#7631 |
Drives: 2015 86 GTS + Mitsi Lancer GSR
I had what seems like the same issue. It was an issue with the tune. Instead of 0.2 g/rev it was 2.0 g/rev on the axis. Caused it to trip out.
This was a base tune given by Sprintex |
| The Following User Says Thank You to COO86L For This Useful Post: | ajcarson11 (11-18-2016) |
#7632 |
Drives: UK GT86
DI ECU well grounded?
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | ajcarson11 (11-21-2016) |
#7633 |
Drives: 2013 WRB Subaru BRZ
Hey guys, so I am in talks with someone and most likely will end up buying this kit. I've been reading up on this thread and ALL I'm seeing is RPM hesitation issues and some belt issues as well. For those who own this or are more familiar with it, is this kit honestly worth it? If i get it, I plan on getting a protune from a really good tuner, so the tune won't be an issue at all. I'd also get it installed by a good shop.
What do you guys think? I'd honestly not want to deal with all these issues even if I'm buying the kit used and not paying full price. |
#7634 | |
I then had it tuned by Delicious Tuning in aussie 98 RON and E85. Completely different to the first tune my God. As to belt issues, I never ever had that issue. I used to flat foot shift and launch control take off's all over the place. Never slipped or missed a beat. Mine came standard with the 69mm pulley and had a smaller belt. |
#7635 |
Drives: 2013 Subaru BRZ Limited (Black)
#7636 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#7637 |
Drives: UK GT86
The lower of the 3 is the grounding connection, it bolts directly to a bar on the engine block.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | ajcarson11 (11-20-2016) |
#7638 | |
Drives: 2013 Scion FRS
I'm running the 69mm high boost pulley without one right now with no problems (on a conservative tune [that is still fast as shit] from Delicious Tuning). Pulled a little faster than a corvette the other day after some alcohol injections. Don't know corvettes too well, but I'm pretty sure this one was NA. I'd definitely recommend Delicious Tuning as your tuner. Outstanding shit.
ScreamingElectron - SnakeShit |
#7639 |
Drives: 16 Brz.
hey guys, i got a new receseng 72.5mm pulley if anyone is interested shoot me a message.
| The Following User Says Thank You to mert34 For This Useful Post: | brybot (11-21-2016) |
#7640 | |
Drives: 2013 Scion FRS Limited Edition
If you're planning on running the supercharger with no cooling, expect a lot of power loss in hot weather or traffic from heat soak. You can run a smaller pulley, the intercooler, or meth injection like @riboyster and I, to help. I'd evaluate your driving style and environment before you pick out your cooling methods, if any. Also, I'd recommend some kind of weight reduction to the rotating mass of the motor. Light weight flywheel and pulleys will help reduce drivetrain stress from the added weight of the supercharger. Its not needed, but you can feel the difference. There will also be more heat in the engine bay, so in a hot environment or tracking, you'll want a vented hood so you don't blow a coil pack. And if you're running a oil return or oil catch can, you'll want to run a vent to atmosphere catch can to prevent oil from being sucked into the intake under high vacuum (more needed with the 69mm pulley.) You'll want to get it tuned, as mentioned. If you're in the North West, @VitViper (vit tuned) would be my reccomendation. Other parts to look into: -cold air intake (I run the perrin Big MAF) -header (I'm soon to be running the tomei EL) -oil catch can Other then that, welcome to the club! (Or soon to be... Hopefully) Sent from my LG-H910 using Tapatalk |
| The Following User Says Thank You to PitViper For This Useful Post: | riboyster (11-20-2016) |
#7641 |
Drives: t
PM me if anyone wants to purchase a lightly used 335 kit.
#7642 |
#7643 | |
Definitely want to get a catless bunch of headers if you haven't already. Less back pressure and better performance from an aftermarket build. I'm running UELs because I like the sound more, but PitViper is making more power because of the ELs. As far as catch can; you can buy just the can online for decently cheap, and fill it with your own concoction (I use copper scrubber pads because apparently they're a good filter AND catalyst for the gasoline and oil vapors). It will save you a bunch of money just doing it yourself.
| The Following User Says Thank You to riboyster For This Useful Post: | PitViper (11-20-2016) |
#7644 |
Does anyone know if there's a billet aluminum 69mm pulley? I can definitely feel the mass difference between steel 69 and raceseng 72.5.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
