86WORX
Old 01-14-2016, 08:36 PM   #6791
ort895
ort895's Avatar
What catch cans are you guys running?
Also can anybody supply there dyno runs, i can't really find any.
Also, anybody runnindg this with an OFT?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 01-14-2016, 11:20 PM   #6792
dhsean
Drives: 2013 White FRS
Originally Posted by moto-mike View Post
Best to go the back. We have those nipples for about 10 bucks shipped. Going to the plate will show fluctuations with any electronic sensors due to the proximity to the intake runner. Going to the back gets you the output of the blower dampened by the intercooler, which is far more accurate.
I have 210 kit with my boost gauge drilled into the maf. This seems like a better alternative. I'm not sure what needs to be done for your option. Can you explain - PM me. Thanks.
dhsean is offline   Reply With Quote
Old 01-15-2016, 12:33 AM   #6793
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
So I just realized that the Raceseng idler pulleys will fit perfectly onto the mounting hardware for the fixed add in idler pulley. You just need to remove the small washer that goes onto the shouldered machined piece. This is useful to those of us who are running the 69mm pulley as it increases the total belt wrap which may reduce the chance of throwing a belt.
The 69mm pulley is 6mm smaller in diameter than the stock 75mm that came with my unit. The original add in idler pulley that came with my kit was 70mm. The Raceseng is 80mm. I know it is 4mm larger in diameter (total), but I think this will allow the following benefits:
1) It brings back the total length of the belt wrap around the pulleys closer to the original configuration.
2) Due to 1), it moves the spring loaded idler pulley arm back closer to its original position. I *think* that means that the spring is closer to the ideal position to generate maximum tension.
3) It causes the belt to have more wrap around the drive pulley on the blower. This *may* help prevent the belt from slipping on the drive pulley.
4) The Raceseng pulley is wider than the original add in idler, which should allow the belt to have a greater margin to float on the surface.
I've done a full autox weekend and a weeks work of daily driving on this configuration and I have had no issues so far.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
The Following 4 Users Say Thank You to whataboutbob For This Useful Post:
CarzCarzCarz (02-04-2016), CSG Mike (01-15-2016), DriftEm (01-15-2016), sroby (08-14-2018)
Old 01-15-2016, 01:23 AM   #6794
FT86RGV
looks great and hopefully removes the nasty squeaky sounds from the added pulley supplied by the kit. got a quick link on where to purchase? I assume from raceseng website but I'm being a little lazy to look around.
FT86RGV is offline   Reply With Quote
The Following User Says Thank You to FT86RGV For This Useful Post:
whataboutbob (01-15-2016)
Old 01-15-2016, 02:51 AM   #6795
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Radium engineering is what I run. I used to run the dual catch cans but nothing ever dropped into the one that hooked up to the intake pipe so I took it off and sold it, so only running the one now. Best catch can on the market in my opinion, but all of there stuff is exceptional and worth the premium price.
stockysnail is offline   Reply With Quote
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
ort895 (01-15-2016), whataboutbob (01-15-2016)
Old 01-15-2016, 09:11 AM   #6796
ort895
ort895's Avatar
So i'd be optioning for the one on the crankcase and not the PCV valve correct?
Old 01-15-2016, 12:55 PM   #6797
stockysnail
Just the tip
I run the PCV. The crankcase is the one that goes to the intake tube. At least as far as I remember.
You can order either of their kits or both as they are the same it's just they are on one side or the other. You could plug either into either PCV or crankcase, as you can run the lines how you wish. That sounded better in my head but didn't get expressed in writing very well.
Old 01-15-2016, 01:22 PM   #6798
ort895
ort895's Avatar
gotcha, thank you for your help.
Old 01-15-2016, 02:55 PM   #6799
whataboutbob
This was from a Revo S2 kit. They just did a redesign on the original idler pulleys that came with the kit and I used one of the old ones for this test. I just checked and it looks like the individual pulleys are not available on the site at this time. You might contact them via email and see if you can get a single unit.
I just want to restate that this is a custom application of their product, and I've only had this on for a short time. So far it seems good, but I won't know if it is a good mod until I've done more long term testing to see if any unanticipated issues arise from this configuration.
Old 01-15-2016, 05:14 PM   #6800
ort895
ort895's Avatar
Also, anybody running aftermarket hoods for more heat management?
Old 01-15-2016, 11:46 PM   #6801
Pekingduck
Drives: 4 wheels
Running seibon DV. I saw my water temp go +230 at last track event and i have to end my session early. and I got a vented hood and next will be oil cooler. I went to track this time and water temp didn't even go above 190.
Pekingduck is offline   Reply With Quote
The Following User Says Thank You to Pekingduck For This Useful Post:
ort895 (01-16-2016)
Old 01-16-2016, 12:07 AM   #6802
ort895
ort895's Avatar
That looks fantastic
The Following 2 Users Say Thank You to ort895 For This Useful Post:
86 South Africa (01-27-2016), Pekingduck (01-21-2016)
Old 01-16-2016, 01:29 PM   #6803
smudge
Drives: Supercharged GT86
Update on my 335 build that has had a nasty ending after just 2,100 miles
http://www.ft86club.com/forums/showt...52#post2511652
smudge is offline   Reply With Quote
The Following 2 Users Say Thank You to smudge For This Useful Post:
CK_Bladesmith (01-16-2016), stockysnail (01-16-2016)
Old 01-18-2016, 12:18 AM   #6804
Harro
Drives: 2014 Toyota 86
So boost levels - Has anyone got a boost curve for the 210 - I've done a search but found nothing.
I've recently had a dyno run and got a boost curve out of it - to say I'm disappointed would be the understatement of the century - but I would like to see some other boost curves before I start flinging shit.
Harro is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Search this Thread:
Advanced Search
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
