#5937 | |
PhoneFlash by EcuTeK
Cheers, William Knose Delicious Tuning |
#5939 |
Drives: 2017 Camaro 1SS
#5940 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Bolt sizes are typically by shank diameter, not head size
Innovate powered- Corn fed- FBM tuned
| The Following User Says Thank You to poorsche For This Useful Post: | Ultramaroon (01-13-2015) |
#5941 |
That's why I specifically said I used a 5mm wrench because I had a feeling bolt specs are retarded like that
#5942 |
Senior Addict
Drives: 86 GT
Anyone with the innovate/sprintex kit using the OEM Subaru oil cooler? I'd like see how you've connected the hoses to the throttle body inlet/outlet....
#5943 |
Running the Sprintex 210 w/ inter cooler with a 69mm pulley, E85 (flex fuel), full HKS exhaust w/ cats and a custom Ecutek tune.
1050cc injectors. Pulling about 11psi and 200kw at the wheels - is this what I should be expecting or should I be getting more out of the car? |
#5944 | |
Drives: GT 86
Depend on the dyno and the operator.
#5945 |
Senior Addict
Drives: 86 GT
#5946 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#5947 |
Drives: 2013 SWP BRZ
Are you talking about the OEM forester cooler? If so I have it, but the setup is no different than if I was running the supercharger or not. I'd check that thread out for more info (if thats in fact what your talking about lol).
| The Following User Says Thank You to xxscaxx For This Useful Post: | Fizz (01-16-2015) |
#5948 | |
Senior Addict
Drives: 86 GT
| The Following User Says Thank You to Fizz For This Useful Post: | asphaltkyle (03-05-2015) |
#5949 |
Senior Addict
Drives: 86 GT
Anyone still using the factory catback with the supercharger? Is it possible for the internal baffles inside the factory muffler to fail/break?
I've noticed over the past week or so that there's a loud rasp coming from the muffler. Started happening intermittently and only in certain mid to high engine loads. But since I fitted my catless UEL header this morning the rasp just went ballistic! Even blipping the throttle in neutral now will give out an enormous rasp, very distinctly coming from the rear end. Note: there are no leaks whatsoever, and was verified by the exhaust shop. I'm going to try borrowing a mate's used factory muffler to see if that makes any difference. By the way my exhaust setup is catless header, 2.5" overpipe, 2.5" catted front pipe, stock catback. |
#5950 |
Drives: 2014 FR-S
Unlikely it's your muffler's fault. The rasp is def. from your header. You hear it from the rear end because that's where the exhaust sound comes from. You wouldn't expect it to come from the front end, unless you have an exhaust leak.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
