86WORX
Old 10-10-2014, 05:34 PM   #5433
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Originally Posted by moto-mike View Post
We are a Sprintex dealer and have the current chargers and pricing. We also have a couple of the 335 kits coming in, one of which is spoken for already, should be fun!
Wah wah waaaaahh
So do you not sell the kit with a Delicious tune?
Also your website says the intercoolers are out of stock.
Does that mean, you don't have any kits with intercoolers? Or are you just out of the intercooler upgrades?
-Jack Burton
Old 10-10-2014, 07:55 PM   #5434
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Originally Posted by jjkerr626 View Post
So what happens to all the people that have innovate motorsports kits if they need warranty or whatnot? Is innovate going to honour that or will that fall to Sprintex? Also why is innovate not selling anymore...were they the test pilots and when the kit appeared successful Sprintex came in and didn't renew innovates license to sell? Please give us the info. Thanks.
SprintexUSA and Innovate warranties will be handled through us directly in OKC. We just don't sell to the general public. I've already sent out parts to people that needed them.
I won't touch the issue of Innovate's contract with a 10 foot pole. That subject is off limits, even for me. Better to be frank than fluffy on that one.
Intercooler upgrade kits are on the way. I don't know if I will have these before SEMA. Were still adding stock here in the new warehouse. I have new intercooled and non-intercooled complete systems and 69mm pulleys.
SprintexUSA is offline   Reply With Quote
Old 10-10-2014, 09:18 PM   #5435
bfrank1972
Drives: 2013 FR-S Argento
I'm so in for 335 results!
bfrank1972 is offline   Reply With Quote
Old 10-11-2014, 10:14 AM   #5436
Xanhast
Drives: 2013 GT86
Coolant Help
Just installed the intercooled blower a week ago and done 400 km so far and I seem to be losing coolant whenever I go complete WOT 6000+ rpm. Last run I made today for about 10 minutes with several WOT pulls, coolant went down another 1 cm. Feels like I've topped up the coolant bottle half a litre more in total so far. Regular driving and low pulls the coolant seems to hold steady. No visible leaks as far as I can tell around the engine bay. Any suggestions much appreciated cheers
Xanhast is offline   Reply With Quote
Old 10-11-2014, 10:18 AM   #5437
mikalem
mikalem's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by Xanhast View Post
Coolant Help
Did you measure the initial amount you put in? Might be bubbles working out of the system. You really had to massage The tubes to fill the space on original install.
2013 WRB BRZ Limited "Belle"
Innovate SC STG2 Innercooled-70mm pulley DeliciousTuning/Moto-East Flex Fuel Tune
TOMEI UEL Header/Overpipe, Stock Midpipe, Perrin Resonated CB
RCE Yellows + RCE Front and Rear sway bars with TSW Nurburgring 18x8/BFGoodrich g-Force T/A KDW 2 in 245/35/18
mikalem is offline   Reply With Quote
Old 10-11-2014, 10:25 AM   #5438
Xanhast
Drives: 2013 GT86
I'm hoping it might still be bleeding but my mechanic reckons based on the 3L bottle he picked up for my install we're over 2.25L by now
Old 10-11-2014, 10:35 AM   #5439
mikalem
mikalem's Avatar
2.2 liters was the amount listed for the install (2200 ml) so you are in the ball park. If it continues to drop check the entire system for leaks. I believe one guy on here reported a crack in the core that was leaking internally - hope that's not the case for you.
Old 10-11-2014, 10:42 AM   #5440
Xanhast
Drives: 2013 GT86
Sorry bad wording in my last post, we're over 2.2 on the manual by probably half a litre, damn I hope not hopefully not
Old 10-12-2014, 11:21 PM   #5441
Raven604
Originally Posted by DeliciousTuning View Post
We are seeing about a 10% increase in power across the powerband on E85. Now on 91 octane that is a different story, as you need to adjust the timing advance so much in the opposite direction it does not seem to do very much.
The 210+ kit is really going to shine on E85 but on 91 octane you may not see much improvement over the 210 kit. California 91 octane just does not cut it.
Now on other pump fuels in the world like 98 RON, or 93-94 octane there would be a little benefit but I do not think it will be 10%. It would be more like 5%.
Once again it will come down to fuel and ethanol will make it shine.
Cheers,
William Knose
You think you would you see similar results to E85 when spraying meth/water?
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 10-12-2014, 11:42 PM   #5442
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
You will probably see little to no difference with meth/water injection being the timing values are already pretty high with E85. Maybe down low a little more torque but on top probably nothing.
Cheers,
William Knose
Old 10-13-2014, 01:51 AM   #5443
Raven604
Cheers,
William Knose
No I ment spraying meth/water on pump gas. Will it be close to E85 numbers.
Thanks
Old 10-13-2014, 02:13 AM   #5444
sam69
Drives: GT 86
Thanks
That's what I thought you meant as well cause I asked the same question in my post on the previous page but William must of missed it and also would like to know if the tune is compatible with headers which I think it would be but not sure.
sam69 is offline   Reply With Quote
Old 10-13-2014, 03:54 AM   #5445
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
You're not going to see similar results because gasoline requires more air than E85 to burn. At least some of the power you make with E85 comes from the fact that you can burn more of it for the same volume of air.
Obviously a comparison to nitromethane is ridiculous but it works much the same way. Nitro has less energy density than gasoline but you can literally burn almost 9 times as much nitro with the same amount of air, so you can make absurd power.
Sellout is offline   Reply With Quote
Old 10-13-2014, 05:15 AM   #5446
s2d4
s2d4's Avatar
M=DxV
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
