#8401 | |
Drives: '13 SWP GT86
And yeah, I have a loud exhaust ACE Alpha header with overpipe, catless stock FP (gutted stock cat) and a Agency Power catback. But still, it should still be more audible than it is, at least when looking at videos of other cars with stock intake and loud exhausts. There is extremely little info on the Tribodyn oil I'm using, but what I've found would suggest the oil lowers the whine..But yeah, going to buy a boost gauge first and foremost to see if I even have the 10 psi my Raceseng 72.5mm should give me. If the boost is good, then I'm at least happy the blower works as intended
IG @squareddesign
http://www.squareddesign.se |
#8402 | |
Drives: 2017 toyota 86
Its very possible the oil is reducing it. i don't think many people use/have it besides people who have rebuilds from jon bond. So could be why they are louder and you aren't. I was thinking about getting some for next time i change fluid. How do you like the 72.5 + E85, does it feel like you'd expect 10+ PSI at around 275whp? |
#8403 | |
![]() Im waiting for some parts so I've only test driven the car, missing the front bumper and other parts, so dont want to drive it too much. Still waiting for my Mishimoto oil cooler for example. Once the car is complete again I'll drive it harder and on E85.
IG @squareddesign
#8404 | |
The whine really kicks in at WOT above 5k RPM, so that could be another reason. Looking more into that oil is making me really want to get some... |
#8405 | |
As soon as it's empty I'll switch to Map 1 or 2 who are for pure E85 ![]() Yeah the oil is supposed to lower the temps in the SC, which is never a bad thing!
IG @squareddesign
#8406 |
Drives: 2013 WRB BRZ
#8407 |
i wonder if Breather Vent, 1/8" NPT, 7/16" dia. would help accomplish basically the same thing and just screw that in instead of dipstick. Or maybe something similar to help bleed out some pressure.
#8408 |
anyone know the threads on the dipstick, haven't pulled it out yet to check, looks like 1/8" npt. anyone confirm?
#8409 |
So I ended up using a brake bleeder screw that I modified. Not sure if 1/8" NTP will fit. I used an M10-1 bleeder screw, chopped off the top and jb welded a piece of filter screen.
#8410 | |
Drives: Boosted Toyobaru
Will keep you posted for sure.... |
| The Following User Says Thank You to JDM_Import For This Useful Post: | 86TOYO2k17 (05-28-2019) |
#8411 |
Good idea. I’ll probably do something similar with a m10x1 to 1/8” female adapter. What is that filter screen called exactly can you buy a small piece of it someplace?
#8412 | |
I had one that came in an air line filter I got from Harbor Freight. I just cut and flattened it and shaped to size using a wheel grinder. |
#8413 |
Well, I installed a boost gauge and my Sprintex is boosting as it should, thankfully
Still can barely hear it in the car, but my loud-ass exhaust isn't helping haha.
IG @squareddesign
#8414 | |
2013 Series 10 FRS #553
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
