#3851 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
#3852 | |
Drives: Raven FR-S
My car is very jerky down low when it's cold and at times when fully warmed up.....guess I'll have to do some logging and see what's going on.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3853 |
Drives: 2013 BRZ limited SWP
Looks like Innovate has the intercooler upgrade kits in stock again. I got my tracking number today. Btw my coil pack issue happened on a non intercooled kit. I will report back if it happens again with the intercooler installed.
Sent from Samsung Galaxy Note 3 |
#3854 | |
Drives: 2013 WRB BRZ Limited
2013 WRB BRZ Limited "Belle"
Innovate SC STG2 Innercooled-70mm pulley DeliciousTuning/Moto-East Flex Fuel Tune TOMEI UEL Header/Overpipe, Stock Midpipe, Perrin Resonated CB RCE Yellows + RCE Front and Rear sway bars with TSW Nurburgring 18x8/BFGoodrich g-Force T/A KDW 2 in 245/35/18 |
#3855 |
Drives: 2013 SWP BRZ
We'll ends up my issue wasn't the spark plugs. Going to try to replace the direct injector seals now as it seems to be happening right in the same RPM range on WOT.
I can't catch a damn break
#3856 |
AutoX-10/10ths every run
Nope. The brass fitting's thread was plenty tight.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
| The Following User Says Thank You to whataboutbob For This Useful Post: | mikalem (03-11-2014) |
#3857 |
Has anyone installed a Crawford AOS with the Innovate kit?? I picked up the universal one a few weeks back on a groupbuy and was going to install it this weekend. I need to find a spot to mount it and was curious if anyone has one installed already with this kit and where did you mount it?
#3858 |
Drives: t
try the saikou michi.. does both and half the price.. and it works..
#3859 |
Drives: 2013 Asphalt FRS
Hey guys a local is having a weird coolant leak ever since he had his IC installed. I know I saw some people who had a leak or issues with the IC. It's hard to dig through EVERYTHING in a short amount of time. Anyone have an idea where this small leak could be coming from? Just helping out the owner/Shop that installed it.
(he isn't on the forum)
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#3860 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Should have an update on my car soon as the tune/intercooler is having issues.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following User Says Thank You to stockysnail For This Useful Post: | NickFRS (03-11-2014) |
#3861 | |
Drives: Raven FR-S
Look for the leak to be at the T that connects to the coolant bottle and into the back of the charger. Mine only starts leaking when temperatures go from hot to really cold.
#3862 |
Drives: Raven FR-S
I also checked my gear oil in supercharger and it was very low....only touching the bottom of the dipstick. Put some Lucas 75 90 in it and she's good to go now.
#3863 | |
Your ic was having issues? sad day man.
2013 Sion FRS
#3864 |
I had a leak at that T fitting. No where else. If the clamps were put on tight enough, there shouldn't be any other leaks anywhere, but check the water pump inlet/outlet, and use a shop towel to wipe down each area so you can see if its wet or not.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
