#3641 | |
Drives: beater
Bigger head might not fit anywhere there's a counterbore. |
#3642 | |
Drives: Subaru BRZ with Delicious Innovate
@xxscaxx
stand in a house temperature controlled at 70 F in front of a window on a really sunny day.. you will get pretty warm in the sunlight. now wrap yourself in that termotech stuff.. it'll do its job and you will feel 70 F again.. now stand in the 70 F house in the shade and wrap yourself in that thermotech stuff.. nothing happens.. its only good for radiant heat.. sure there is some radiant heat in the engine bay.. but like I said. MOST of it is coming from conduction from the engine heads through the manifold and convection by being trapped in a closed room with a bunch of hot stuff and hot air.. oh and the fact that when you compress air it gets SUPER HOT (THE BIG PROBLEM). [ame="http://youtu.be/-MMGzeA1TXo"]http://youtu.be/-MMGzeA1TXo[/ame]
| The Following User Says Thank You to calispec For This Useful Post: | xxscaxx (02-25-2014) |
#3643 |
Drives: GBS Premium
Is there any trick to removing the pulley?
Edit: Never mind. Red Loctite made it a real bitch to get off.
#3644 |
Grip>Slip
False alarm, still looking. Definitely not the PVC after removing and zip tying that into place.
| The Following User Says Thank You to xjohnx For This Useful Post: | Calum (02-26-2014) |
#3645 |
Drives: 2016 Subaru WRX
Bill please put your car on a DynoJet so we can see what it makes when you are done tweaking
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#3646 |
Drives: 2017 Halo Toyota 86
Anyone running a 70mm pulley? How are you getting more then 10lbs of boost? Are you using a boost controller?
previous build thread!
http://www.ft86club.com/forums/showt...236#post962236 |
#3647 |
Drives: fr-s
#3648 |
Drives: 2013 Asphalt FRS
This. Even the 75 pulls like 6-8lb's I think. Evan you have a upgraded bar sensor? I'm thinking about ordering one today. Don't know how that works with BRZedit.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#3649 | |
Drives: fr-s
![]() Sent from my Nexus Five, I'm Alive! |
#3650 |
Drives: Scion FR-S
#3651 |
Did you use a boost controller? What kind? Right now I'm only able to get around 10
#3652 | |
Edit: you can't use a boost controller on a twin screw supercharger. Centrifugal.. That's a different story. Also. Boost controllers will only limit boost. Not increase it.
| The Following User Says Thank You to calispec For This Useful Post: | evan (02-26-2014) |
#3653 | |
This one? http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor
2013 Sion FRS
#3654 |
Drives: fr-s
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
