable the code as its more of a diagnostic code then anything.
Also after checking everything over, just reset the code, and see if / how long it takes to pop back up. If its another 2 or so months i wouldn't worry too much just have to keep resetting it. not a big deal. or disable it.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
JDM_Import (07-22-2019), jflogerzi (07-22-2019)
Old 07-23-2019, 05:26 PM   #8588
kev0
Drives: '14
Kind of an emergency but does anyone know what belts from autozone or Oreillys fit the 72.5mm pulley? Stranded far from home and cant find my replacement belt in the trunk..
kev0 is offline   Reply With Quote
Old 07-23-2019, 05:48 PM   #8589
kev0
Drives: '14
Nvm. Found a belt at O’Reillys. Weird..my belt snapped when I went over a bump. Scraped my exhaust and all but I didn’t think it would snap my belt!
Old 07-23-2019, 06:56 PM   #8590
jflogerzi
jflogerzi's Avatar
I use this belt and have a spare at my house
Gates K061015 Multi V-Groove Belt https://www.amazon.com/dp/B000C2YCXM..._Ej4nDbKEXAWJ2
Old 07-23-2019, 07:00 PM   #8591
kev0
Drives: '14
Yup, I went back to my earlier comments and saw that you recommended that belt. I went to O'Reilly's got the exact same belt you linked. $34 though..but 3 year warranty.
Old 07-24-2019, 02:13 AM   #8592
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Pretty common. Double check the connections on your EVAP solenoid.
Last time I threw one of these, I just kept driving on it until the code cleared itself.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 07-25-2019, 02:34 AM   #8593
kev0
Drives: '14
Has anyone ever pressure tested their SC? What psi did you get?
Old 07-25-2019, 06:06 PM   #8594
kev0
Drives: '14
Hmm. Pretty sure my lean-ness was from a faulty Air/Fuel sensor in the heading the whole time..
Old 07-26-2019, 09:06 PM   #8595
kev0
Drives: '14
Welp, found a leak here from the smoke test. Seal isn't working correctly, which is probably expected from a used SC. Going to get it shipped off to Jon Bonds Performance to get it rebuilt.
Old 07-27-2019, 01:47 AM   #8596
riboyster
riboyster's Avatar
Okay guys, my turn.
Car was misfiring (I think) today on the way home from work. When I got home, I did a few low-load run ups. The first few were okay. On the 3rd one I got avid misfiring in the 4k-5k range, to the point where I threw a code and the motor dropped itself to idle.
I turned off the motor, wrote down the code(s), and restarted.
The idle works fine, but now when I use any little bit of petal, the motor stalls immediately. After several attempts to get above idle, the idle became rough, with my parameters all over the place. AFR was spiking.
The codes displayed were P1325, P0300, and U0075(which im pretty sure is from the odb connection being shitty).
Anyone got any ideas? Very inconvenient, because I'm putting the intercooler in tomorrow.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
