Old 09-12-2014, 05:51 PM   #5335
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Originally Posted by dwx View Post
What kind of boost is that running on the E85 setup? Still the same Laminova IC core as the 210 unit? Those numbers are turbo and SC together or just SC? I realize the top end WHP is mainly due to the SC.
-21psi
-Same Laminova core
-turbo+sc together
SprintexUSA is offline   Reply With Quote
Old 09-13-2014, 03:56 PM   #5336
JoonPrime
Drives: 2015 Limited series all white brz
i remember reading a few days ago a post that said you have the official release lined up, 7 weeks or so. does this mean i can order it in 7 weeks or is it gonna be a bit longer then that should there be no setbacks?
JoonPrime is offline   Reply With Quote
Old 09-14-2014, 08:30 PM   #5337
SprintexUSA
Drives: 2014 FT86
I think that was Mark in Oz on FB. That time frame sounds right. He works in the corporate office in Perth. USA is a satellite. I'm the last to know anything
Old 09-15-2014, 05:38 AM   #5338
8686
8686's Avatar
Drives: 86
Innovate (Sprintex) Supercharger Owners Topic
What is the ideal AFR for running this SC non intercooled on 91 octane?
Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 09-15-2014, 06:51 AM   #5339
s2d4
s2d4's Avatar
Thank you
When it stops making power.
The Following User Says Thank You to s2d4 For This Useful Post:
Keenercarguy (12-05-2016)
Old 09-15-2014, 07:01 AM   #5340
8686
8686's Avatar
Drives: 86
From your experince, when it will stop making power?
Old 09-15-2014, 06:10 PM   #5341
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by SprintexUSA View Post
We're looking at two standard pulleys, 75mm(non-ic) and the 69mm (ic). CARB approval depends on the tune, which the last I heard is still in Bill's corner. The systems just arrived here recently, so I'm still getting up to speed on the details. We have a whole lot of nice new things coming about.
We are working out the details on this.
Cheers,
William Knose
Old 09-16-2014, 09:53 AM   #5342
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Does this kit work better or worse if you remove the stock intake snorkel pictured below?
Wise is offline   Reply With Quote
Old 09-18-2014, 01:30 PM   #5343
blown
Drives: ft86
blown motor?
runs fine, idles fine, blows tons of smoke at Full throttle only and start up.
went through 1 qt in a day and oil pools inside the intake manifold.
72mm pulley e85
blown is offline   Reply With Quote
Old 09-18-2014, 02:28 PM   #5344
xwd
If you had a turbo I'd say for sure blown turbo oil seals, not sure how the Innovate works though.
Old 09-18-2014, 02:40 PM   #5345
mikalem
mikalem's Avatar
Drives: 2013 WRB BRZ Limited
Just started or was this right after installation...? Looks like you are getting a ton of oil from the return into the back of the intake - way more than you should anyways.
2013 WRB BRZ Limited "Belle"
Innovate SC STG2 Innercooled-70mm pulley DeliciousTuning/Moto-East Flex Fuel Tune
TOMEI UEL Header/Overpipe, Stock Midpipe, Perrin Resonated CB
RCE Yellows + RCE Front and Rear sway bars with TSW Nurburgring 18x8/BFGoodrich g-Force T/A KDW 2 in 245/35/18
mikalem is offline   Reply With Quote
Old 09-18-2014, 02:54 PM   #5346
blown
Drives: ft86
happened on a spirited drive, a few hundred miles after install. PCV valve checked fine, catch can for pcv valve empty, the catch can for the engine breather had oil, and that is where the oil appears to be going into the inlet elbow..
Old 09-18-2014, 03:10 PM   #5347
blown
Drives: ft86
Old 09-19-2014, 10:40 AM   #5348
blown
Drives: ft86
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
