Old 02-25-2016, 07:54 AM   #6875
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Got my SPS kit installed!! Finally got it tuned (OTS Tune) and on the road. So much fun!
Wondering what fuel economy on unleaded you guys are getting on average? I feel my OTS kit is slightly fuely.
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
raven1231 (02-25-2016)
Old 02-25-2016, 08:14 AM   #6876
Docmattic
Drives: GT 86
im getting 11l/100km
mine was higher when i first installed it as i was on the gas non stop haha.
Docmattic is offline   Reply With Quote
Old 02-25-2016, 08:16 AM   #6877
COO86L
COO86L's Avatar
I'm seeing about 13.3L/100km at the moment :/
Old 02-27-2016, 02:50 AM   #6878
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by Chrisbrz14 View Post
Does anyone have a part number for the Idler pulley? I know i saw it here before but i can't find it again.
Here's the info I saved on it.
NuLine Engine Pulley EP075 (idler pulley for supercharger). Can also use Gates 38018 pulley and order locally
stockysnail is offline   Reply With Quote
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Chrisbrz14 (03-14-2016), Dream20b (02-27-2016)
Old 02-27-2016, 09:21 AM   #6879
sam69
Drives: GT 86
I'm avg 8.5 lts / 100 but do alot of country .
sam69 is offline   Reply With Quote
Old 02-28-2016, 03:19 PM   #6880
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Originally Posted by moto-mike View Post
How'd I miss this...big statement indeed, backed up with what? We have dozens of folks world wide running the sprintex/innovate tune (among nearly every other FI combo) and without melted pistons, plugs, or bad bearings (though nobody is immune). Indeed you do good work from what we hear, but I think your statement over reaches a bit. We've had the innovate setup on our car since the kit was released, and I doubt any other pro tuner has the miles, dyno time, and flash count of our vehicle in tuning this setup. I think the difference at this point is not so much tuner ability, but having the time to fine tune these setups remotely. I think for this reason alone we do "re-tunes" from other tuners more than initial tune sales by a ratio of 3:1 if not more. That means we've "fixed" a tune from just about EVERY vendor on here and elsewhere, even the "world class" ones. Doesn't mean that all bad, some just needed more work than the prior tuner was going to put in.
All that aside no tuner is 100% on every setup 100% of the time (we did indeed have growing pains last year as everyone else did with the PD blower). Nor can one single tuner own the whole market. I think we can market and promote our products without such broad and completely unsupportable statements. That can be left for the tablet types who boast "advantages" over EcuTek
Thank you
I should add my NA car first tuned by bill then i switched to mike. Mike is great tuner and i trust him. we flashed 6 NA car and one Innovate SC car , all mike tunes work great and he is so responsive at e-tune map revisions.
We use 4 separate map for every car but We never charged more for map revisions . Thank you Mike
Toyota86.ir is offline   Reply With Quote
Old 03-02-2016, 07:46 PM   #6881
Dream20b
Y u do dis?
installing my 335 kit this friday night into Saturday, will keep you all posted.
http://forums.nasioc.com/forums/show....php?t=2770387 build thread
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following 2 Users Say Thank You to Dream20b For This Useful Post:
sam69 (03-02-2016), smudge (03-04-2016)
Old 03-03-2016, 07:18 PM   #6882
Toyota86.ir
We installed a 210 sprintex pulley 75mm on one of my friend's gt86 .
Mike base tune is so good , no knock with tehran low octane pump gas , very smooth.
We returned oem map sensor , we use 700cc port injector plus dw65 pump fuel.
I will put some pictures and some data log files in the next week.
We are waiting for wide o2 harness and 69mm pulley.
Mr.Iman is car owner and he is very happy with driving feeling of his car.
Mapswitch 1 : E100
Mapswitch 2: E85
Mapswitch 3: E30
Mapswitch 4: pump gas
Old 03-04-2016, 01:22 AM   #6883
stockysnail
Just the tip
Originally Posted by DriftEm View Post
Here is where I tap for my boost gauge:
I saw you sold your supercharger, but I have a question on this. I tried removing the rear allen bolt from the back for tapping in to get a boost reading for the gauge, but it stripped really easily. I'm wondering if you have your map plate still and if not how would you suggest I create one myself? Should I just buy a new one and drill a hole, weld the fitting onto it, and slap it back on?
The Following User Says Thank You to stockysnail For This Useful Post:
Dream20b (03-04-2016)
Old 03-04-2016, 10:25 AM   #6884
Dream20b
Y u do dis?
those bolts stripped really easy for me too, broke three of them.
Dat Hot Lava Doe
Old 03-04-2016, 11:34 AM   #6885
ColoBRZ
ColoBRZ's Avatar
Drives: 2013 Subaru BRZ Silver
Looking at doing the intercooler upgrade this Summer. Wondering if anyone has recommendations on the stage 2 tune?
"Tomorrow isn't promised"
ColoBRZ is offline   Reply With Quote
Old 03-04-2016, 12:48 PM   #6886
COO86L
COO86L's Avatar
Okay peeps, having a bit of an ish at the moment.
Under load in 3rd and 4th gear mostly, between 3k and 5k there is a bit of hesitation. There doesn't appear to be any knock from what I could see. I switched back to stock ROM and it was the same/worse.
Is this something in the tune or have I got some form of leak? I've checked everywhere and all bolts are tight, don't appear to be any obvious gaps under manifold. Fuel likes are free and loosey goosey so not pinched.
Any ideas?
69mm pulley, intercooled, stock MAP sensor and intake and MAF, Tomei UEL and over pipe, stock front pipe and catback.
Old 03-04-2016, 02:40 PM   #6887
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Any ideas?
Tuning not tailor made maybe?
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 03-04-2016, 02:42 PM   #6888
COO86L
COO86L's Avatar
That's my thoughts (and hopes) before I go getting a proper EcuTek tune.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
